Old 06-16-2010, 10:12 PM #1
chipski chipski is offline
chipski is on a distinguished road
newbie with ball mount ???
Just picked up an 07 v8 a couple of weeks ago. Got to say I'm lovin' it.
My question is will any ball mount fit? I'm planning on towing a car trailer- about 16' tandem axle. Total weight should be around 4k. Can the ball mount be straight or will I need some drop in it? I have searched some and it seems like most mounts will fit.
TIA
chipski is offline   Reply With QuoteReply With Quote
Old 06-16-2010, 10:55 PM #2
kylebacc kylebacc is offline
kylebacc is on a distinguished road
I think anything with a 2" shaft will fit. The ball size does not matter, just get one that matches the trailer. I would go with a slight drop, maybe 2" someone else who tows a lot should chime in and let you know what the best would be. Ideally, you want the trailer as level as possible.
Kyle
2006 GX470 Sport
kylebacc is offline   Reply With QuoteReply With Quote
Old 06-17-2010, 09:14 AM #3
Would I also need a brake controller system? I'll probably get a trailer with electric brakes.
Old 06-17-2010, 09:19 AM #4
I think that's really up to you. If I had the option I would pretty much always go with a trailer with brakes over a trailer without. Your truck should have come with a harness/adapter and I think the owners manual will tell you where to plug it into/how to wire it to a controller.
Kyle
2006 GX470 Sport
Old 06-17-2010, 09:26 AM #5
I'm with you- I will get brakes on the trailer.
I'll check for the harness/adapter- this was a used truck, so I'm not sure what I have. If I don't have one- I guess I need to go to the stealer for one?
Old 06-17-2010, 09:35 AM #6
Well check out the trailer shop first, maybe they have a cheap alternative to the dealer harness. Get prices at both places before you buy And if you have it, it'll probably be in the glove box or one of the trunk compartments. One last place it could be is plugged in where it belongs (if the previous owner ever used it). Take a look around, and if you don't find it, go price it. I've never towed anything more than a couple waverunners with mine, so hopefully someone who has will give their input.
Kyle
2006 GX470 Sport
Old 06-17-2010, 01:02 PM #7
Kwik8608's Avatar
Kwik8608 Kwik8608 is offline
Kwik8608 is an unknown quantity at this point
Kwik8608's Avatar
I tow a 20 foot Mastercraft X2 that weighs in around 4,500 with trailer, boat, and gas. I use a 2 inch drop and tow just fine. Also, it has hydrolic brakes. It'd be nice to have electric, but the hydrolic brakes for what my needs and uses are is not bad.
'08 Toyota SR5 4Runner
- 4WD V6 4.0L
- Black
- Bug Deflector - Valor Exhaust Tip - Toyota 4Runner All Weather Mats (Front and Rear) - Husky Cargo Liner - Black Westin Safari Bar - 30% Tint
Kwik8608 is offline   Reply With QuoteReply With Quote
Old 06-18-2010, 03:23 AM #8
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
Any 2" ball mount should fit into the factory hitch receiver, but you have to be careful about the length of the tube. Because of the placement of the spare, in some cases, the longer ball mount tubes can hit the spare and not allow the hitch pin to line up. As for the amount of drop, that is determined by the height of the tow vehicle, and the trailer towed. Idealy, you want the trailer frame to ride as level as possible when towing. This means chosing the correct amount of drop, or rise in the ball mount to result in a level trailer when hooked up. It is easy to figure out. First, with the trailer sitting on level ground, raise, or lower the tongue, until the frame is as close to level as possible. Then measure from the bottom of the socket where the hitch ball fits into, to the ground. Then, with the tow vehicle also on level ground, measure from the inside top edge of the hitch receiver square opening to the ground. The difference between the two measurements is the amount you have to make up with either a drop, or rise on the ball mount. ie, if the trailer measurement is 18", and the vehicle hitch tube measurement is 22", you need a 4" drop on the ball mount to make the trailer ride level when connected. If the trailer measurement is 22", and the vehicle hitch tube is 18", then you need a 4" rise ball mount. FYI, the amount of drop, or rise on a particular ball mount is measured from the top surface of the square tube to the top of the surface where the ball bolts on to the mount. Because the drop, or rise is measured from the top surface of the ball mount tube, a ball mount that has a 4" drop, when inverted, will now have a 2" rise.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 10:17 PM #9
CameronMagee's Avatar
CameronMagee CameronMagee is offline
CameronMagee is on a distinguished road
Curious what you went with and if you rotate it up/down or keep it the same?
2008 Toyota 4Runner SR5 4WD | V6 | 32,727 Odometer | Grey/Grey
CameronMagee is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 11:24 AM #10
importman importman is offline
Real Name: Danny
importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough importman is a jewel in the rough
Real Name: Danny
Do you realize the thread you replied to is over ten years old? Probably not gonna get a response.
Ironman 3/2 lift kit, JBA high caster upper control arms, Upgraded to Sport Front Cardone Calipers with Brembo Rotors and Akebono Pads, Added Spoiler, Sony XAV-AX1000 with Apple Carplay, USB Jack, Backup Camera, General Grabber ATX / 275/70/17, Auto Dimming Mirror with Compass and Homelink, Map Light Mod, Tekonsha 90160 Trailer Brake Controller, Recoil SL1708 Sub, Sealight LED Headlamps, K&N drop in air filter, Smittybilt XRC 9500 Winch, Weathertech floor mats.
importman is offline   Reply With QuoteReply With Quote
Old 10-20-2020, 11:45 AM #11
y=mx+b's Avatar
y=mx+b y=mx+b is offline
y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of y=mx+b has much to be proud of
y=mx+b's Avatar
I think techwrench has a good method for determining the height as described above. I've only towed uhaul trailers, but flipping a 2" drop hitch to become a .5" rise was the best for my stock 4runner pulling the uhaul trailer
y=mx+b is offline   Reply With QuoteReply With Quote
