02-09-2010, 08:16 AM
Looking to have Shock/Struts replaced...
Ive got 93,000 miles on my 03' Runner and noticed it's riding pretty rough. I was curious what the ballpark cost would be to be to have the shocks replaced. Ive done a lot of the maintenance myself but suspension work is a little out of my comfort zone. Whats a good brand to go with thats as good as OEM?
Thanks!
02-09-2010, 10:13 AM
Super Moderator
Super Moderator
xreas?
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
02-09-2010, 03:17 PM
You may want to start reading up on FJC suspension swaps. The two gotcha's are the rear air suspension (which you probably don't have), and the X-REAS. The X-REAS can be pulled if you have a set of shocks.
02-09-2010, 04:16 PM
Originally Posted by CJ3Flyr
xreas?
That's the question, isn't it. If you have XREAS and want to keep it, parts alone will cost $500+. If you don't have XREAS, the parts will be a lot cheaper.
If brute force doesn't work, you're not using enough of it.
Current: 2013 Land Cruiser
Gone: 2003 4Runner V8 Limited 4WD
02-09-2010, 04:30 PM
you could always do without xreas too. simply replace the struts with new t4r or fj shocks. and the fj springs are interchangable as well
02-09-2010, 07:57 PM
xreas?
I dont believe I have the xreas. From the sounds of it I wouldnt keep it if I did. Im looking for something thats as good as oem. Thinking about giving Meineke a call to get an estimate. Ive never kept a vehicle long enough to need new shocks so I have no idea what to expect them to cost.
02-09-2010, 08:06 PM
Some people don't know that their shocks only last about 50,000 miles before they need to be changed. I found this out with my 99 Maxima that I no longer have. They may be different with Trucks, but I know I need to replace the ones on my T4R, as it has over 71,000 miles on it.
2011 LE Toyota 4Runner Classic Silver Metallic| JBL/NAV System | Chrome Tip | Running Boards | Factory Crossbars |
02-09-2010, 09:04 PM
Super Moderator
Super Moderator
Many like the Bilstiens. For a good OE Replacement shock I like the KYB GR2.
If I were you I'd find a local shop that'd put on what ever shocks you carried in and then pick your shocks.
Chris
02-09-2010, 09:17 PM
Banned
Banned
Put some Toytec in there.
02-09-2010, 11:55 PM
I'd go Bilstien's as a great replacement/upgrade. all 4 should cost about $300 without having a guy put them in for you.
02-11-2010, 02:17 PM
PM sent.
02-11-2010, 02:54 PM
why not just get a set of FJC stock ones? i picked up some for $85 from a local seller. i haven't installed it yet. one of my xreas shocks is leaking but don't want to just throw the other three away. i haven't noticed any ride difference except the noise when i go over speed bumps at low speed. i want to use them as long as possible. will get mechanics opinion during my oil change next time...
2006 Sport Edition V6 4X4 Shadow Mica
Permavin/Glass Etch
FJ suspension
Side-exit Exhaust
aFe CAI
02-11-2010, 10:42 PM
I had the XREAS fail in my '03 and was quoted $4k by my dealer to fix/replace it. "But," they said, "it'll be warranted for 3 years"
I replaced it with a ToyTec 3" Ultimate lift for about 25% the cost. I now have a much better ride, a bunch of money left in my pocket and a great looking and performing 4Runner. Maybe more importantly this gets you a suspension that can be worked on in the event of a problem, not a rip and replace job.
Even the Toyota dealer didn't know how to work on XREAS much less a local shop.
+10 on ToyTec
XREAS
02-11-2010, 10:48 PM
I just recently had a dealership install a brand new XREAS system on my Runner tubes and all. The entire XREAS was changed out due to mechanic error when installing my lift. I would love to get rid of this and go aftermarket so if you all know anyone interested in buying a BRAND NEW XREAS system just PM me and make an offer I cant refuse and they are yours!Less than 600 miles on it!
2007 4Runner Sport 4X4 Silver..
MODS so far: 2.5/1.5 Daystar lift, Installed Garmin Nuvi 350, rear FJ springs, Husky Liners (front, rear, and cargo), K&N air Filter.
02-11-2010, 11:21 PM
hey there fishn, was it the dealer that made the error?
i took my truck to the dealer 3(!) times with xreas issues once they kept it for a week, they could never figure it out! my friend and i took it out in a big parking lot for 30 minutes and figured out what the problem was (he did really, but it was a 2 man job ;) )
10 days later the XREAS was removed and the ToyTec installed, problems solved!
XREAS
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
