01-11-2019, 10:45 AM
#1351
Originally Posted by ELock3rdGen
Will the adjustable tundra Burstein 5100 we used in our 3rd gen fit our 4th gen? Assuming I get new springs? Reason I ask is I put in some new 5100 on my 3rd gen a few month back but now I'm debating on selling it. I already have a 04 4runner v8 so of it was compatible I was going to take them off and use them on the 4th gen.
Yes it will fit
01-11-2019, 11:13 AM
#1352
Originally Posted by Sharkseed
Yes it will fit
Thanks!
1998 4Runner. AVS wind visor. Yakima LoadWarrior. Optima Yellow top. Trail Gear battery holder. Big 3 upgrade. Tundra brake upgrade. Tundra TRD front coil. Toytec Superflex with Tundra 5100 Bilstein rear. Complete Alpine audio system. FJ Trail Gear rim.
01-18-2019, 05:01 PM
#1353
fJ Springs with Bilsteins 5100
So Im in the process of installing FJ Springs with Bilstein 5100 Shocks. I've set the Bilsteins at 1.75 and now the springs are so compressed I cant jack up the control arm, the springs don't want to compress any more and when trying to jack up my lower control arm, the whole truck lifts and the shock and spring wont compress any further. Thoughts?
01-28-2019, 03:03 PM
#1354
Real Name: Chris
Real Name: Chris
Spring seat on upside down?
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
02-27-2019, 12:07 PM
#1355
XREAS is shot....
The rides been getting rougher and rougher, and found my XREAS is leaking at the central control module on both sides on my 06 Sport 4WD V6. 130k miles. I plan on ripping it out and therefor, need to replace all my shocks. Figure I'd do the coils as well.
After reading a lot (wow, this forum is an incredible resource), I think I'm going to do the 5100s with Moog Coils, with new KYB shock mounts, but am currently looking at the 4runner Moog coils (81045-back and 81090-front). I'm only on dirt roads/mountain roads occasionally but this is more of our play vehicle, so I'd like about 1.5"-2" of lift, and would like to level out the front which has horrible sag right now. My current plan is to do a Daystar 1.5" spacer in the back and set the 5100s on 1.75" in the front. From what I've seen, that (with new springs) does a pretty good job leveling things out. The Moog 4R coils have about .5" more height than OEM.
Now I'm wondering if I should do the Moog FJ coils (81081) in the rear instead and skip the spacer, which according to a coil rate chart that I found here, which have 1.2" most coil height to them, but also appear to have a lower spring rate than the 4Runner Moog coils. Any thoughts? I've read that the Moog FJ coils don't fit well in the rear and require modifications.
As I mentioned before, we mainly use the 4runner for going up canyon roads in the winter, fire/dirt roads in the summer for backpacking/climbing, and occasionally will take it to Moab on some rougher roads, but never do anything that a stock vehicle wouldn't be able to get through. Some extra clearance and a fresh ride is really all I want.
02-28-2019, 12:36 AM
#1356
Alright so this past weekend I finally pulled the trigger and did my upgrade. I chose to stick with the stock 2007-2009 FJC Tokico shocks and the 2010+ FJC coils and wow, what a difference it made in handling.
No more bottoming out (front end) over speed bumps at very low speeds, no more feeling the imperfections of the road at any speed either.
Cornering definitely improved. Braking and accelerating also feels tighter now. Before I could feel the truck tilt when braking and accelerating.
Before the "upgrade" I could tilt the truck side to side and it would wobble a few times but now it wobbles maybe twice and then stops.
Here's some before and after measurements from the ground to the bottom of each fender. The difference from left to right was really tiny, like 1/16" in both before and after which is why the measurements look perfect.
Before Upgrade: Stock OEM T4R Limited Suspension on V6 4WD
Front Left: 32 3/4"
Front Right: 32 3/4"
Rear Left: 35 1/4"
Rear Right: 35 1/4"
After the Upgrade: 2007-2009 FJC OEM Tokico Shocks and 2010+ FJC coils
Front Left: 33 3/4"
Front Right: 33 3/4"
Rear Left: 35 3/4"
Rear Right: 35 3/4"
Front Difference: 1" gain
Rear Difference: 1/2" gain
I'm really happy with the results and wasn't looking to raise it much as it is mostly always driven in the city. It's been about 11 years on the old suspension and about 90k miles.
There was nothing special I needed to do in order to have the two different years of FJC parts work. Everything bolted up just fine.
For those who are curious or interested in this mod, I listed the shocks and coils below.
PARTS LIST:
Front Shock (Left/Right): 48510-80397
Front Coil (Left): 48131-35670
Front Coil (Right): 48131-35660
Rear Shock (Left/Right): 48530-80461
Rear Coils (Left/Right): 48231-35420
This concludes the chapter of this upgrade on my T4R. Thanks for all the information from everyone.
03-06-2019, 02:45 PM
#1357
Small update, ordered the 5100s and some other parts. Ended up getting the Moog FJ coils for the front, and the Moog T4R coils for the rear. Both arrived horribly packaged, with each coil having at least 10+ chipped sections throughout the powercoat or whatever the finish is. They are scratched to the point where it looks like they have almost been installed before. I've order paper towels that came with more protective packing...
Decided to return all of the coils, including the 1.5 rear spacer, and am going to bite the bullet and go for the T1/T12 coils, with only a 1/4" spacer on the FL to level out the driver's sag based on: . I thought about doing the OME stuff, but the heavier spring rate, combined with some comments around here about the valving for 5100s not playing the best pushed me towards the Wheeler's stuff.
Will update when everything arrives!
03-18-2019, 10:34 PM
#1359
Real Name: Chad
Real Name: Chad
Originally Posted by 4RUNNINGNY
I think you can beat those prices at Advance Auto Parts - they will almost always give you 25% off if you throw them in the cart and then wait a day. But even at that with the 15% code at the top of the site you'll be a few bucks ahead I bet
2008 4Runner SR5 V6 - Bilstein 5100 (0.85) w/ MOOG FJ Springs - 255/70R17 Goodyear Wrangler TrailRunners - Rola Rack w/ extension - Pioneer AVH-2300NEX - Canvasback Cargo Cover - WeatherTech mats
03-19-2019, 06:18 AM
#1360
Real Name: Russell (OB #9908)
@ 4RUNNINGNY
, IIRC, Daystar is among the few manufacturers whose specs indicate the thickness of the spacer, not the lift gained, which is double the spacer thickness. I’m not sure if the geometry is the same front & rear but in the front, my understanding is that a 1.5” spacer gives you 3” of lift. Can someone with a deeper knowledge than mine confirm that this is also true for the rear?
If so, just be aware that with Daystar gear, you’ll be lifting the rear 3”, not 1.5.
03-19-2019, 12:01 PM
#1361
Real Name: Derek
Real Name: Derek
Originally Posted by Bluesky 07
@ 4RUNNINGNY
Rear is 1 to 1.
So the rear at 1.5" = 1.5".
Your just lifting straight up at the coil.
Front is almost 2 to 1...or just under.
Front at 1.5" = just under 3"... in theory. 2x1 ratio. has to do with the geometry ratio with the A-arms. Think of it like a lever.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
03-19-2019, 01:39 PM
#1362
Originally Posted by BackOff
Rear is 1 to 1.
Thanks for clarifying that.
03-20-2019, 12:08 AM
#1363
Thanks for that info guys! Definitely saved a bit using Advance auto parts. One thing to keep in mind is that they charge tax and eBay did not.
04-11-2019, 06:05 PM
#1364
Real Name: James
Real Name: James
Are those the rear springs that need a mod to get to seat corectly?
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
07-08-2019, 03:41 PM
#1365
So let me get this straight, FJ Cruiser springs from 2012 WILL fit a 4th gen 4Runner but the actual OEM shocks will not?
