08-06-2010, 03:37 PM
Rear Window and Wiper stopped working
The rear window and rear wiper stopped working. I tried to find the fuse in both the interior fuse compartment (left of steering wheel) and the fuse box under the hood. I can't find anything marked for the rear window or wiper, front wipers are clearly marked. Where should I look for the fuse? Does it have its own strange designation? Thanks
08-06-2010, 03:50 PM
According to my Factory Manual, when the rear wiper and washer system does not operate, then check the ALT, AMI and ECU-IG fuses.
These fuses are found in the fuse box in the engine bay under the hood.
Summer: Michelin Defender LTX 245/60R20 on OEM Limited 20" rims / Winter: Toyo Observe GSi-5 265/70R17 on 2018 TRD Off-Road 17" rims.
08-07-2010, 12:50 AM
Make sure the window is all the way up...can be open just a crack without seeing it and will make the wiper inoperable.
'97 4x4 SR5--traded in for '03 4x4 Limited--traded in for current truck:
Shadow Mica '07 V8 Limited 4x4 with Nav
Heartland Edge M-18 travel trailer
08-07-2010, 07:16 AM
And also check the window lock button on the driver's door. If the passenger window controls are locked, the switch on the dash for the rear window also doesn't work.
2006 Limited V8 4x4, Shadow Mica/Stone
08-07-2010, 09:26 AM
All good suggestions; however, the rear wiper fluid is flowing and the passenger windows are working. I haven't checked the fuses that "Bossman" suggested yet.
I'm hoping that's the answer.
I traded my 96 Limited for a beautiful 03 V8 AWD
08-07-2010, 12:01 PM
Still can't find fuse
Hi folks, I still can't find the fuse for the rear window. There is a fuse marked RR WSH but it looks OK. The rear wiper was engaged when the window and wiper lost power so it is about 2 inches from resting in its cradle. I checked the ECU-IG fuse it looked OK. I couldn't find fuse purely marked as ALT or AMI.
I appreciate the help.
08-07-2010, 12:09 PM
08-07-2010, 12:51 PM
Fixed
Hi Folks,
Thanks for all the suggestions. Chaz put me onto "normalizing" the rear window, which did the trick.
wperk
08-07-2010, 05:20 PM
I'm sure the OM would have helped, too.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
08-14-2018, 06:15 PM
Nice necro, bro
New around here, but I believe the preferred method is posting in established threads rather than starting new ones...
2003 Limited, 150k, V8 4wd
Situation
I have lost power to my rear window: window will not go down with fob or dash button, window lock button is not depressed, and rear windshield wiper does not respond. I tried the "hold the dash button up 15sec then down 15sec" without any change. I've called the fuse box several less than flattering names, without improvement of the situation.
Background
I'm admittedly a novice on auto repairs, but I understand the concept of replacing fuses (having blown one when replacing my interiors with LEDs.)
Assesment
Could this be the source of the issue? All fuses that I have pulled whose descriptions even mildly reference rear, power, or window, look to be in tact. If this is a fusaroni, which one?
Computer halp!!
08-16-2018, 07:33 AM
Bump.
No suggestions?
08-16-2018, 08:13 AM
08-16-2018, 12:52 PM
Originally Posted by Bossman
I’ve read through this thread and, as mentioned in my post, tried both solutions recommended: key on 15sec up 15 sec down start vehicle, and the window lock button.
I apologize if I wasn’t clear enough with my post that I had tried these already.
08-16-2018, 12:57 PM
I’ve read through this thread and have even posted my question in it (last post of the thread. I’m sorry if I wasn’t clear but the solutions recommended in that thread have not helped as 1) through no method will my rear windo raise or lower, and 2) I’ve replaced the fuse I assume to be linked to the rear window (believe it’s RR WIND in the cabin fuse box.)
I get it, you’re trying to discourage people from creating the same thread over and over and over and encourage them to use the search function. You literally linked two threads I’ve read through and referenced in my post, one of which I’ve been posted in.
Am I missing something?
08-16-2018, 01:24 PM
My post was simply offering links to two threads that might provide you with some ideas of where next to proceed.
I can appreciate how frustrating electrical troubleshooting can be. It may be a combination of factors.
If the window is down even slightly, the rear wiper, rear washer, and rear defroster won't work.
Is the rear wiper properly seated in its cradle? If not, the rear window will not operate.
rear window wont work
