Old 10-22-2011, 09:51 AM #31
ghser7's Avatar
ghser7 ghser7 is offline
ghser7 is on a distinguished road
ghser7's Avatar
Great info in this! I just bought one and have the same issue. I have not had time to look at it yet, but pretty sure this will help.
I have no clue why people would think going from "LO" setting to 65 and getting heat would be normal or even the way the A/c is suppose to work though.
ghser7 is offline   Reply With QuoteReply With Quote
Old 04-19-2017, 10:18 AM #32
jediwebdude's Avatar
jediwebdude jediwebdude is offline
jediwebdude is on a distinguished road
Originally Posted by rtuck1 View Post
I just went through this after installing a brand new head unit. As it turns out the interior temp sensor for the a/c unit was unplugged. It is located by your right knee on the drivers side. If you look at the plastic plate under the steering wheel you will see an area that has slits in the plastic. The sensor is right behind that piece of plastic. Simply plug in the sensor or if it has gone bad it may need to be replaced. That is my experience and i had the same exact situation occur.
Thank you!! I installed a new head unit last night. Today, my A/C blows only at LO. Hopefully this is what happened.
TCT Magazine
2019 TRD Pro Tacoma - Voodoo Blue
2018 Shelby GT350
jediwebdude is offline   Reply With QuoteReply With Quote
Old 11-08-2017, 09:20 PM #33
daytonaviolet's Avatar
daytonaviolet daytonaviolet is offline
daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold daytonaviolet is a splendid one to behold
Originally Posted by progress4m View Post
I have seeing same issue as you described when temperature sensor inside of the truck (on lower part of the dash) is unplugged, has bad connection or not functional..
I would check that first.
this.. fixed my issue
http://www.toyota-4runner.org/2839404-post7.html
daytonaviolet is offline   Reply With QuoteReply With Quote
Old 11-09-2017, 11:58 AM #34
progress4m's Avatar
progress4m progress4m is offline
progress4m will become famous soon enough progress4m will become famous soon enough
progress4m's Avatar
Smile
Originally Posted by daytonaviolet View Post
Wow, that was the old thread, but I am sure glad that my info still useful and helped to fix the problem!
2013 Silver Trail (with KDSS)-Nitto TG-G2, Bilstein 5100, Custom lift: front 2.1", rear 1.5" (lift info: [URL=https://www.toyota-4runner.org/2938235-post744.html[/URL] thread #744)
1995 SR5 4x4, 1996 SR5 4x4, 2005 SR5 V8 4x4- All Sold, but not forgotten!
DON'T GET CONFUSED BETWEEN MY PERSONALITY AND MY ATTITUDE. MY PERSONALITY IS WHO I AM...MY ATTITUDE DEPENDS ON WHO YOU ARE
progress4m is offline   Reply With QuoteReply With Quote
Old 11-09-2017, 01:16 PM #35
lol yes but that's what forums are for i've had this issue since the stereo shop installed my CarPlay HU (2 mo) and its been bother me.
Old 08-17-2019, 04:46 PM #36
WyEast-08's Avatar
WyEast-08 WyEast-08 is offline
WyEast-08 is on a distinguished road
WyEast-08's Avatar
Same thing happened here. Anything above LO and the system was blowing hot air. I pulled the panel under the steering column ( two screws) and sure enough the sensor and tube were disconnected. I re-connected, buttoned the panel up and the climate control worked as it should.
WyEast-08 is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 01:11 PM #37
RRobich RRobich is offline
RRobich is on a distinguished road
Smile
I had the same problem, AC blowing hot on any temperature setting other than Lo. Interior temp sensor was not completely plugged in. Easy fix! I had been fixing something under the dash a few weeks ago and must have slightly disconnected it. It looked like it was plugged in, but it wasn’t “clicked” in.
RRobich is offline   Reply With QuoteReply With Quote
Old 07-21-2020, 05:02 PM #38
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Add me to the list of people who got cold air on lo and hot air on 65°. It’s 82° and sunny here today, so my interior was definitely hotter than 65°.
My cabin temp sensor was also disconnected and not attached to the lower dash panel. (I had my lower dash apart when I installed my 1” body lift recently.) It was a simple and free 5-minute fix. Gotta love this forum!
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Difference Between Cold Air Intake Dry Filter and Wet Filter ts9790147 4th Gen T4Rs 3 11-27-2009 11:05 AM
air vent setting - Fresh Air?? tamiyatim 4th Gen T4Rs 5 10-09-2008 10:27 PM
2003-up Range Rover (RR3) Thai Comparisons & Reviews 50 06-09-2006 08:32 AM
Mysterious Cold Air Intake for '03s Goose Engines / Suspension / Wheels / Tires / Audio / Accessories 4 11-14-2003 12:41 AM
K&N air filters Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-02-2003 09:26 AM
