Originally Posted by pearlj10
That's a bummer, for sure. How did you install the seals? I wonder if your right seal may have been damaged during istall?
I kept the original seals on the outer ends of the differential. I was carefull and inspected the seals. Only the right side leaked. After seeing the leak, I replaced the perfectly good seal with a new Toyota seal. I drove it in with a motorcycle oil filter wrench that fit perfectly on it. I had assistance holding the shaft and guiding it in. The splines never touched the seal. I appreciate you guys asking these questions.
