Old 11-28-2010, 02:36 PM #1
ALTAHLC's Avatar
ALTAHLC ALTAHLC is offline
ALTAHLC is on a distinguished road
ALTAHLC's Avatar
Broken plastic housing on remote key
I've broken the little plastic loop on the main remote housing that attaches the key to my '06 Sport. Its completely annoying have them separated. I haven't explored a factory replacement, but was wondering what my options are for a replacement and subsequent programming.
Thanks much!
'8/11 TE Shoreline Blue | KDSS | Bilstein 5100 | BFG KO2 | SS Exhaust Tip | N-Fab Nerf Bars | Rago Fab Lower Shock Guards | Blackout | K&N Air & Cabin Filter | KC HiLites Cyclones | V-Led | Equipt1 / Escape Gear Seat Covers | Canvasback Cargo | ICS Fab Dash Panel | Ram X-Grips | Rago Fab MOLLE Panel | Blue Ridge Overland Gear MOLLE Seat Panel & Pouches | LLumar Tint | Pioneer AVH-4500NEX | Alpine S-A32 | Alpine PWE-S8 | Hertz Audio | NVX Baffles | Kilmat | Garmin Dashcam 56 | Yakima FatCat 4 |
ALTAHLC is offline   Reply With QuoteReply With Quote
Old 11-28-2010, 04:11 PM #2
glock56534's Avatar
glock56534 glock56534 is offline
glock56534 is on a distinguished road
glock56534's Avatar
I would just use some JB Weld or epoxy to "rebuild" the loop. It might not be as pretty as a replacement, but it will work well and will be MUCH cheaper than buying a new one.
If you do go this route, just make sure you get something that will bond to the plastic on the remote. If not, it will eventually fall off again.
If you really want to get dirty with this project, duct tape it .
glock56534 is offline   Reply With QuoteReply With Quote
Old 11-28-2010, 04:29 PM #3
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
http://www.keylessride.com/order/cho...&model=4Runner 2006 Toyota 4Runner Keyless Entry Remote - Keyless Entry Remotes - Replacement Car Auto Key Fob Remotes Keyless Entry DESIGNER-STYLE KEY FOB COVER. Fits many Toyotas and Scions from 1999 to 2007. | StreetPerformance.com
chaz is offline   Reply With QuoteReply With Quote
Old 11-28-2010, 05:50 PM #4
ALTAHLC's Avatar
ALTAHLC's Avatar
I appreciate the links Chaz! The whole loop snapped off, so no option to "weld", but I appreciate the idea Glock. That reminds me to put a roll of duct tape in the truck.
Thanks again.
Old 11-28-2010, 06:16 PM #5
glock56534's Avatar
glock56534's Avatar
Yep, no problem. Epoxy putty would fit the bill the best if you do end up going that route, as you can mold it exactly how you want it shaped and will bond to the plastic very well. Even if the entire loop is snapped off, the epoxy putty will create a whole new loop. Or, you could just lightly sand the end of the broken remote, then put a good amount of epoxy on the end so you can drill a hole in it for the keyring after it cures.
You could just buy an after market remote, and epoxy a new loop on the old one so you have a good backup remote.
And yes, keeping a spare roll of duct tape in the truck is a must.
Old 08-04-2017, 12:13 PM #6
Iguanahump Iguanahump is offline
Iguanahump is on a distinguished road
Key Fob replacement
If the insides of the key fob are still good. You can buy a replacement cover on Ebay for $7.00. Just did it, looks identical and was easy.
Iguanahump is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 12:47 PM #7
Legender Legender is offline
Legender is on a distinguished road
plenty of low cost options on ebay like the above.
2005 SE V8 FWD 177k
Legender is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 01:29 PM #8
Trumpet Trumpet is offline
Trumpet will become famous soon enough Trumpet will become famous soon enough
Amazon as well.
2007 SR5 V6 long live the kingfish !
2009 SR5 V6 ---RIP
Trumpet is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 02:39 PM #9
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
mine did the same. I replaced the case, and at the same time added a rubber outer sleeve for a bit of additional protection.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 08-04-2017, 08:57 PM #10
scotthulbs scotthulbs is offline
scotthulbs is on a distinguished road
What ^^^ he said. I just bought one of these last week. Its a perfect cheap solution so long as the fob still works
scotthulbs is offline   Reply With QuoteReply With Quote
2000 4Runner Key Programming Instructions SkyRat 3rd gen T4Rs 8 03-01-2019 04:57 AM
Remote Start IIIBradIII Engines / Suspension / Wheels / Tires / Audio / Accessories 30 12-13-2012 09:00 AM
Factory Remote Housing Replacement Asmara 3rd gen T4Rs 14 05-18-2011 06:47 PM
Plastic Key JoeV 4th Gen T4Rs 31 11-16-2004 09:19 PM
How to make an extra key? hanya Engines / Suspension / Wheels / Tires / Audio / Accessories 14 04-02-2004 02:57 PM
