08-23-2010, 10:35 AM
#31
Banned
Banned
Originally Posted by Nuke
Batteries will often die catastrophically. They will start the car and then destroy themselves from something as simple as a pothole. You'll never know the battery took a dump until the next time you try to start the car since the alternator was supplying the power while you're previously running.
When that happens, it's almost always because a plate came loose and shorted against another plate. That's a sure-fire way to immediately kill a regular lead/acid battery. It's also a big reason why some guys love those gel batteries as replacements....
08-23-2010, 10:49 AM
#32
04 with 58K and original OEM Battery... Probably replace it with a new one later this year for peace of mind..
2004 SR5 4x4 V6 Titanium Silver
Suspension OME - Front 884 & N140S - Rear 895 & N141
Weather Tech Floorliners
Wet Okole's
JAOS Front Skid Plate
Michelin LTX A/T-2
265-70-17
wish list:
Bugatti Veyron
08-23-2010, 11:28 AM
#33
Another '04 here with 83K miles and the original battery. I've never had a battery last longer than three years here in Phoenix. Like may others on this site, I've checked the battery to make sure that the water was at the appropriate level. The first time that I did this about a year ago it was low, so it's a good thing that I checked. I'm thinking of replacing the battery since it is exposed to high summer heat in the desert and low winter temperatures in the White Mountains of Arizona. I also wish that I could buy the same battery as a replacement.
04 4Runner SR5 V6 4WD
08-23-2010, 01:58 PM
#34
Banned
Banned
Me too. Maybe the Toyota branded battery is just as good as the Panasonic... if nothing else, at least it is a perfect match in all specifications (including physical size) to the original.
I'm considering replacing mine before this winter, but I kinda want to see how long it can possibly last before it dies. So I'll probably just run it to failure.
08-23-2010, 01:59 PM
#35
Real Name: Paul
Real Name: Paul
My wife drives a 2003 Camry SE and it still has the original Panasonic battery. Here in MPLS the temps range from -25*F to 95*F. I had the battery tested in the early spring 2010 thinking it was time but the guy at O'Reilly was amazed, it still maintains 95% of the CCA as new!
I bought my 2006 T4R in July 2009 from a small auto broker, to try and gain some sense of comfort I made the sale contingent on passing a Toyota Dealership cerified test. Well the dealer(stealer)ship said everything was perfect with the exception of the battery, it failed the load test. They wanted to replace it and they had a replacement battery in stock (salespitch!!). I told them I'd replace the battery myself but surprise surprise I took the T4R battery to O'Reilly and they said it was perfect for a 3 year old battery.
2016 Trail MGM. P265 70/17 Falken Wildpeak AT3W. Matte Black TRD Wheels. Leveled with 2" spacer. Heated Front Seats. All LED interior. Mud flaps deleted. TRD Air & Oil Filter. TRD Oil Cap. FJC Shifter. Subaru Kicker tweeters. Hikari LED Low Beam. Cougar Motor LED DRL/High beam. Hood "scoop" and lower door wrap.
2006 SR5 4WD V6 - Owned from July 2009 with 38,200 miles to March 2017 with 150,100 miles.
08-23-2010, 06:45 PM
#36
my 04 sport has 73000 on it and has OEM battery yet. now im knocking on wood after posting this ;)
'14 4Runner SR5 Premium Bilstien 1500's, Airlift bags, 275 70R 17 Cooper AT3's,Power Stop rotors & brakes, Xenon Depot 9005 Extreme Pro LED, Morimoto H11 2Stroke 2.0, AEM dry flow filter, Magnaflow exhaust, Sprint Booster
'19 Tundra Limited CM, 2.5/1 Bilsteins 5600's, Cooper AT3 275 70 18 on Method NV305's
'12 Subaru Legacy Limited
08-23-2010, 10:12 PM
#37
I have an '04 V6 Sport with 86,000mi and the orig. battery. I keep thinking each year that it's about due but it keeps doing fine. I hope I get a warning sign first.
2004 WHITE SPORT 4RUNNER V6
Full FJ TT suspension, Daystar Comfort ride 2.5/1.5
Cooper ATR 265/70/17
and 2020 White SR5 Premium (boring stock)
08-23-2010, 11:37 PM
#38
Real Name: Jeff
Real Name: Jeff
It says in big red letters TOYOTA . And except for the date code and acid warning decal it says nothing . There is no stamping into the plastic anywhere . I REALLY wanted to know who mfger'd this battery !! The truck has also been garaged 90% of the time since new so maybe not sitting outside in the winter has helped its longevity . Regardless , I think I will replace it before this winter comes along .
Originally Posted by kylebacc
Holy crap. Is that the same panasonic one that's in the 4th gens? Either way, that's very impressive.
Agreed.
1998 4Runner 4WD Ltd
08-24-2010, 12:00 AM
#39
90,000 on my 04. stock battery with heat shield wrapped on it. works every time like a champ
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
08-24-2010, 12:01 AM
#40
Mine's going strong as well. 04' with 115k. Doesn't even hesitate. Had it tested at 110k and it came back good.
'04 Black sr5 | Tinted | Ventvisors | Driving lights | 265/70/17 Nitto Terra Grapplers | Black FJ Wheels | Custom Light Bar |
08-24-2010, 12:56 AM
#41
04 150K, original Panasonic battery, hot, cold you name it.
99 SR5 4WD, eLkr(i wish) 3.4V6 5spd.
2019 TRDOR.
2019 Taco ORP 6MT
08-24-2010, 06:38 AM
#42
Banned
Banned
That sounds like the replacement batteries that are sold at Toyota dealerships. I'm not sure who manufactures them, but I do know that there are only a handful of battery manufacturers for virtually every brand sold in the U.S.
08-24-2010, 10:54 AM
#43
I have a 04 sport at 115k and it's still running on the Panasonic Battery.
08-24-2010, 12:54 PM
#44
Banned
Banned
Wow, I'm really amazed at how many of the early 4th gen 4Runners are still running around with the original battery. That's awesome. I guess my battery isn't out of the ordinary.... The strange thing is that batteries in all my other cars only last 3 to 4 years maximum.
08-25-2010, 01:18 AM
#45
04 with original Panasonic battery!
Galactic Grey Limited 4x4 V8
Oldie - 97 Scooped 4runer
