Old 04-15-2010, 10:56 AM #1
Jawood's Avatar
Jawood Jawood is offline
Jawood is on a distinguished road
Jawood's Avatar
Possible Problem with DAC Switch
I haven't used my DAC switch in probably one year at least. The other day it occurred to me that when I have my lights on, my Differential switch and my AC switch both illuminate orange, but my DAC switch doesn't. I can't remember if it's supposed to or not. I looked through my manual for a possible fuse to replace, but nothing was in there. It does show the green icon on my dash when I engage it, but is it supposed to illuminate as well??
Jawood is offline   Reply With QuoteReply With Quote
Old 04-15-2010, 12:32 PM #2
Autbond's Avatar
Autbond Autbond is offline
Autbond is on a distinguished road
Autbond's Avatar
Yes it does illuminate. try checking the wiring underneath if you can, I thought mine had a blown fuse also and pulled the center plastic up and one of the install guys just had not plugged it back in.
2006 4Runner Sport V8 4WD Satoshi Grille, Magnaflow exhaust, K&N filter; Shrockworks bumper, Overland Warehouse 2.0 Radflo full kit, 33 inch Mud Grapplers on 20 inch Rockstars. HID Kit, Blacked out Headlight Housings, Tinted tail lights, LED license plate lights, LED running lights and turnsignals. De-badged all around. 2% tint all around with 30% all the way down windshield. Kenwood Double Din 7 inch headunit. 2 Alpine Type R 12" subs with 2 Alpine 500 watt Mono Amps and a 6 farad capacitor. All interior lights swapped for LED's. Train Horn mounted where spare tire was. WAR EAGLE!
Autbond is offline   Reply With QuoteReply With Quote
Old 04-15-2010, 02:19 PM #3
Jawood's Avatar
Jawood's Avatar
I opened it back up and there was a white 6-pin harness not connected. The blue harness that goes into the DAC switch IS CONNECTED. But, I cant figure out where the unconnected white harness is supposed to go. Any pictures would be nice too
Old 04-15-2010, 03:33 PM #4
jpless's Avatar
jpless jpless is offline
jpless is on a distinguished road
jpless's Avatar
side question: I keep finding myself hitting this button accidentally. My understanding is we only should use it in a straight line and going down hill in extreme conditions so am I doing any damage by driving with it occasionally?
the location makes is so easy to hit accidentally when reaching for things in the little compartment behind it or the center console!
My Build Thread
2006 Grey Mica Limited 4wd, JBL, Redline detector, RCI Skids, FJ TT suspension, aFe stage 2 CAI + URD MAF cal, Cobra 75 CB, 17" MB Gunner6 wheels + 265/70 Cooper Discoverer AT3s, Poly Bushings, Rear Diff Breather Mod, Morimoto XB 4500k HID Lows, LEDs in and out, DIY Blackout HL's and emblems, Husky Liners, Load Warrior.
jpless is offline   Reply With QuoteReply With Quote
Old 04-15-2010, 03:43 PM #5
martini's Avatar
martini martini is offline
martini is on a distinguished road
martini's Avatar
You won't do any harm since it only works in 4L.
2007 4Runner Sport V6 4WD Shadow Mica, Tint, Extended differential breather, Carbon filter removed, Bilstein 5100s - 0 setting with Old Man Emu 884s, ToyTec Superflex coils and 5100s rear, SPC Light Racing UCAs, P265/70/17 Michelin Defender LTX M/S, Spidertrax, Xtreme Phillips 4300K HIDs, ICON Sway Bar Relocation Blocks
Former 1999 4Runner Highlander V6 4WD Black
martini is offline   Reply With QuoteReply With Quote
Old 04-16-2010, 10:25 AM #6
Jawood's Avatar
Jawood's Avatar
Bump
Anybody? Autozone told me it could be a small bulb inside the switch that could have shorted. I really don't want to spend $30 at the dealership if it's an easy fix. Thanks for any help
Old 04-16-2010, 10:31 AM #7
Jawood's Avatar
Jawood's Avatar
Oh yeah Autbond, I went to Auburn... just saw that's where you live. I live in Florence now though
Old 04-16-2010, 11:11 AM #8
cdoyle's Avatar
cdoyle cdoyle is offline
cdoyle is on a distinguished road
cdoyle's Avatar
i had my center console apart the other day, and I also have a white connector not connected to anything. So I think that's normal.
As for the light in the switch, I don't think it's normally replaceable, it might be an LED not sure. I want to change the color of the light, and didn't see anything that could be removed. So I'm thinking there is an LED inside that you'll have to unsolder to replace. I haven't had a chance to do this yet, so not sure.
2004 Titanium Limited V8 Pics
Car Audio Central's own Mafia style RPG. Sign up for free and let Chrisfromwa know you're from 4Runner.org. I'll set you up with cash and weapons to get started.
cdoyle is offline   Reply With QuoteReply With Quote
Old 04-16-2010, 11:16 AM #9
J.A.'s Avatar
J.A. J.A. is offline
J.A. will become famous soon enough
J.A.'s Avatar
If it's anything like the AC 115 switch which I believe it would be, the bulbs are replaceable.
J.A. is offline   Reply With QuoteReply With Quote
Old 04-16-2010, 11:35 AM #10
Autbond's Avatar
Autbond's Avatar
Sweet, I went to UNA for my first 2 years of school
Old 04-16-2010, 01:20 PM #11
Jawood's Avatar
Jawood's Avatar
Think I found a solution... I haven't opened my center console back up and checked the bulb yet, but I think that's what it is. Here is a thread explaining how to replace bulbs in your switches. Thanks for the help guys.
05 Illuminated buttons - Toyota 120 Platforms Forum
Old 04-16-2010, 03:13 PM #12
Jawood's Avatar
Jawood's Avatar
Well from taking it apart I realized it's a clear incandescent bulb T-1 style (3mm). The color of the illumination is from a rubber covering that slides over the bulb, which in our case is ORANGE. So i guess by replacing that rubber boot, you can make your switches light up any color you want.
Old 04-16-2010, 03:38 PM #13
Cape 4RUNNER's Avatar
Cape 4RUNNER Cape 4RUNNER is offline
Cape 4RUNNER is on a distinguished road
The white connector not connected to anything is for the optional cigarette lighter/ extra outlet system.
03 V8 T4R Limited Galatic Grey Mica :
K&N Cold Air Intake
Hard-wired Radar detector
XM Satellite Radio
Kenwood DNX5120
20% Tint / Vent Visors
10K HID Fogs / 6K HID Lows / SilverStar Ultra HIs
Cape 4RUNNER is offline   Reply With QuoteReply With Quote
Old 04-16-2010, 03:43 PM #14
cdoyle's Avatar
cdoyle's Avatar
ah you're right, I was thinking of the seat heater switches. Anyone know how to open those up? I want to put LEDs in those too.
Old 04-30-2010, 10:58 PM #15
Jawood's Avatar
Jawood's Avatar
If you detach the switch from the harness, all you do is unscrew the bulb with a flathead screwdriver and it pops right out
2003 4Runner SR5 V8 4WD
HID Retrofit Lexus RX-AFS, Build Thread
dac , illumination , light , switch
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
