keyless entry problem...front door wont lock
I've searched the forum, but didnt see a similar problem. i have a 2008 with factory keyless entry. when i press the lock button on the remote, all doors lock except the drivers door. and, when i press the lock button on the remote, you can hear all doors trying to keeping locking a couple more times. when i press the unlock button, all doors unlock, normal beeping sounds, and lights come on. no issues with the unlocking feature.
one other thing. when i put the car in reverse, the doors try to lock like normal and all do except the drivers door. and again, you can hear the doors trying to lock a couple more times.
i havent done anything to the car except add HIDs. I've had them for quite a while and havent had any issues related to them. ive checked the fuses and none are bad. i disconnected the battery and left it for an hour. and there is no corrosion around the battery terminals so i think there is a good connection.
any ideas???
2008 2wd SR5, V6
Mods:
Extreme HID's 4300k with Philips bulbs; lows and fogs
FJ Coils/Bilstein 5100s all around
