Old 08-25-2010, 04:02 PM #1
A10MileHusker's Avatar
A10MileHusker A10MileHusker is offline
Real Name: Doug
A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough A10MileHusker is a jewel in the rough
Real Name: Doug
Steering Wheel Shaking
Hey guys! Sorry It's been so long! Been away for the summer but I'm back so I'll be back on here a lot.
The 6 or so months I've been experiencing some heavy shaking in the wheel at certain speeds. My question is simple. Is this because of the aftermarket wheel spacers I'm using. I'm unsure if the ones I bought are Lug or Hub Centric but if they happen to be lug centric would that cause some shaking? I love the stance of the 1.5" wheel spacer but if its causing this shake I'll gladly go to a Spidertrax 1.25" Hub Centric Wheel spacer.
What are your thoughts?
Glad to be back!
Doug
A10MileHusker is offline   Reply With QuoteReply With Quote
Old 08-25-2010, 05:16 PM #2
audiqtr's Avatar
audiqtr audiqtr is offline
audiqtr is on a distinguished road
audiqtr's Avatar
When was the last time you balanced your tires?
Wheel spacers shouldn't cause vibration as long as they are hubcentric and installed properly. During installation, it helps to clean the hub with a wirebrush and make sure all is tight and tq'ed to spec after the first 50 miles of installing them.
audiqtr is offline   Reply With QuoteReply With Quote
Old 08-25-2010, 05:21 PM #3
Real Name: Doug
Real Name: Doug
Oh they are balanced and rotated as perfect as my 4R can. I've had my mechanic look at everything and he says everything is tight under there and nothing he can do to fix it.
The thing is: I don't know if they are hub centric or not. If they happen to be lug centric would they cause shaking?
Old 08-25-2010, 05:33 PM #4
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
Do you have any pics of the spacer? If not, get some and we can tell you if they're hub centric or not. I'd lean more towards it being something other than the spacers, but I could be wrong.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 08-26-2010, 12:26 AM #5
Real Name: Doug
Real Name: Doug
So I dont have any pics, as of yet. But after doing some small research I'm pretty sure my spacers are, in fact, lug centric.
Correct me if I'm wrong. By what I've seen, the lug centric spacers just have bolts coming out of a spacer - thats it. Where the hub centric is designed where it has the bolts coming out and a ring on the spacer it fit into the center ring of the wheel. Its really hard to explain with words but I'm almost 95% sure I have lug centric spacers.
Would this cause the shaking? My mechanic swears (after 2 inspections) that everything is tight in my front. He's even surprised how good it looks coming from an off road truck.
Thanks for all the help!
I will get pictures tomorrow of my spacer JUST for clarification
Doug
Old 08-26-2010, 08:01 AM #6
CJ3Flyr's Avatar
CJ3Flyr CJ3Flyr is offline
Super Moderator
CJ3Flyr will become famous soon enough
Super Moderator
CJ3Flyr's Avatar
Originally Posted by A10MileHusker View Post
Correct me if I'm wrong. By what I've seen, the lug centric spacers just have bolts coming out of a spacer - thats it. Where the hub centric is designed where it has the bolts coming out and a ring on the spacer it fit into the center ring of the wheel. True. The outboard side of the spacer has a 'lip' to center the rim. Its really hard to explain with words but I'm almost 95% sure I have lug centric spacers. I won't swear to 95% but it's a huge majority
Would this cause the shaking? IMHO yes. There's a few with non-hubcentric spacers and they swear they never have an issue but most seem to need the hubcentric to get a smooth ride. My mechanic swears (after 2 inspections) that everything is tight in my front. He's even surprised how good it looks coming from an off road truck.
If your rims will take a conically shaped lugnut and you get lugnuts with the correct angle on the face of the nut that may be a choice... I have thought of that a few times when this topic comes up. I don't know if anyone has ever done a lugnut swap.
CJ3Flyr is offline   Reply With QuoteReply With Quote
Old 08-26-2010, 05:19 PM #7
Real Name: Doug
Real Name: Doug
Thanks everyone! Think I might just buy a couple spidertrax and see if that fixes my problem. Thanks!
Old 09-08-2010, 10:42 PM #8
Real Name: Doug
Real Name: Doug
Spidertrax are on their way! I'm feeling pretty optimistic that this is the problem. If not, I'm going to be pretty upset at my mechanic and make him do a much more extensive search of anything that could cause this shaking.
Will let you all know as soon as they are on!
Old 09-08-2010, 10:48 PM #9
Real Name: Doug
Real Name: Doug
Old 09-08-2010, 10:51 PM #10
Real Name: Doug
Real Name: Doug
Also, I looked at this and saw the picture and my wheel spacers look Identical to the silver ones on the right.
http://blog.spidertrax.com/2010/09/0...rial-analysis/
Old 09-08-2010, 10:59 PM #11
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
The Blog of Spidertrax Domestic vs. Import Wheel Spacers: Mechanical & Material Analysis
Those aren't hub centric (the silver one isn't, the blue one is), the lip is the dead give away. I opened this thread cuz I had the same problem but only while braking, I figured out that my left front rotor was warped. If the vibration only occurs under braking this could be the cause if the spidertraxx spacers don't fix it.
edit: I also have spidertraxx and at first thought they were the cause, but it's fine now with the spacers since I changed the rotor
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 09-08-2010, 11:01 PM #12
Real Name: Doug
Real Name: Doug
Yep! Thats why Im optimistic this will fix the problem. The ones im running are the silver ones and aren't hub centric as the spidertrax ones are. And no this is while driving, not braking.
Old 10-28-2010, 08:57 PM #13
rwilliams's Avatar
rwilliams rwilliams is offline
rwilliams is on a distinguished road
rwilliams's Avatar
I have the same problem. I have spidertrax and daystar 2.5 front strut spacers. The front tires are balance dead on. 35PSI in all 4 tires. What else could be wrong? This just happened about 1 month after the spacers
rwilliams is offline   Reply With QuoteReply With Quote
Old 10-28-2010, 09:01 PM #14
veightkiller veightkiller is offline
veightkiller is on a distinguished road
take out the spacers drive the truck and see if you still have the same problem. imo
veightkiller is offline   Reply With QuoteReply With Quote
Old 10-28-2010, 10:01 PM #15
rwilliams's Avatar
rwilliams's Avatar
Didn't help. I'm thinking new tires even though they still have atleast 80% life left on them. SUNNY tires. I bet that's the reason :/ Damn cheap-o's putting crappy tires on a 4runner just because their lease is up.
