Old 10-28-2004, 11:50 AM #1
Joe_GT Joe_GT is offline
Joe_GT is an unknown quantity at this point
Question Lift Kit and Factory Warranty
HI All,
I just wanted to know if you do add a lift kit to your vehicle, will this void or change the factory or extended warranty? I though that alterations to the vehicle would do this, but I am just checking to make sure.
Thanks,
Joe
Joe_GT is offline   Reply With QuoteReply With Quote
Old 10-28-2004, 12:19 PM #2
boston_kevin's Avatar
boston_kevin boston_kevin is offline
boston_kevin is on a distinguished road
a quandry....
According to the manufacturer's specs, if you mod anything, then the system you made the modifications to is now void under warranty. However, and I say this strongly.... It can also apply to systems that are affected by the modification.
For example: You add a lift and bigger tires... 6 months later, you have to replace the steering pump. Some dealers (not all) will argue that the increased weight of the tires and wheels over the stock size/weight caused premature failure of the pump and thus is not covered under warranty. I have known people who lifted their jeeps and threw U-Joints or driveshafts, and the dealer refused to service the vehicle under warranty because the angle of the lift placed the shafts and joints at a more severe angle causing them to fail.
Bottom line, it is most likely a dealer call, but any system affected by the lift may be void under warranty (this would include, but not limited to the brakes, steering, drive shafts, tranny, diff's, and the electronic systems controlling these areas)
boston_kevin is offline   Reply With QuoteReply With Quote
Old 10-28-2004, 12:55 PM #3
Faeylyn Faeylyn is offline
Faeylyn is an unknown quantity at this point
From a thread on Yotatech:
MAGNUSON MOSS WARRANTY ACT
US Code - Title 15, Chapter 50, Sections 2301-2312
Legally, a vehicle manufacturer cannot void the warranty on a vehicle due to an aftermarket part unless they can prove that the aftermarket part caused or contributed to the failure in the vehicle (per the Magnuson Moss Warranty Act (15 U.S.C. 2302(C)) . For best results, consider working with performance-oriented dealerships with a proven history of working with customers.
From: http://www.magnusonproducts.com/magnusonmoss.htm
The farther you get away from the modification, the more difficult it would be for them to prove a connection. However, that doesn't mean the dealer will fix it. It may require arbitration.
Faeylyn is offline   Reply With QuoteReply With Quote
Old 10-28-2004, 01:14 PM #4
4route's Avatar
4route 4route is offline
4route is on a distinguished road
4route's Avatar
definitely read what Faeylyn posted, maybe even memorize it ... because some dealerships will try to tell you that your warranty is void just so they can charge you more when in fact that part in question couldn't have been effected by the mod.
4route is offline   Reply With QuoteReply With Quote
Old 10-28-2004, 01:40 PM #5
Biff's Avatar
Biff Biff is offline
Biff is on a distinguished road
Biff's Avatar
I added a lift kit to the front of my runner, had to take it to the dealer for a wheel sensor problem. The stealer could not prove that my lift was at fault. So like 4route said read the above post, its your protection against the stealer.
Victor
08 FJ TT
94 FZJ80
Biff is offline   Reply With QuoteReply With Quote
Old 10-29-2004, 04:08 PM #6
Duc Hunter's Avatar
Duc Hunter Duc Hunter is offline
Duc Hunter is an unknown quantity at this point
Duc Hunter's Avatar
With another vehicle I got to know that law well. In 95% of cases when a dealer balks because of mods, mention the law by name and they will have an instant change of heart and do the work.
04 4Runner Limited V8, NV, SR, GY, RF, HP, P9, Z1, E5, XM Radio, BlueTooth Wireless, OME Lift 885/896, 285/70/17 (had 265/70's), SpiderTrax Spacers, K&N FIPK, Magnaflow exh, Shrock Bumper, Warn XD9k, Blitz 240 lights
http://www.toyota120.com/forum/showthread.php?t=2156
Duc Hunter is offline   Reply With QuoteReply With Quote
Old 10-29-2004, 06:30 PM #7
Thanks..
HI,
I just wanted to thank you all for the information....
It makes me feel a lot better about making a mod to my truck.
Thanks again,
Joe
Don't be fooled! Front lift spacers, diff drop kit, rear coils no easy task!!! Slippery24 3rd gen T4Rs 25 11-03-2009 11:47 PM
lift kit for '05 SE? t4r_se_n_wv 4th Gen T4Rs 1 11-03-2007 08:28 PM
What's the verdict on the factory XM kit? drake3 4th Gen T4Rs 13 07-26-2006 05:20 PM
Lift void warranty? okkin 4th Gen T4Rs 12 08-04-2005 08:02 AM
Factory Sport Bumper Kit Scout Av8er Engines / Suspension / Wheels / Tires / Audio / Accessories 13 04-07-2004 11:27 AM
