Originally Posted by jbrown16
I was in the same boat as you. Ordered a key off Amazon, plus two extra fobs. Took the uncut key to a little local locksmith shop and they took it, no hesitation. Four minutes and ten dollars later -- all set.
Total spent on two fobs and a key was probably $55 or so.
Yeah I just went with a small local locksmith shop. It's just hard because you search 'locksmith' on the internet for your local area and all the comes up are these horrible places that use kiosks where it scans your key and then they mail you the key 3 days later. Finally I tracked down a local guy with a small shop.
My master key was so messed up (he said) that he needed to take the lock out of my door to properly cut the two keys. He popped it out with a screwdriver (rubber cover and a couple of screws) then made the keys. He charged me like $16.
I programmed the keys usings the 5 inserts, 6 door open/closing method. One key was too screwed up from his cutting and just didn't work. The other key seemed to just let the ignition try and try but wouldn't turn over the car. I did the 5/6 programming method again on that key and it now works. These aren't genuine Toyota keys, they just look like generic blanks, so I was worried.
So I have 1 extra key now which is cool. It cost $15 for 2 keys from Amazon and $16 for cutting them. And probably a lot of gas because I had to drive to Lowes, Wal-mart, and Home Depot and get turned down.
