02-19-2010, 07:10 PM
Body lift vs spacers...your take
Ok, I am in the process of narrowing down what I want to do but would like some good solid input before I make the move.
Body lift vs spacers. what works better and is easier to get done in a weekend. I have looked at the
Toyteck 1" body lift, 2.5" FRONT 1.5" REAR LIFT KITfrom Daystar
Cornfed spacers 3/2 & 2/1.
how much lift would i actaully get out of these kits and whats the best bang for the buck.
As it sits now, the front fender is 33" off the ground and the rear is at 36". I would like to level it out and maybe get an added inch in the rear.
Pros...cons....ideas?????
As always, thanks for your help and input.
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
02-19-2010, 07:22 PM
I did the front 1" spacer(2"lift) leveling kit to my 04 two weeks ago. It took me 2 hours and it was a piece of cake. I am looking for some FJC spings next, and some FJC wheels too.
02-19-2010, 08:04 PM
what brand did you use and how does it ride? you are saying that a 1" spacer has given you 2" of lift on the front correct?
02-19-2010, 09:17 PM
Real Name: Blair
Real Name: Blair
Well what is your goal for lifting your truck? Just looks? Also, how much lift do you want? If you are wanting to get rid of the rake on your truck, a BL won't do it since it will lift it evenly. I would say start with a suspension lift, a body lift does not raise the underside of your truck at all, at least with a spacer lift you will have some more clearance under your skids and frame rails (not sure if you off road)
As for which is easier to install, I would probably say body lift.
I have a body lift, but only got it to fit bigger ties. My front fenders are 39.5/40 off the ground and rear fenders are 40/40.5.
2008 4Runner Sport Edition 4WD V6- Long Travel, Camping Rig Build Thread
2023 Lexus LX600 F Sport- Daily Driver
2023 Highlander Hybrid Limited- Wife Daily Driver
02-20-2010, 04:17 AM
Both? But I started with the spacer lift. There's more functional benefits with a spacer lift than a body lift (more ground clearance).
02-20-2010, 02:37 PM
I would like to start with getting rid of that nasty rake but not sure what size spacers to get. I see your point on the body lift. What spacer kit did you prefer?
02-20-2010, 03:09 PM
Measure the gap between the rear tire and bottom of the fender, then do the same on the front. Typically there will be about 2" difference. However, a 2" lift puts the running boards with an upwards slant towards the front. I chose a 1" spacer lift with FJ Cruiser front springs, this setup will give 1.5-2" of lift.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
02-20-2010, 04:06 PM
Question Blair, and anyone else please chime in. I want a lift not for looks, but to create more ground clearance. I've faithfully searched for and read lots of threads about lifts, and ended up genuinely confused about at least one thing. On the higher lifts at least, I read things about dropping down the diff? I assume they're talking about the differential, but what it this about? When you lift then drop something back down, that would seem to defeat the purpose to some extent.
Sorry if this question is too elementary, but I'm sort of lost here.
02-20-2010, 04:52 PM
One difference is that a body lift won't change your CV angles or other suspension components. To add a question here, are there any suspension lifts that will not change the CV angles (other than a lift then diff drop)? If not is the way to go to switch to aftermarket CV boots if you have problems after a lift?
2007 4Runner Sport V6 4WD Shadow Mica, Tint, Extended differential breather, Carbon filter removed, Bilstein 5100s - 0 setting with Old Man Emu 884s, ToyTec Superflex coils and 5100s rear, Dobinsons UCAs, P265/70/17 Michelin Defender LTX M/S, Spidertrax, Xtreme Phillips 4300K HIDs, ICON Sway Bar Relocation Blocks
Former 1999 4Runner Highlander V6 4WD Black
02-20-2010, 05:34 PM
Good answers can be found in this thread:
Lift requiring more alterations
02-20-2010, 06:15 PM
Let me see if I'm reading that thread correctly. It is when you go over 3 inches that you have to start adjusting things. For example a Toytec Ultimate 3" lift package (which is one option I'm seriously considering) wouldn't require any changes to brake lines, differential, etc.
Is that correct?? Thanks again for the all the great help people offer here. It's hard to imagine being without it.
02-20-2010, 07:34 PM
Ok, so lets just say i am going to get the daystar 2.5/1.5 lift. What will something like that run me $$$ wise? I really want to get this and get it on. The T4R rake is driving me nuts!!!!
Reason: f
02-20-2010, 10:43 PM
there's a link somewhere around here for the daystar kit on amazon.com for $159.00+ shipping. i was going to order it from there, but I got bit by the OME bug due to a weakened factory struts and springs after 137k miles of use.
03 T4R Limited V8
02-20-2010, 10:52 PM
I recently bought an '08 4-runner SR5. I have no idea why a manufacturer would reduce the ground clearance on a utility vehicle. Probably an idea from the same bozo that decided to remove the dipstick on the automatic transmission. I'm no expert, but bought the vehicle because I live several miles off the pavement and another mile past the end of a maintained road. Soon as I got it, I had Desert Rat install a Daystar kit, 2.5" lift in the front and 1.5" in the rear. I also removed the running boards for more clearance. I think the parts were about $165.00, $100.00 for the post wheel alignment, (you want this) for a total of about $490 with tax.
I am delighted with the setup, it gets around great in snow and mud with worn out Michelin tires. (60,000 miles on vehicle.) I would consider the lift an essential part of a purchase.
02-21-2010, 09:14 PM
@ BRK....do you have any photos of your runner after the install???
