Old 11-17-2010, 12:44 PM #1
Aquabear's Avatar
Aquabear Aquabear is offline
Aquabear is on a distinguished road
Aquabear's Avatar
T4R Dealershp work
Well, I sent my 4R to a different dealer (not dealer where 4R purchased)but was really close to college. I went in because my brakes occasionally took a really long time to stop- accident prone-, a little wavy on the highway, oil change(back muscle sore no do myself) AND our famous 4R BANG/THUMP thing at stop. I wanted to have her check b4 the long drive on to my sisters house from NY to Boston on Thanksgiving.
Well oil changed used mobil one $60.86.
Rotate and balance $82.95- no need for a 4wd alignment saved $89.95 thanks dealer.
Clean, inspect and adjust brakes $32.36- Calipers working, 8mm thick front disc and 5mm thick rear disc so no need for full brake change- would done that myself back hurt n all
They said (hmmmm) they found some debris n air in brake lines that they could flush it out and put new fluid in and maybe that would also help with the braking. $132!!!! ****! But brakes=safety and I do not have experience with bleeding brake lines so I gave the go ahead. Do not want any accidents on Turkey day.
I hate this next part
The slip Yoke (Stop/brake/Thump/BANG thing)- to usually fix this the dealer said requires a major lube 39.99 and usually solves this many customers have said. Toyota knows of this but havent said or put in a fix for it so its a charge. Was hoping it would be covered under warranty.
So far the last few days truck drives great, better pickup, not noticed the brakestopthump and brakes are functioning well better than when it went it.
Thanks
2016 T4R Trail - Rogue
Nitto TG2 285/70/17, Toytec Ultimate Lift, AFE CAI, Borla CAT BACK, URD MAF Cal, Sprint Booster
Pepe 2008 T4R V6
Aquabear is offline   Reply With QuoteReply With Quote
Old 11-17-2010, 01:01 PM #2
TC4Rnr's Avatar
TC4Rnr TC4Rnr is offline
TC4Rnr is on a distinguished road
TC4Rnr's Avatar
I bought the 6pack M1 oil at Costco this month with coupon $24, OEM oil filter $4(case price), oil disposal Free, so you are out $32
got my tires at DT, lifetime free rotate and balance, I can do it every week if I wanted. so you are out another $82.
there's no such thing called 4-Wheel alignment on 4Runner's, it has solid rear axle, only the front wheels are adjustable. sorry, you didn't save anything.
there's nothing to clean on the brakes, maybe couple squirt of compressed air. you can see the brake pads when taking off the wheels, my tires shop does it for free. another $32
I bleed my brakes every other year, 30 minutes on a bad day with my wife in the driver's seat pushing pedals and $3 worth of brake fluid. ouch....
driveline has to be lubed every year, with the rear wheels off the floor, maximum 10 minutes under the truck, 2 grease guns 1 lithium, 1 moly. for $40 you can buy everything good for 10 years. it's even listed in your owner's manual
You, have been sucked in by the stealers.
99 SR5 4WD, eLkr(i wish) 3.4V6 5spd.
2019 TRDOR.
2019 Taco ORP 6MT
TC4Rnr is offline   Reply With QuoteReply With Quote
Old 11-17-2010, 02:13 PM #3
S p a r k y's Avatar
S p a r k y S p a r k y is offline
Real Name: Mark
S p a r k y will become famous soon enough
Real Name: Mark
Why you gotta be an A hole about it? Sounds like a college kid trying to enjoy his 4runner and come to an online community where people can chat and talk about their rides.
'04 Sport V8
OME 885's, 1/4" spacers - 5100's at 0 - Toytec Superflexes with 1" rear spacers - 285/70/17 - SCS Gunmetal SR8's - LR UCA's - 20% front - 6000k low's and fogs - LED'd everything- Blacked out head lights - JL Sub and Amp
06 White Tundra - OME 888's and OME Shocks - JBA UCA's - AAL's - Summit Dakar's Black - NRG 285/75/17 - 20% front - LED everything.
S p a r k y is offline   Reply With QuoteReply With Quote
Old 11-17-2010, 02:34 PM #4
eskimochaos's Avatar
eskimochaos eskimochaos is offline
Banned
eskimochaos is on a distinguished road
Banned
Im still trying to find the point to the original post. What is it?
eskimochaos is offline   Reply With QuoteReply With Quote
Old 11-17-2010, 02:38 PM #5
TC4Rnr's Avatar
TC4Rnr's Avatar
look like you are an ahole who works for dealers. don't you see I'm helping the OP to save some money next time around.
stop *****ing and start reading.
2019 TRDOR.
2019 Taco ORP 6MT
Old 11-17-2010, 03:32 PM #6
Real Name: Mark
Real Name: Mark
haha I def don't work for a dealer. I appologize, from reading, it just seemed you were pointing out what he did and how you did it better. I agree completely the dealer is not the way to go on all that stuff. However we dont know his knowledge, may not even have a screwdriver or even how to turn it. My bad.
'04 Sport V8
Old 11-17-2010, 03:39 PM #7
TC4Rnr's Avatar
TC4Rnr's Avatar
matter of fact I didn't say anything about I did it better. it's just way cheaper. i.e. changing the oil on a 4.0V6 is the easiest as it can be of any car. you don't even need to have all 10 fingers to squeeze a grease gun to lube the propeller shaft, it only needs couple pumps anyway and if that, is ok to you for 40 bucks, then you are probably with the wrong group of people.
plus, before I leaned how to bleed brakes, I paid no more than $45 to have a shop to do it for me. holy jeepers crapers, $132????
2019 TRDOR.
2019 Taco ORP 6MT
Old 11-17-2010, 04:54 PM #8
Conspearasea's Avatar
Conspearasea Conspearasea is offline
Conspearasea is on a distinguished road
I'm not going to get into what you could have saved DIY, it's not for everyone.....
I would like to know what the better pickup can be attributed to? I could understand if your brakes were binding or something like that, but I don't see anything listed that should have led to better pickup. ( Unless the lighter wallet somehow helped it....You----> <-----Dealer Sorry couldn't help it. )
While I agree that some of those services are overpriced, we all know thats what the dealerships are infamous for doing. I suggest spending a little time on the forum asking and reading, prior to being talked into some of the crap the dealer will sell you. Lot's of help around here, it can save you a ton of money while learning about your vehicle at the same time.
Glad you are pleased w/ the truck, as that's what this is all about anyways!
2007 SR5 4WD V6 Titanium Metallic- Toytec Ultimate lift, 17x8 Pro Comp 7105s, 285/70/17 GY Duratracs, Kenwood-Infinity system, ROLA Roof rack, PlasitDip emblems and more.
http://www.toyota-4runner.org/4th-ge...ld-thread.html
2005 Limited 2WD V8 Black-Stock
Conspearasea is offline   Reply With QuoteReply With Quote
Old 11-18-2010, 12:34 AM #9
Aquabear's Avatar
Aquabear's Avatar
I am a hands on guy when it comes to cars but at this time being a disabled vet going to college it’s to find the extra time and energy or should /I say a day with less pain – and as it gets colder the nerve pain from the over 200 stitches and 40 staples not to mention the artificial skin gets really bad.
Earlier in the summer using this site I did some work on my T4R which felt great to do, new spark plugs, cleaned MAF, installed cold air intake, oil change, changed fluids in front & rear diffs and xfer case. But right now as I said this cold weather makes it hard for me to work on her.
The oil change simply made the truck drive smoother- no not like she had a turbo on but I feel when new oil is in my engine.
I bought my Nitto’s from a tire shop which gave free unlimited lifetime balancing and rotation BUT the owner of 30 years sold and the new owner and crew SUCKS so even free it’s not worth the effort of constant balancing errors, hours wasted and blood pressure up.
Yes the dealerships are overpriced – guy sitting next to me got charged 100+bill for 6 new spark plugs OUCH - I bought and put on my own for 20%of that cost- with my previous knowledge and your help here. But as I said physically my body was saying NO to working on the T4R out on the driveway so dealership it was.
PS:
I would have but have never ever bled my brakes on any cars I’ve owned.
Never had to lube a driveline ever but would have if warmer and back was better.
Brakes- thru my own visual inspection pads appeared to have girth but still had slippage so need to look to do something else I nromaly haven’t done- ie bleed brakes and clean n inspect or whatever with their brakes but I will say they are operating better.
So yes I had to pay but with the other work that I did on my own I would say I am ahead of the game.
Thank you for all your comments positive, negative and indifferent.
Pepe 2008 T4R V6
Old 11-18-2010, 01:05 AM #10
TC4Rnr's Avatar
TC4Rnr's Avatar
4Runners.org covers lots of the basic stuff.
for lube the slip yoke, it shouldn't take more than 5 seconds. it only takes couple pumps of grease, actually, too much grease is worse than dry.
I currently going to school, too. with so many people I know are entry level dealer mechanics and lube/tire changers(from all makes), the story they tell every day about how they work at dealers are just plain scary.
mind me ask a question, how do you know it's M1 oil they put in there? they put a Mobile1 sticker on your window doesn't mean it's the oil in your engine. first, , as far as I know, at least here in Indy, all the GM, Ford, Chrysler, Toyota, Nissan, Honda dealers have the same bulk oil supplier. they don't used bottled oil. their oil coming from the same tanker, either regular or synthetic blend 5-30wt. your car need 0-20w oil, you will get the 5-30w, for synthetic, you will get the blend. that's all the lube techs have. but, everybody has their own window stickers, Chevron, Valvoline, Pennzoil, Mobile you name it.
2019 TRDOR.
2019 Taco ORP 6MT
Old 11-18-2010, 01:07 AM #11
THEROK THEROK is offline
THEROK is on a distinguished road
i like my dealership. bellevue toyota.
THEROK is offline   Reply With QuoteReply With Quote
Old 11-18-2010, 01:13 AM #12
810moto's Avatar
810moto 810moto is offline
810moto is on a distinguished road
810moto's Avatar
@ auqabear. I will say this loud and proud. You are a Vet as am I. Thank You for your service. What branch did you serve?
BTW...if the dealer is what you had to do becuase of conditions out of your control, then so be it. You do what you have to do sometimes.
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
810moto is offline   Reply With QuoteReply With Quote
Old 11-18-2010, 10:11 AM #13
Aquabear's Avatar
Aquabear's Avatar
Thanks alot 810moto. Navy. What about you?
I didn't come to the decision on using the dealership lightly as I would rather DIY.
TC4Rnr that same statement about the oil in bulk could be said for ANY mechanic shop not just dealerships or toyota dlrshps as not every shop that does oil changes actually opens up individual oil quarts so thats kinda paranoid. Yes it could be true but I don't believe everything nor everyone is a conspiracy theory.
I'm glad you can do the work on your own but at this time I can't because as I previously said I served my country and becasue of the cold weather it's hard for me to do the work on the truck. You already stated your point once and thank you but now your just being rude, disrespectful and full of yourself.
Scuba diving, got hit with a rogue wave, crushed on the rocks was barely and dam lucky to be alive, medevac to the states, trauma unit for weeks, I was diving, over 200 stitches, 40 staples, artifical skin- so please don't go over your theories of oil- I don't give a **** really!
This site was meant as a medium to pass along knowledge which I have used successfully many times and let's keep it that way and have gained great knwoledge of my vehicle to my financial and personal satisfaction.
Think and read fully before you respond to a message if someone says they can't do the work don't disrespesct them not once but twice?
If that was not your intent then you really need to rethink about what your intent truly was to begin with.
But we are goning to leave this on a positive note Thanks alot for your service 810moto. Right on
Pepe 2008 T4R V6
Old 11-18-2010, 10:13 AM #14
Aquabear's Avatar
Aquabear's Avatar
Sunrise Toyota. First time using them - for service that is- I like mine too.
Pepe 2008 T4R V6
Old 11-18-2010, 10:20 AM #15
Real Name: Mark
Real Name: Mark
[QUOTE=Aquabear;652665] You already stated your point once and thank you but now your just being rude, disrespectful and full of yourself. QUOTE]
Isn't that kinda what I said? lol.
Aquabear and 810moto, thank you for what you do. Without guys like you we wouldnt be on this forum or modding cars.
'04 Sport V8
Tail light Hookup?? For Towing the T4R Spaceman 4th Gen T4Rs 6 03-08-2008 11:02 PM
2007 T4R Seat Warmers - how well do yours work? hesimeustic 4th Gen T4Rs 9 02-24-2008 12:57 PM
How to hook up tail lights for towing T4R Spaceman Engines / Suspension / Wheels / Tires / Audio / Accessories 1 02-14-2008 11:32 AM
Not so impressed with the T4R owner who.. magnumfan 4th Gen T4Rs 17 02-08-2008 11:48 PM
T4R G4 4WD Driving habbits magnumfan 4th Gen T4Rs 23 02-04-2008 09:04 PM
