Old 11-11-2010, 11:52 PM #1
run4estrun run4estrun is offline
run4estrun is on a distinguished road
Interior Middle Dome Light Noise ?
Hi, I have a 2005 Limited. About 1 month ago I started noticing a very odd sound in the middle dome light assembly.
As with any 4th gen, when you turn off the ignition and then open the door latch to exit the vehicle the interior lights illuminate. However, when the light illuminates it is making a weird sort of "spring" like sound. Lasts for about 1 to 2 seconds.
Let me try to describe the sound:
If you took a small spring, held one end with your hand and plucked the other end with your other hand. You know those door stops with the rubber nub on the end that we played with as kids? Kind of like a muted version of that. It isn't all that loud but it's definitely noticeable.
Anyway, not sure if anyone else has experienced this and if there are any known causes/solutions to rectify. I haven't taken it apart yet because both bulbs are functioning fine it is just making this weird noise (and only when it illuminates)...
Thanks for reading and posting any ideas you may have.
Apologies if my answer is out there in another forum. I did a search and came up with zero results.
-run4estrun
'05 LTD V6
06 LED Tails
USA Spec PA-15 TOY iPod interface
4500K Xenon Fogs
run4estrun is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 12:01 AM #2
Doozi's Avatar
Doozi Doozi is offline
Doozi will become famous soon enough
Doozi's Avatar
Mine vibrates over certain road conditions... kind of sounds like someone driving up behind me with way too much base! I plan to remove it and see if I can add some foam behind it to dampen the vibration.
~Doozi
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
Doozi is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 12:27 AM #3
00328's Avatar
00328 00328 is offline
00328 is on a distinguished road
00328's Avatar
I had that same buzz awhile back and for the life of me I can't remember what I did to fix it. It was a very simple fix though. Will post back if i can recall the fix.
2005 4X4 V8 LTD 4Runner Black
Driver's side upper assist handle, tail/stop bumper light mod, Flowmaster 50 suv with side exit exhaust and Valor tip, 20% tint on fronts and 27% add'l tint on rear window, DIY blacked-out headlights, Stainless door sills, VIP Plus w/GBS alarm, OBX pedals, Can. hood protector, ash tray kit, '06 LED tails, T&H Euro bar, OME lift, Spidertrax spacers, LT275/70R17 Cooper AT3s, HIR bulbs in LB and fogs, VSC mod, AFE Pro Dry S filter, White LED cluster and HVAC
00328 is offline   Reply With QuoteReply With Quote
Old 11-12-2010, 03:11 PM #4
thanks...that would be great if you can recall what fixed it. it is not happening when moving. it is when the vehicle is in park at a total stand-still...
'05 LTD V6
06 LED Tails
4500K Xenon Fogs
Old 11-12-2010, 03:37 PM #5
97BlackAckCL's Avatar
Real Name: Chris
Real Name: Chris
Take off the light cover and try reseating it
Old 11-12-2010, 10:44 PM #6
00328's Avatar
00328's Avatar
I don't think the light cover has anything to do with it, however I would pull the bulbs out of the cabin dome and the cargo dome and try reseating them. I would also try switching both domes to the off position and run them off for a couple days and see if these two things make any difference.
Old 11-15-2010, 12:14 AM #7
I took the bulbs out and tried reseating them:
Both out = noise gone.
1 bulb = noise only from the 1 bulb
both bulbs = i still get the sound after reseating
I might try getting 2 new bulbs and see if that does the trick. Maybe they are just worn. I think the sound is the small metal retention clip when it energizes.With out the bulb the circuit is open so I dont think they are getting power.
It's weird there are not more ppl experiencing the same sound. I wonder if LEDs would be worth trying?
'05 LTD V6
06 LED Tails
4500K Xenon Fogs
Old 11-15-2010, 02:58 AM #8
T4RBoarder's Avatar
T4RBoarder T4RBoarder is offline
Real Name: Aaron
T4RBoarder is an unknown quantity at this point
T4RBoarder's Avatar
Real Name: Aaron
I notice a similar sound more since I have installed my LEDs
T4RBoarder is offline   Reply With QuoteReply With Quote
dome , light , middle , noise , sound
rear dome light rear seat audio wiring eric4runner Problems & Warranty Issues 1 02-01-2016 09:10 AM
Center Dome Light AKABlig 4th Gen T4Rs 4 08-28-2010 08:48 PM
drop-in dome light LED pipspeak 4th Gen T4Rs 3 12-10-2008 09:18 PM
Dome Light SixxiA Classic T4Rs 3 10-08-2008 10:49 PM
blown dome light fuse wlhinso Problems & Warranty Issues 0 01-22-2007 11:13 AM
