05-24-2010, 08:45 PM
Stiffer rear springs?
I'm looking for some stiffer springs for the rear for towing. Everything I tow makes the rear sag like crazy...is the 4runner known for really soft springs? I had a 2000 Limited 4unner and had no sagging issues at all, which made me think the PO upgraded the springs. Can someone point me in the right direction? My truck has XREAS if that matters...
Thanks!
2007 Limited V8 w/XREAS/Self Levelling Rear Air
05-24-2010, 09:24 PM
Super Moderator
Super Moderator
If you want springs with little or no lift just stiffer the FJC rear springs will do it. Perhaps a better option would be Firestone or Airlift rear airbag system. The rear airbags are nice, cheap and do a good job of compensating for tongue weight.
Now for all the obvious questions: Is the trailer balanced right? Is it a camp trailer or something that would benefit from a WDH setup?
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
05-24-2010, 09:30 PM
If it drives nice the rest of the time you're not towing, then airbags are probably the best choice. Won't really affect ride or handling but can air up when needed. A weight distributing hitch may be needed as mentioned by cj3, depending on what you are towing.
'04 V8 T4R Limited Pacific Blue Metallic
Xreas removed, front FJ springs, Bilsteins all around, Toytec 1/2" spacer, Spidertrax, BFG AT 265/70/17, Curt 13445 hitch
05-24-2010, 11:07 PM
I tow our 15' foot camper, which isn't a big deal, but when I tow my girlfriends 16' horse trailer with one horse in it, it sags quite a bit. She nose loads the horse if there is only one so all the weight goes on the tongue. What are airbags worth? Do you have a link? How difficult are they to install with the switch/compressor?
05-25-2010, 08:24 AM
Airbags alone are about $150 and install is easy. Add about another $200 if you want the compressor with it. I don't have a link but many on here have done it so a quick search should get results.
Keep in mind the bags will help sag but will not distribute weight to the front axles for better control. The tongue weight of that horse trailer probably exceeds the 500lb limit of the stock hitch as well unless you have the upgraded frame mount hitch (which you may be exceeding as well)
05-25-2010, 09:23 AM
05-25-2010, 09:30 PM
i have the airlift bags on my 04 sport and their great . keep 5psi in em unloaded and air em up when u need them.they've been in for 3 yrs now and still no leaks. easy to install also.
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
05-25-2010, 09:35 PM
Super Moderator
Super Moderator
Hit the Airlift link in my signature for more details.
Chris
