Old 06-03-2010, 10:47 AM #1
grover grover is offline
grover is on a distinguished road
sluggish acceleration
got an oil change a few days ago and since then, i've noticed my 2005 4runner is sluggish on acceleration. when pressing the gas, it starts pretty sluggish most of the time and will then "take off" after a few seconds or so.
any ideas what this could be? need help fast, as i'm supposed to take it on a road trip this weekend. thanks!
grover is offline   Reply With QuoteReply With Quote
Old 06-03-2010, 11:05 AM #2
kylebacc kylebacc is offline
kylebacc is on a distinguished road
what oil did you get put in? I wonder if the weight of the oil is too high, if that would cause it?
Kyle
2006 GX470 Sport
kylebacc is offline   Reply With QuoteReply With Quote
Old 06-03-2010, 01:34 PM #3
Nuke's Avatar
Nuke Nuke is offline
Nuke will become famous soon enough
Nuke's Avatar
This sounds like a coincidence with something else besides the oil. A thicker weight oil shouldn't cause a noticeable change unless it was substantially thicker. Also, you describe "it starts pretty sluggish most of the time and will then "take off" after a few seconds or so" which leads me to believe this is a hesitation problem where the car starts off sluggish but then goes as normal (if I read you correctly) which wouldn't be oil related.
Try a fresh tank of fuel from a different station. Perhaps it's time to run some good fuel system cleaner (Techron, SeaFoam) thru a tank.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
Nuke is offline   Reply With QuoteReply With Quote
Old 06-03-2010, 01:46 PM #4
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
I agree with Kyle and Rick. Check the oil level and make sure it's not radically over-full and then try some fresh gas.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 06-03-2010, 02:07 PM #5
thanks nuke. you read it correctly.
i'm thinking the oil change was a coincidence too, but will check the level as CJ3Flyr recommended.
took it to a mechanic real quick and, of course, it wasn't doing it when he drove, but he thinks it may be some bad gasoline also.
Old 06-07-2010, 04:53 PM #6
well, looks like the problem isn't/wasn't bad gas. ran that tank out and filled up with some premium and i still have the problem. it actually felt like it was going to stall out on me this afternoon when starting from a complete stop. seems to be pretty intermittent though. any thoughts? thanks.
Old 06-07-2010, 05:00 PM #7
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
I am assuming the air filter is fresh. How many miles? My '07 w/67k was READY for a Throttle Body cleaning. Are you still on original spark plugs? Did you try an ECM reset?
http://www.toyota-4runner.org/mainte...ning-pics.html Read the whole thread, it has a link on how to reset the ECM.
Old 06-07-2010, 11:31 PM #8
Aquabear's Avatar
Aquabear Aquabear is offline
Aquabear is on a distinguished road
Aquabear's Avatar
Good prior advice above. I did put too heavy of an oil in my old rav4 and it did similar to what you said. I'd say go back and have the guy who changed the oil do it again and maybe watch him use the correct weight- it coulda been a new guy who screwed up the oil weight.
If that dosen't work-
How many miles do you have? Time for a tune up? Do the step by step items- view/change air filter? spark plugs? maybe a bottle of fuel injector cleaner to clean out injectors? Uhhh Pray???
Aquabear is offline   Reply With QuoteReply With Quote
Old 06-08-2010, 10:43 AM #9
thanks guys. air filter is very new. not sure about the spark plugs. i got the 4runner 7 months ago. i'll check the plugs and put in some SeaFoam.
CJ3Flyr, it's a 2005 with about 67K miles on it. is resetting the ECM the same as pulling the fuse for the EFI relay? and do i need to disconnect the battery or just make sure the truck is off before pulling the fuses?
thanks again!
Old 06-08-2010, 10:50 AM #10
CJ3Flyr's Avatar
Super Moderator
Super Moderator
CJ3Flyr's Avatar
CJ3Flyr, it's a 2005 with about 67K miles on it. is resetting the ECM the same as pulling the fuse for the EFI relay? Yes. and do i need to disconnect the battery No. or just make sure the truck is off before pulling the fuses? Correct.
thanks again!
This may add clarity: http://www.toyota-4runner.org/560825-post4.html
I thought of something else: Do you have 44psi tires? Were you running them in the high 30's/low 40's? Did the guy at the oil change place read 32psi on the door jam and let air out???
Old 06-08-2010, 01:22 PM #11
great, thanks for the clarification. i do not have 44psi tires, but will check them to make sure they're still in the 32-35psi range.
i'll try pulling the fuses and putting in some SeaFoam to see if that helps.
Old 06-09-2010, 09:57 AM #12
okay, probably a dumb question, but how should i use the SeaFoam? seems to be a lot of different methods online.
truck was REALLY sluggish this morning and seemed like it was about to stall out when trying to pull out of my neighborhood. seems to get better as i drive it though.
Old 06-09-2010, 10:17 AM #13
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
try cleaning or replacing the MAF sensor, a dirty one can have similar effects including stalling.
chaz is offline   Reply With QuoteReply With Quote
Old 06-09-2010, 08:37 PM #14
Goatdog Goatdog is offline
Goatdog is on a distinguished road
Crawl up under there and check the transmission fluid. If they drained SOME of the wrong fluid (this has happened to 4runners before) before they caught their mistake, it could cause sluggishness on acceleration. This would be very obvious if the trans fluid was completely drained but could be intermittent on acceleration if it is just pretty low.
Just a thought. I have seen this exact problem with my friends 05 V8. 2 qts low from the Jiffy Lube. They denied it at first but the worker fessed up when asked. Guess he didn't know how to add any with no tranny dipstick available. We added 2 qts and it was fine.
My friend now changes his own oil (as I always have).
2004 4Runner V8 SR5 4WD - Cornfed 3/2, Spidertrax, Nitto Terra Grappler 265/70/17, Dimpled/Slotted Rotors with Ceramic Pads, Borla Duals, K&N, Sure Power Dual Battery with Optima Red and Blue Tops, Edgestar 43qt Refrigerator/Freezer, 750w/300w Inverters, eight 12V Outlets, PIAA 520's, Rear Fogs, Silverstar Ultra (Low/High/Fogs), Blue V-LEDS, Hunter Light Bar, Yakima Load Warrior w/ext, Hitch Bar, Kenwood 5140DNX Head Unit with Garmin GPS, Rearview Camera, iPod, DVD, Bluetooth, etc, Rear DVD/Gaming Entertainment System, Garmin 400T w/topo maps, Samsung Fascinate (Android), Custom Sleeper/Storage with Tier III Survival Kit, Tier II Bag, Recovery Gear, Scan Gauge II Monitor, 20% Tint, Yaesu FT-2900R 2M Radio with Comet Antenna (KJ4VVA), Cobra 19 CB Radio with Wilson K30 and PA, Weathertech Floor Mats, Wheelskins, Iggees Seat Covers, and a Guinness Bottle Opener.
Goatdog is offline   Reply With QuoteReply With Quote
Old 06-09-2010, 10:27 PM #15
DRC DRC is offline
DRC is on a distinguished road
DRC DRC is offline
Strangely enough I may be experiencing a similar issues. It’s nowhere near what you have described but I noticed, well the butt-dyno tells me, that my v6 seems a tad sluggish after switching from 5w-30 dyno to 0w-30 Mobile 1 synthetic. It’s subtle and I am not sure if there really is a performance issue because the engine is running very smooth and normally when I jump on it I would hear it roar to life and take off, but now it’s so quite that it may only seem to be sluggish because I am not hearing the engine noise. But oddly enough it seems a pinch slower in low end acceleration. I have also read that too heavy of an oil in a 4 banger can cause this issue. I would not imagine a v8 would have such an issue but who knows. Maybe there is something to the oil change. Maybe a bad filter or wrong oil.
DRC is offline   Reply With QuoteReply With Quote
