Thread Tools Rating: Thread Rating: 10 votes, 4.20 average. Display Modes
Old 11-05-2019, 12:30 PM #1396
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Originally Posted by JShipps View Post
Hey John, your ride looks great! Did you happen to measure your before and after from hub to fender? I'm curious what kind of lift you ended up getting.
I went a different route for my suspension and got way more lift than I was expecting and I'm wondering if it's too much and I'll need to mess with a new UCA. I've already had my CV axle boot split, but that's not surprising on a rig with 160K on it.
People talk about needing new UCAs with a 3" or more lift, but that doesn't tell much when you're comparing to a saggy old suspension. What's the baseline for the 3" to start from? It seems like what I really need to know is, at what hub to fender measurement do I need to worry about new UCAs?
It's more about the alignment. Once you can't get a good alignment anymore because of the height that when you need them
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 12:52 PM #1397
JShipps JShipps is offline
JShipps is on a distinguished road
Thanks. I had it aligned and they didn't say anything about any problems, so I assume it's OK. I attached a pic of my rig with the new suspension.
Compiled: FJ Springs Lift Info for 4th gen-img_649b25260938-1-jpg
4Runner Noob
2007 SR5 V6
JShipps is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 04:52 PM #1398
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
The more you lift these things, you more loose caster.
less caster=constant steering wheel input.
More caster=tracks better with less steering wheel input.
3.5* or more fixes that funky wandering feeling.
In the NW we use studded tires, makes big ruts in the pavement.
Low caster really suck in that sort of roadway. Constant user input...really sucks.
Caster improves the tracking of the T4R... less driver input.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 11-05-2019, 05:58 PM #1399
Thanks Derek. I'm nowhere near 3.5. I'm at 1.3 and 1.39. But my steering feels fine. The specs say that 3.97 is the max. I guess we'll see how it settles in. Perhaps over time it'll feel like it's wandering more, but for now it feels great!
My only real concern is the CV axles. I've already replaced one and will probably need to do the other before long.
4Runner Noob
2007 SR5 V6
Old 11-05-2019, 06:11 PM #1400
Real Name: Michael
Real Name: Michael
UCAs won't affect anything related to CV wear just btw...Also "Max" is for factory suggested setting and also in the event that you are all stock suspension and wheel/tire, which you aren't. Don't worry about going over that caster number, it has no negative consequence. I believe my numbers are like 6+ and mine drives great
Old 11-05-2019, 06:36 PM #1401
So pardon my ignorance, but it seems like you're saying that I can dictate what the alignment shop sets my alignment at. Is that correct? Or, are you setting it yourself? I just drove my rig to the alignment place and paid for an alignment. I didn't know I was supposed to tell them how I wanted it. I'm new to this stuff so still figuring it out.
4Runner Noob
2007 SR5 V6
Old 11-06-2019, 09:39 AM #1402
Real Name: Michael
Real Name: Michael
Well, with aftermarket UCAs you can get a more wide range of measurements thus allowing you to fine tune your specs.
Some with the SPC UCAs like me, have to set their preliminary alignment at home and then take it to the shop to get fine tuned.
Not all shops are aware of stuff like this. Most "Off-Road, or Custom" shops know stuff like this though if you can find a shop like that that will align you will be much better of in my experience.
This video should help.
YouTube
Old 11-06-2019, 10:59 AM #1403
mkscrewy mkscrewy is offline
mkscrewy is on a distinguished road
Originally Posted by crete01 View Post
Small update, ordered the 5100s and some other parts. Ended up getting the Moog FJ coils for the front, and the Moog T4R coils for the rear. Both arrived horribly packaged, with each coil having at least 10+ chipped sections throughout the powercoat or whatever the finish is. They are scratched to the point where it looks like they have almost been installed before. I've order paper towels that came with more protective packing...
Decided to return all of the coils, including the 1.5 rear spacer, and am going to bite the bullet and go for the T1/T12 coils, with only a 1/4" spacer on the FL to level out the driver's sag based on: . I thought about doing the OME stuff, but the heavier spring rate, combined with some comments around here about the valving for 5100s not playing the best pushed me towards the Wheeler's stuff.
Will update when everything arrives!
sorry to bump your post from march, but how did this work out for you? interested in doing the same lift with the same equipment. thanks!
mkscrewy is offline   Reply With QuoteReply With Quote
Old 11-07-2019, 03:09 PM #1404
blackjackck's Avatar
blackjackck blackjackck is online now
Real Name: John
blackjackck will become famous soon enough
Real Name: John
Thanks, with NEW OEM FJ shocks, coils and all compared to my XREAS was roughly 1 inch lift. That also include the skinny and a tad taller tires. The FJ Wheels also has a different offset so the tires and wheels come out a bit.
Yeah, I've read about new UCA when lifting over 3' as well. Sorry I can't help answer that question. I do vaguely reading talk about all that in the thread when I read through the whole F**ken thread. Where I can't remember now. Good luck
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
blackjackck is online now   Reply With QuoteReply With Quote
Old 02-11-2020, 12:08 PM #1405
koawood08 koawood08 is offline
koawood08 is on a distinguished road
Great info on here regarding the whole 5100/FJ combo. I've notice a lot of height discrepancies when one states they are on FJ coils set at .85 (no spacers) and fj rears with 5100. Looking for a real mild lift but some of the infor here is misleading. 265/70/17 AT's are the plan for fitment on an after market wheel 17x8.5
koawood08 is offline   Reply With QuoteReply With Quote
Old 02-11-2020, 12:45 PM #1406
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
I have Moog 2007 FJ rear coils with no spacers and running, for now, 2017 Tacoma Bilstein rear shocks. Plenty of room with zero rubbing for my 265/70/17 Goodyear Wrangler UltraTerrains. Front are 2019 Tacoma Bilsteins with the Tacoma coils.
The Tacoma shocks are a little soft and I will probably change them out for 5100s sometime soon.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 07:19 PM #1407
Bkt4runner's Avatar
Bkt4runner Bkt4runner is offline
Bkt4runner is on a distinguished road
Bkt4runner's Avatar
FJ red bilstein TRD on 4th gen
Would the red Bilstein TRD offroad shocks allow me to stay at the factory height on my 2003 4Runner if I used my oem stock springs?
Toyota TRD FJ Cruiser Front Offroad Strut Absorbers Genuine OE OEM | eBay
Do I really need to replace my oem springs? I have 222,000 miles on it.
-2003 SR5 V8, white with grey trims
Bkt4runner is offline   Reply With QuoteReply With Quote
Old 03-04-2020, 09:06 PM #1408
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I had the same question when I did my suspension and concluded that I didn’t want to do the work and then always wonder how much better the ride would’ve been had I done the springs. So I did my research and learned that springs are a very underrated part of the suspension.
I think a lot of people spend money, sometimes a lot of it, on shocks but no springs, and then are disappointed with the ride. You have a 2003, so you’re riding around on metal that has carried a 4500 lb. SUV for 17 years on the equivalent of nine trips around the planet. They had a good run, but it’s time for new ones.
Check out the suspension link in my sig for a side-by-side pic of my stock 2007 springs versus FJ springs.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 03-17-2020, 01:39 PM #1409
MxwlT4R99 MxwlT4R99 is offline
Real Name: Max
MxwlT4R99 is on a distinguished road
Real Name: Max
Originally Posted by Daemon View Post
Hmm, that's odd, because with my '06 V8, the front 5100 at 0.85 and Moog FJ
springs all around, running board is only 1/4" lower in the rear than front.
Now if I wanted to equalize the wheel gap (between top of tire and fender)
then I'd have to raise the front another full inch, but that definitely would
create a reverse rake at the running board (and almost everywhere else).
Daemon, sorry for the massive 3 year resurrection, but what tire size are you running in the picture you shared (included in this post) ? Can you post an update on how it's sitting?
I'm asking because I am after a very similar setup on my 2006 V8 Limited, and I can't decide between the 0.85 perch or the 1.75 perch with the Moog FJ springs, which seem like they give more of a lift than the actual Toyota FJ spring take-offs. I'm planning on running 265/70r17 on Level 8 mk 6's...
If anyone has any advice or new images of a similar setup, I'd appreciate it - I've pretty much exhausted all searches and threads.
Daemon's setup in question below:
Compiled: FJ Springs Lift Info for 4th gen-daemonquote-jpg
MxwlT4R99 is offline   Reply With QuoteReply With Quote
Old 04-14-2020, 01:00 PM #1410
RCopp17 RCopp17 is offline
Real Name: Ryan
RCopp17 is on a distinguished road
Real Name: Ryan
Been pouring over this topic for the last few weeks and had a question I can’t seem to find the answer to. So at the risk of sounding naive, has anyone used OME shocks and FJC coils?
2006 SR5 4x4 Bilstein 5100s (1.75) | FJ Coils | black 5th Gen 17s | 265/70/17 Falken AT3Ws | Flowmaster 50
Sold:2001 SR5 4x4
RCopp17 is offline   Reply With QuoteReply With Quote
Compiled: Satoshi Build, Help & Picture Thread dgwood12 4th Gen T4Rs 76 08-11-2021 07:20 PM
Lift Info and FAQ thebwlife 5th gen T4Rs 1 05-25-2012 06:01 PM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
mixed info with 99 tall springs?? hdoggie24 3rd gen T4Rs 17 07-15-2010 04:48 PM
Leaf Springs-Prices/buying info '88 mountainman_gz Classic T4Rs 4 02-08-2009 01:28 PM
