Originally Posted by gassface
Hey gang - I need your help. I have a 2006 limited with no heat. I read a few threads and tried a few suggestions, but still no heat. Here are some details...
- Coolant level is OK
-engine temp levels are ok - warms up fine
- I ran the engine for about 20 minutes with the radiator cap off to try and "burp" out any trapped air in the heater core - No luck
- both hoses into/out of the heater core are hot
any other ideas? I can't believe the heater core could be kaput. Its only a 2006, right? Any help would be appreciated - of course this happens the day a winter storm and cold spell roll into town.
Quick Update in case someone else finds themselves with the same issue. After living with the problem for a couple of years I decided to bite the bullet and take it to the shop. Turns out my heater core was clogged. I could get some heat with recirculated air, but if I turned the fan to high it would blow cold after a few seconds. The mechanic said it was pretty rare, but it fixed the problem. All the motors and blend door actuators were functioning properly. $1050 at my indie mechanic.
