the 5100s are adjustable & will give ya up to 2.5 up front so u really dont need a spacer there, unless u want more, then get a 1in. spacer for the rear, you'll get a lift + better ride with that than spacers alone, total cost about about 450, then whatever the labor & alignment is. rear coils instead of spacers will be more $, a complete OME setup will run about 760, any other brand of complete setup will be more, just new coils frt & rear for lift will be 400 ,but u use ur stock shocks, u could also hunt down an FJ setup with the bilsteins, that alone will give ya 1 in. up front, maybe 1/2 outback, then use spacers for more lift. thats a short rundown, so the cheapest route is just spacers, for about 1/2 the cost of the billies. personally, id get the bilstein 5100, & reuse the stock springs. its really how much u want/can spend. goodluck
