03-01-2010, 11:01 PM
Back seat won't fold up????
I was getting ready to haul some stuff in my cargo area today and I was trying to fold up the back seat but it seems as though it is locked some how. The single seat folds up fine but the double seater is where I'm having issues with. The bottom part won't fold up at all. Is there some sort of lock on this? This just happened today. It worked fine two weeks ago when I had them down. Any ideas???
2006|4Runner Sport|v8
2007| Lexus IS250 AWD
03-01-2010, 11:26 PM
Banned
Banned
Maybe something's stuck in there. My '03s seat has something you have to pull to put it down then the backrest has a button ontop to push down before you can put it down. When putting it back up, the backrest has to latch before i can put the seat up.
03-02-2010, 03:00 AM
I am going to assume that my 2003 is the same as your 2006 model. The rear seat bottom is hinged in the front so it pivots forward when lifted and there is no locking mechanism. Check under the front area of the seat bottom cushion, maybe there is some foreign object wedged there that preventing the seat bottom from pivoting forward.
03-02-2010, 03:35 PM
Checked all around and not much I can move around. I can squeeze my hand underneath the seat but not very far and i don't feel anything at all. any other ideas??
03-02-2010, 04:31 PM
Again assuming my 2003 is the same as your 2006. On the lower front of the bottom seat cushion near the floor are two plastic covers. Pop the covers off, and underneath them are the bolts that secure the front seat hinge to the floor. If you remove the bolts, you should be able to remove the lower seat cushion. In looking at my rear seat, on the floor under the rear seat cushion are two round tabs that are open on the back half. Underneath the passenger side bottom cushion towards the middle of the vehicle there is a metal loop that rest just to the rear of one of those round tabs when the seat is in the down position. Also there is a metal tab on the outboard underside of the bottom seat cushion that's covered by fabric that also rest just behind the other round tab when the seat is in the down position. Maybe something has shifted to cause the metal loop/tab under the seat cushion to lock into the round tabs on the floor. If you unbolt the front hinges from the floor you should be able to wiggle the seat bottom out. If the tabs are locked together you may have to push the seat bottom back after unbolting the hinges so the tabs clear each other.
03-02-2010, 06:34 PM
Thanks, I'll give that a shot.
03-02-2010, 08:21 PM
This may sound simple, but have you checked to see if the front seat is too far back, and not allowing the rear seat back to be lifted back up into the vertical position? With my '03, I have found that if either of the front seats are all the way in the rear position, it is very difficult to get the rear seats to drop all the way down, or lift up to be put back in the vertical position.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
03-02-2010, 09:59 PM
If I understand Andyboy's post, he is unable to lift the rear passenger side seat BOTTOM cushion up to its vertical position. For some reason it is stuck in the down position and he is unable to lift it up and forward toward the back of the front seat.
03-02-2010, 10:20 PM
What he said...
I haven't unscrewed the seat hinge yet. I will try that soon.
03-03-2010, 07:40 AM
OK, my bad. I guess I read his post too fast and mis-understood what his issue was. I don't know what the problem could be. I fold my seats down quite a lot, and have not had that problem so far.
03-04-2010, 10:08 AM
I've had the same problem on my 08 Urban Runner.
Problem: Rear Passenger SEAT BOTTOM stuck and won't fold forward.
Solution: While pulling up on the nylon pull-tab, give the front of the seat bottom a good rap towards the rear.
Note: I discovered this quite by accident when in my frustration to get the seat bottom up to load gear, I smacked the front of the seat while pulling up on the nylon pull-tab...........and "they" say anger is never the solution.
2008 Urban Runner
*** 1.5" Cornfed front lift
*** Winter tires: Michelin LTX A/T 2
(265/70/17, Load Rating E)
*** Summer Tires: Michelin Latitude
(285/60/18 Speed Rating V)
03-04-2010, 11:34 PM
took off the hinges and foud that the "hook" that's bolted to the platform of the floor underneith the seat was catching on the metal thingy on bottom of the seat where there's a little dip at the end. I bent back the thin metal on the bottom seat and then placed a small cardboard on top of the "hook". It's ghetto rigged but it works! damn, PITA!
Think my fiance' was the last one who placed that seat down. Guess she was mad at me for not walking the dog...yay marriage! Thanks for all the help!
03-05-2010, 02:50 AM
Glad to hear that the problem is resolved. Well you know what they say,
"Women, can't live with them, can't live without them". (LOL)
07-18-2013, 04:07 PM
Totally worked!
4Given, thanks for the good advice. My seat was stuck and I tried loosening the bolts, sticking a screwdriver down there . . . everything.
Then I did what you recommended and pulled forward on the fabric strip while giving the front of the bottom seat cushions a good hit. It totally worked. After the seat bottoms came up I could see that this was happening because the fabric around the plastic tab that clicks to the round black locking mechanism was slightly torn and getting stuck in the mechanism. I trimmed it with some scissors and voila . . . the seat it back in working order.
Thanks for the advice. It saved me a trip to the dealer.
08-21-2014, 09:33 PM
A moment of Zen
Push the front seat all the way forward. Get in the car facing the backseat with your knees on the front of the seat. Put your non-dominant hand on the top of the backseat. Put your dominant hand on the little loop and pull up at the same time you push back with your knees. This puts pressure on the seat to move back and it will come up easily. The makers of this car have designed it to work without a struggle. If you are struggling something is wrong. Peace out.
