04-15-2010, 10:56 AM
Possible Problem with DAC Switch
I haven't used my DAC switch in probably one year at least. The other day it occurred to me that when I have my lights on, my Differential switch and my AC switch both illuminate orange, but my DAC switch doesn't. I can't remember if it's supposed to or not. I looked through my manual for a possible fuse to replace, but nothing was in there. It does show the green icon on my dash when I engage it, but is it supposed to illuminate as well??
04-15-2010, 12:32 PM
Yes it does illuminate. try checking the wiring underneath if you can, I thought mine had a blown fuse also and pulled the center plastic up and one of the install guys just had not plugged it back in.
2006 4Runner Sport V8 4WD Satoshi Grille, Magnaflow exhaust, K&N filter; Shrockworks bumper, Overland Warehouse 2.0 Radflo full kit, 33 inch Mud Grapplers on 20 inch Rockstars. HID Kit, Blacked out Headlight Housings, Tinted tail lights, LED license plate lights, LED running lights and turnsignals. De-badged all around. 2% tint all around with 30% all the way down windshield. Kenwood Double Din 7 inch headunit. 2 Alpine Type R 12" subs with 2 Alpine 500 watt Mono Amps and a 6 farad capacitor. All interior lights swapped for LED's. Train Horn mounted where spare tire was. WAR EAGLE!
04-15-2010, 02:19 PM
I opened it back up and there was a white 6-pin harness not connected. The blue harness that goes into the DAC switch IS CONNECTED. But, I cant figure out where the unconnected white harness is supposed to go. Any pictures would be nice too
04-15-2010, 03:33 PM
side question: I keep finding myself hitting this button accidentally. My understanding is we only should use it in a straight line and going down hill in extreme conditions so am I doing any damage by driving with it occasionally?
the location makes is so easy to hit accidentally when reaching for things in the little compartment behind it or the center console!
My Build Thread
2006 Grey Mica Limited 4wd, JBL, RCI Skids, FJ TT suspension, aFe stage 2 CAI + URD MAF cal, Sprint Booster, Cobra 75 CB, 17" MB Gunner6 wheels + 265/70 Cooper Discoverer AT3s, Poly Bushings, Rear Diff Breather Mod, Morimoto XB 4500k HID Lows, LEDs in and out, Husky Liners, Load Warrior.
04-15-2010, 03:43 PM
You won't do any harm since it only works in 4L.
2007 4Runner Sport V6 4WD Shadow Mica, Tint, Extended differential breather, Carbon filter removed, Bilstein 5100s - 0 setting with Old Man Emu 884s, ToyTec Superflex coils and 5100s rear, Dobinsons UCAs, P265/70/17 Michelin Defender LTX M/S, Spidertrax, Xtreme Phillips 4300K HIDs, ICON Sway Bar Relocation Blocks
Former 1999 4Runner Highlander V6 4WD Black
04-16-2010, 10:25 AM
Bump
Anybody? Autozone told me it could be a small bulb inside the switch that could have shorted. I really don't want to spend $30 at the dealership if it's an easy fix. Thanks for any help
04-16-2010, 10:31 AM
Oh yeah Autbond, I went to Auburn... just saw that's where you live. I live in Florence now though
04-16-2010, 11:11 AM
i had my center console apart the other day, and I also have a white connector not connected to anything. So I think that's normal.
As for the light in the switch, I don't think it's normally replaceable, it might be an LED not sure. I want to change the color of the light, and didn't see anything that could be removed. So I'm thinking there is an LED inside that you'll have to unsolder to replace. I haven't had a chance to do this yet, so not sure.
Check out my 2004 4Runner Audio upgrade.
04-16-2010, 11:16 AM
If it's anything like the AC 115 switch which I believe it would be, the bulbs are replaceable.
04-16-2010, 11:35 AM
Sweet, I went to UNA for my first 2 years of school
04-16-2010, 01:20 PM
Think I found a solution... I haven't opened my center console back up and checked the bulb yet, but I think that's what it is. Here is a thread explaining how to replace bulbs in your switches. Thanks for the help guys.
05 Illuminated buttons - Toyota 120 Platforms Forum
04-16-2010, 03:13 PM
Well from taking it apart I realized it's a clear incandescent bulb T-1 style (3mm). The color of the illumination is from a rubber covering that slides over the bulb, which in our case is ORANGE. So i guess by replacing that rubber boot, you can make your switches light up any color you want.
04-16-2010, 03:38 PM
The white connector not connected to anything is for the optional cigarette lighter/ extra outlet system.
03 V8 T4R Limited Galatic Grey Mica :
K&N Cold Air Intake
Hard-wired Radar detector
XM Satellite Radio
Kenwood DNX5120
20% Tint / Vent Visors
10K HID Fogs / 6K HID Lows / SilverStar Ultra HIs
04-16-2010, 03:43 PM
ah you're right, I was thinking of the seat heater switches. Anyone know how to open those up? I want to put LEDs in those too.
04-30-2010, 10:58 PM
If you detach the switch from the harness, all you do is unscrew the bulb with a flathead screwdriver and it pops right out
2003 4Runner SR5 V8 4WD
HID Retrofit Lexus RX-AFS, Build Thread
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
