Old 12-02-2004, 01:43 PM #16
Cliff s Cliff s is offline
Cliff s is an unknown quantity at this point
If it isn't the Steering wheel bind problem, then you have a defective lock. There are small springs that press down the pins in the lock and if one of them is defective the lock will be intermittent.
The dealer needs to replace the lock.
Cliff s
Cliff s is offline   Reply With QuoteReply With Quote
Old 12-02-2004, 04:57 PM #17
ToyDiehard's Avatar
ToyDiehard ToyDiehard is offline
ToyDiehard is an unknown quantity at this point
ToyDiehard's Avatar
It's been fine for about 3 weeks now but I'm ready with an extra key to try this time. I think the Runner knows I'm ready. She'll wait, she'll stock me until she knows that I don't have the extra key on hand .... then she'll strike.
That's how it normally happens. Murpheys law.
2004 Sport Edition 4WD V6 Galactic Gray
Moonroof
Rear spoiler
Daytime running lights
Double Decker Cargo System
Homelink
T4R.ORG decals
SilverStars
OBX Pedals
All Weather Mats
Front End Mask
No More Crappy Dunlop AT20 tires
Bridgestone Revo's 265/70/17 .....Sweeeeeeet!
2000 Solara
2007 Solara Sport
1993 4Runner SR5 V6 (bought new, 165,000 miles, Sold after 11 years)
ToyDiehard is offline   Reply With QuoteReply With Quote
Old 04-05-2011, 01:29 AM #18
Keepmy4runnin Keepmy4runnin is offline
Keepmy4runnin is on a distinguished road
Problems with your ignition turning
Originally Posted by ToyDiehard View Post
Have you ever gotten into your 4Runner, go to turn the ignition key, and it just won't turn? (Imagine installing someone elses key into your ignition, that's what it feels like). I don't try to force it. Instead, I remove the key a couple times and try again. A few tries later it finially turns easy and starts.
I've had my 04 Runner for about 6 weeks now and have experienced this same problem only twice, but Im afraid of being stranded somewhere. Anyone else ever experience this same problem?
You need to pull your ignition cylinder out and have the tumblers replaced. I have a '99 4runner that had to have this done. Some threads will tell you to replace it with a new one or or a used one and have it keyed. I took mine out by myself in about 5 mins, ran it down to a locksmith and in about 20 mins he hooked me up with pretty much a brand new ignition cylinder. Works better than new. The problem with the cylinders is that they use a split tumbler system, one half will move and the other sticks. That's why you have to run your key in and out 20 times before it takes.
Keepmy4runnin is offline   Reply With QuoteReply With Quote
Old 04-05-2011, 09:07 PM #19
KBToys KBToys is offline
KBToys is on a distinguished road
I had this problem in my 99 tacoma, it kept getting worse till finally I could not turn the key. Had to call a lock smith and he came out took the ignition out and replaced the tumblers.
KBToys is offline   Reply With QuoteReply With Quote
Old 04-06-2011, 11:20 AM #20
rockwall's Avatar
rockwall rockwall is offline
rockwall is on a distinguished road
MY GARAGE
rockwall's Avatar
MY GARAGE
I agree that this issue is common on foreign vehicles, especially Japanese. My Nissan Altima and Pathfinders both did it. It happens once in a while on my 4Runner and the steering wheel lock is the culprit.
2003 4Runner Limited V8 4WD;Pacific Blue Metallic; Cornfed 3/2 Lift; Spidertrax Wheel Spacers;Magnaflow Cat-Back Exhaust; Nitto Terra Grapplers 265/70/17; aFe Pro-Dry S Air Filter; Philips 4300 Xtreme HID Low-Beams; PIAA 540 Plasma Ion Fogs; HIR Hi-Beams; HIR main fogs; Man-A-Fre Front Skid; Alpine Head Unit w/I-pod Interface; Alpine Type-R 10" Sub; Kenwood 1000W Amp; JBL 10 speaker system; Steelcraft Bull Bar; Go Rhino Hitch Step; PIAA Super Silicone Wipers; TRD Radiator and Oil Caps; Brembo brake pads & rotors; TRD Carbon Fiber and iForceV8 Emblems on Hatch; all LED interior, Running Board, Reverse and License Plate bulb replacements; Weather Tech mats and Cargo Liner; Blitz Hybrid Cabin A/C Filter
rockwall is offline   Reply With QuoteReply With Quote
Old 11-01-2011, 04:47 PM #21
4wdGunner's Avatar
4wdGunner 4wdGunner is offline
4wdGunner is on a distinguished road
4wdGunner's Avatar
I know it's a 4th gen thread, but this happen to my 98 4runner today. After about 45 mins of trying, wiggling, turning the steering wheel, spraying some pb blaster in it, I gave up and got a ride to Toyota and got a new key made. Got home, new key worked perfectly!
98 Limited 4WD
4wdGunner is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 03:28 PM #22
kyle_pc_75 kyle_pc_75 is offline
kyle_pc_75 is on a distinguished road
This just happened to me. 2005, 220,000 miles, so I'm not surprised. I have a spare with no transponder. It unlocks the door flawlessly (both keys do), but the ignition cylinder won't turn even with the transponder key taped to the cylinder. It worked fine last time I drove it a week ago. I know it's not the steering wheel lock as it wasn't locked until I fidgeted around with it so much that I turned it hard enough to lock it. I can feel the steering lock disengage when I pull hard to the left, but the cylinder still won't turn.
So now what? I can't pull the cylinder without a key that will turn the igntion to ACC. Is a locksmith my only option?
2005 V8 4Runner
1" Toytec body lift, FJ Cruiser stock springs front and rear, Bilstein 5100 front struts, 1.5" rear coil spacers, Total Chaos front UCA's, Uinta Metal Fab custom built front bumper, VHF Radio for comms
kyle_pc_75 is offline   Reply With QuoteReply With Quote
Old 01-12-2019, 06:24 PM #23
lightfreak lightfreak is offline
lightfreak will become famous soon enough
MY GARAGE
MY GARAGE
Spray dielectric lubricant into the keyhole, and give it a few minutes to penetrate. Tiny bits of crap builds up in there over many years and gradually hardens. Try that before towing it.
2004 4Runner Limited V6 4WD
346,000 Km
Titanium Metallic
Other Vehicles: '17 Acura TLX SH-AWD Tech, '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 02-03-2019, 06:55 PM #24
soundmanlpte soundmanlpte is offline
soundmanlpte is on a distinguished road
I had this problem. It sucked. For whatever reason, if I leaned over into the passenger seat and turned the key with my left hand, it worked. Something about the pressure on it that way.
To fix it: take it to a great locksmith. Spent maybe $100-$150 and itís worked ever since. That was a few years back.
98 4Runner SR5 V6 240k
soundmanlpte is offline   Reply With QuoteReply With Quote
Old 02-05-2019, 10:37 AM #25
Boort's Avatar
Boort Boort is offline
Boort is on a distinguished road
Boort's Avatar
Not an issue on my 4Runner, but my 97 Tacoma's been doing this off and on for a couple of years. Most likely the key, tumbler pins in the ignition, or both have worn due to the key jiggling in the ignition over the years. I had an old spare that was seldom used which I had another key key made from that helped for a while but time is catching up on that key now.
I've gotten to a point that when the keys goes in I can generally feel if it's not going to turn. There is a little hitch on the way in. if you don't want to change out the ignition switch and deal with 2 keys you'll get used to feeling for it.
Boort
-- 1997 Tacoma v6 Std Cab
-- 2006 4Runner v8
Boort is offline   Reply With QuoteReply With Quote
Old 02-27-2019, 10:12 PM #26
Pulling the door cylinder and having them make a key off that worked. Now just to take it back and have a transponder key made. Thanks guys!
2005 V8 4Runner
Old 02-28-2019, 03:22 PM #27
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR will become famous soon enough
MY GARAGE
Real Name: Michael
MY GARAGE
You can program these keys yourself. Very easy to do. I bought 2 blanks off amazon and had them cut at lowes for free and then programmed them out in the parking lot. Took me <30 mins and I only spent 25$ on the 2 keys combined. Also to the people who were talking about it being an issue with the transponder...I don't believe that is the case. For example, if you had a key cut, but not yet programmed, it will fit into the slot and you will be able to attempt starting but it will just crank and not turn over.
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Key - keyhole (ignition) locks up - won't turn apwdweb 3rd gen T4Rs 64 05-15-2018 12:32 AM
Key won't turn. proudrunner 3rd gen T4Rs 19 11-02-2011 03:50 PM
My key won't turn in the ignition Tanner Maintenance/Detailing 16 09-15-2009 08:32 PM
Key stuck in ignition 98 4runner knockerjoe Maintenance/Detailing 4 02-27-2006 05:45 PM
Help! I keep hitting the 4 wheel drive dial when I turn the ignition key! rhlitt 4th Gen T4Rs 12 04-30-2004 10:31 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
