Old 08-02-2011, 03:07 PM #16
jimithing jimithing is offline
jimithing is on a distinguished road
Originally Posted by Seatown View Post
I think I figured out my issue. Earlier this morning I was at Toyota for some warranty work on my console power outlet and spoke to the tech about my issue. He came back and said that I need to program the homelink with the main garage remote, not the backup basic remote that I've been using. I do have 2 other primary remotes with 3 buttons on them; internally they have a large circuit board that the small one does not have. We're assuming the lager circuit board contains the ability to get the remotes to connect to homelin. I'm going tonight to see if I can get it the other ones synced up.
Do you know if your garage door opener has the rolling code or not? If it does then it's my experience that the only way to train it is with the button on the garage door opener itself, like Dr. Gonzo said.
jimithing is offline   Reply With QuoteReply With Quote
Old 08-02-2011, 03:12 PM #17
Seatown's Avatar
Seatown Seatown is offline
Seatown is on a distinguished road
Seatown's Avatar
I hear you, but I've tried the train button technique at least 4-5 times aleady with no luck whatsover. maybe i'm doing it wrong....this is what I've done
1. hit red train button on overhead opener...red light blinks
2. jump in car and press the 1 button upto 5 times
nothing!
am I missing a step?
2018 TRD OR: 265 Grabber AT2, Pro Comp 7005, 5100/5160, Dobinson coils, SPC UCAs, N-Fab, XD LED Low, TE roof rails
Seatown is offline   Reply With QuoteReply With Quote
Old 08-02-2011, 11:56 PM #18
Dr. Gonzo's Avatar
Dr. Gonzo Dr. Gonzo is offline
Dr. Gonzo is on a distinguished road
Dr. Gonzo's Avatar
sounds like you're doing it correctly. The only thing I could suggest is erasing the homelink itself, then trying again. Hold the two outside buttons down for 30 sec.
You probably have already tried this. When programing the homelink try holding the button (inside the car) down for a couple seconds.
Do you know if it is a rolling code system?
2006 4runner Limited V6 4x4
265/65/18 BF Goodrich All-Terrain KO | Bilstein 5100s set at .85"
4300k Morimoto HID | Exhaust tip relocate w/ Borla tip
Map light mod | Custom Sat Nav mount | Weathertechs
Dr. Gonzo is offline   Reply With QuoteReply With Quote
Old 08-03-2011, 12:27 AM #19
Seatown's Avatar
Seatown's Avatar
Thanks Dr. Gonzo I figured it out!! I was using the auxiliary remote from Genie (small key chain remote w/ flashlight), this remote did not have the ability to sync up with the homelink. After a trip to radio shack for a battery I resurrected a larger remote. First having to train it to the system; from there it synced to the homelink instantly with rapid flashes after holding both homelink and remote buttons simultaneously. From there I did the rolling code training directly from the unit and boom...there it was!
So, morale of the story is make sure your remote is the primary, not a backup remote or else it won't sync.
Thanks for everyone's help in figuring out my problem.
Old 10-03-2018, 11:06 PM #20
FrankG FrankG is offline
FrankG is on a distinguished road
Just bought a brand new 2018 Limited 4Runner and had this same issue - spent a few hours trying everything in the manual and it didn't work. I have a garage door opener with a rolling code. Just got it working tonight so wanted to share the steps I did. Hope this helps others.
1) First, in your car hold down homelink buttons #1 and #3 simultaneously for 10 seconds until you see the light flash green. That will clear the car homelink settings so you are starting fresh.
2) Find your manual remote that came with your garage door opener - ie this is the handheld clicker that comes with any door opener. You can NOT skip this step. If you are like me you never use the handheld clicker but you need it to set the homelink. Hold the handheld clicker right next to the homelink buttons in your car and then simultaneously press and hold one of the homelink button and the handheld clicker button at the same time. Wait for the green blinking light and then release both.
3) Now go to your garage door opener and press the 'learn' button. Go back into the 4Runner and press and hold the homelink button you set in step #2 above. You should see your garage door opener light blink once it has registered. I did not need to press and release 3 times like the manual said - I press and held it one time and saw the light blink on the garage door opener. I then was able to press the Homelink button and the door worked.
In my other Toyota, which is a 2012 Sienna I did not have to do the extra step of programming with a handheld remote first and could just program the homelink button. But for some reason with the 4Runner you MUST program the handheld clicker with the Homelink as a prerequisite. I had tried to skip this step and it never worked. A few other folks on this thread mentioned it as well and they were right. I wanted to add more detail here and let others know too.
FrankG is offline   Reply With QuoteReply With Quote
Old 10-04-2018, 08:48 AM #21
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
^^ That's how I program all of my Gentex mirrors (even the ones I pick up from the junkyard to swap out the basic no frills rear view mirrors).
Gotta keep track of that clicker.
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 10-04-2018, 09:13 AM #22
hinmo24t hinmo24t is offline
hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough hinmo24t is a jewel in the rough
i have only had my 2004 a few mos now but have a 2 car garage that id like to link to the truck. can all the 4th gen 4runners perform this? i have remote clickers as backup but would like to avoid always having it on my visor or glovebox.
thanks
hinmo24t is offline   Reply With QuoteReply With Quote
Old 10-04-2018, 03:39 PM #23
ZebRuaj's Avatar
ZebRuaj's Avatar
thanks
Yes, if you have homelink in the truck. Clear the memory, then re-program it.
Yes, if you don't. You can get homelink with a new/used Gentex mirror swap. There's a thread on how to add a Gentex homelink mirror if you search for it. I've done it to mine.
Old 10-04-2018, 04:08 PM #24
thanks!
Old 12-01-2020, 11:35 PM #25
JeffInTampa JeffInTampa is offline
JeffInTampa is on a distinguished road
I have a 2011 4Runner Limited and had programmed button 1 for my Genie GDO. There are 4 other devices programmed for that GDO, and all those are fine. Today, my button 1 stopped working. The LED flickered weakly when I pressed button 1, so I tried programming buttons 2 and 3 with no luck.
If it matters, the Genie is model 2040 "Quick Lift" AC Powered Belt Drive, installed in 2012. The programmed devices are my 2011 4Runner, daughter's 2010 4Runner, 2 original Genie remotes (son and wife) and one Genie Intellicode remote added for daughter's running excursions.
Any suggestions on how I should proceed? Reset the Genie and start over?
Aha: "You cannot used more than one button per remote, per opener". "Per remote" means "per device", so that explains why I couldn't program buttons 2 or 3. So, I do need to follow the instructions for "Erasing all remotes" and start over. Fam will be annoyed...
JeffInTampa is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 08:17 AM #26
jonz's Avatar
jonz jonz is offline
jonz is on a distinguished road
jonz's Avatar
I suggest, clearing the memory and then re-linking all your openers. Not sure about your model, but Homelink reps gave me info several years ago on only 6 devices being stored at anytime, any time one is added, one gets knocked out. See my posts earlier in this thread or follow this link.
Homelink Looses Programming - Toyota 4Runner Forum - Largest 4Runner Forum
2017 Trail Premium, Weathertechs, BFG KO2s 275/70/17, Xnenon Depot HIDs, Gobi Stealth Rack, NFab stepbars, Chinese TRD Grill and Marker lights
jonz is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 05:18 PM #27
We're planning on doing that this weekend. It's not clear whether that will also clear the two original preprogrammed Genie remotes, but I'll post the outcome here.
