10-04-2010, 05:07 AM
1 inch front end lift now noisy, NEED HELP
I recently had a 1 inch Daystar lift put on my car. Now when I'm driving there is a strange noise coming from the suspension when I jerk the steering wheel side to side and when I drive on a bumpy road. Kind of like a clicking noise, but doesn't do it continuously. Was it a bad install?? Is there anything I can Do?? CRAP!!!
PLEASE HELP!
2007 4TH Gen 4x4 SR5, 1" Daystar front end lift, 265/70-17 Nitto Terra Grapplers tires, Polk db speakers, Infinity Kappa Four amp, 5000K HID from DDM, 15%tint
10-04-2010, 06:47 AM
Super Moderator
Super Moderator
Re-torque the the 3 top nuts on each side. (6 total)
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
10-04-2010, 12:00 PM
Thanks!
Wow! If that's all, then I'll check it now.
Thanks!
10-04-2010, 12:09 PM
I agree with CJ3.
Also check the lower shock mount. If you over torque those mounts then it can cause them to squek or tick. I did this on a dodge pickup before. It made a helluva racket until I losened them and torqued to the proper amount.
04 4x2 Black SR5 V-6, Bilstein 5100s @ .85 w/ Moog 81088 springs 2.75" lift front, FJ Rear Springs, 265/70s, Scion T1807 HU w/ AUX input cable. 151K miles. 07/08/14 Traded-in.
08 4x4 Salsa Red SE V-6 Daystar 2.5/1.5", 265/70 Revo 2s, SpiderTrax. Traded-in on 09/14/11 W/55k miles for 08 Sequoia 5.7L
10-04-2010, 05:55 PM
2 of the 3 are a slam dunk if you have a torque wrench. that 3rd one is a PITA!
Just make sure you have properly torqued every nut and bolt to it's respective torque requirements.
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
10-04-2010, 07:15 PM
Super Moderator
Super Moderator
The magic number is 47lb/ft. After you torque two with the proper wrench your arm/wrist will be semi-calibrated and close enough for the 3rd IMHO.
Chris
10-04-2010, 09:15 PM
I have the same issue on my 05 limited with x-reas with the daystar lift on the front. Does anyone know what the correct torque specs are for those 3 top bolts?
2008 4Runner Limited 4X4 V8(X-REAS, Factory Navigation, Backup Camera, Weathertech Floor Mats, Sylvania SilverStar Ultra Highs/Lows)
10-05-2010, 02:15 PM
Working Great!!!
This fix worked great! Thanks to all of you. While inspecting the torque on most of the suspension, I came to find out that my stabilizing bar linkage was barely hand tight! That will be the last time that mechanic works on my truck.
Here are the Daystar 1"lift instructions for torque specs
20. Lower the vehicle onto the ground and tighten the upper strut tower 10mm nuts S10518. Torque to 35 foot-pounds. (3 on each side)
21. RETORQUE ALL BOLTS AFTER 500 MILES.
10-05-2010, 06:13 PM
Super Moderator
Super Moderator
Good news!
Not that it matters much but the 35lb/ft is from the spacer instructions, correct? The 47 I posted is from the '06 FSM. BTW, FWIW I'd use the spacer instructions torque.
Glad it's fixed
Chris
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
