Thread Tools Rating: Thread Rating: 10 votes, 4.20 average. Display Modes
Old 05-25-2020, 01:02 AM #1426
4runnerlexky's Avatar
4runnerlexky 4runnerlexky is offline
4runnerlexky is on a distinguished road
By any chance when swapping with the FJ suspension, I noticed that the toytec body lift is cheaper than the springs. Should I go for the 3 inch body lift and wait to save money. I was thinking about doing the Icon stage 5 suspension with modified high clearance lower control arms.
4runnerlexky is offline   Reply With QuoteReply With Quote
Old 06-01-2020, 10:50 PM #1427
RCopp17 RCopp17 is offline
Real Name: Ryan
RCopp17 is on a distinguished road
Real Name: Ryan
Compiled: FJ Springs Lift Info for 4th gen
Just swapped my suspension out this weekend (5100s all around with 07-09 FJC coils)! My question is how long should i wait for everything to settle before i get my truck aligned?
2006 SR5 4x4 Bilstein 5100s (1.75) | FJ Coils | black 5th Gen 17s | 265/70/17 Falken AT3Ws | Flowmaster 50
Sold:2001 SR5 4x4
RCopp17 is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 09:18 AM #1428
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
I'd say a day or 2, I wouldn't wait too long afterwards. I'm planning on doing my suspension swap on Saturday with an alignment scheduled for the following Monday morning.
Any pictures with the new FJ suspension?
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 06-02-2020, 12:01 PM #1429
Real Name: Ryan
Real Name: Ryan
Got it, I’ll see if I can squeeze in somewhere later this week then. Just nervous because I netted a little over 3” (unsettled)in the front, set the strut at 1.75 but it leveled me right out. I think the rear is about 1/4” higher technically, I’d have to double check what I got for measurements. Here’s a crappy phone pick thoughCompiled: FJ Springs Lift Info for 4th gen-img_4627-jpg
Sold:2001 SR5 4x4
Old 06-02-2020, 01:07 PM #1430
Heffernan's Avatar
Heffernan's Avatar
Got it, I’ll see if I can squeeze in somewhere later this week then. Just nervous because I netted a little over 3” (unsettled)in the front, set the strut at 1.75 but it leveled me right out. I think the rear is about 1/4” higher technically, I’d have to double check what I got for measurements. Here’s a crappy phone pick thoughAttachment 362642
Thanks - I keep going back and forth between setting the front to the second (.85") setting or leaving it on the stock setting and adding a 1/4" top out spacer. I'm not planning on lifting the rear right now so I'd like to keep the lift to around 1.5"-2" total.
Old 06-02-2020, 05:21 PM #1431
Real Name: Ryan
Real Name: Ryan
There’s a great spreadsheet and thread that was put together that should help you answer that question believe Ark_runner started it
Sold:2001 SR5 4x4
Old 06-03-2020, 09:22 AM #1432
Heffernan's Avatar
Heffernan's Avatar
Oh yea, I've seen it.
Is your T4R a V6 or V8?
Old 06-03-2020, 11:09 AM #1433
Real Name: Ryan
Real Name: Ryan
It’s an ‘06 V6
Sold:2001 SR5 4x4
Old 06-18-2020, 12:18 PM #1434
71-Cruiser's Avatar
71-Cruiser 71-Cruiser is offline
71-Cruiser is on a distinguished road
71-Cruiser's Avatar
i just ordered a set of 2895e springs and will report back.
03 Tundra 4x4, 03 4-Runner V8, 71 FJ40, 67 FJ45LV
13 CRF450R
TLCA #14378
71-Cruiser is offline   Reply With QuoteReply With Quote
Old 06-25-2020, 06:44 PM #1435
Jayson44's Avatar
Jayson44 Jayson44 is offline
Jayson44 will become famous soon enough
Jayson44's Avatar
ok, so what needs to be modified on the strut to make a set from a 2010+ work? I found a Toytec Ultimate kit for sale locally, but it's for 10+ 4Runner & 10+ FJ Cruiser...
J.
05 v8 Sport - K&N air filter - Toytec Ultimate front + OME 3" rear - JBA HD UCAs - Spydertrax spacers - 35" Kenati Trail Hogs - Vors v37s
Jayson44 is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 05:56 PM #1436
jweb4r jweb4r is offline
jweb4r is on a distinguished road
2005 V6 4x4. Original x-reas system was starting to go, rear right shock was leaking(DEC 19'). Had already been digging into this thread like crazy, tons of great info and setups, so thanks all! Had the job done mid March this year.
Bilstein 5100 all around, front @ 1.75
OEM FJ coils front and rear(2012 4x4)
1" Cornfed rear spacer
1.25" Spidertrax
265/70/17 Hankook DynaPros for now....
Measured from ground through center of wheel to fender.
Before
Right Front - 33.75
Left Front - 33.5
Right Rear - 36.12
Left Rear - 36.25
After
Right Front - 36.5
Left Front - 36.25
Rear - 37.75 both sides
Compiled: FJ Springs Lift Info for 4th gen-xyn5dq3l-jpg  Compiled: FJ Springs Lift Info for 4th gen-ez4yachl-jpg
jweb4r is offline   Reply With QuoteReply With Quote
Old 06-29-2020, 06:19 PM #1437
J.
First page, original post. Not sure if this applies to the ultimate kit though. Toytec could probably clear that up for you.
Originally Posted by Toy4R4Me View Post
According to X6RUNNER:
The 2010 front FJ strut's lower joint needs to be modified in order to fit a 4Runner. The rear mounting hole (on the chassis) also need to be enlarged to fit the larger bushing washer. It can be done with some power tools.
Old 06-30-2020, 08:58 AM #1438
Heffernan's Avatar
Heffernan's Avatar
Just completed the swap over the weekend.
I deleted the XREAS system with 5100s all around. I left the rear springs stock and swapped just the fronts with new OEM 4x4 FJ springs. I set the clip on the bottom/stock setting. As noted from other members, I gained, pretty much, exactly an inch of lift with that combination.
If anyone is interested in doing this swap, I have a used set of front 4x4 FJ springs and a pair of brand new Wheelers 1/4" top out spacers I didn't end up using. Looking to sell to anyone who is interested.
Old 06-30-2020, 02:44 PM #1439
Jayson44's Avatar
Jayson44's Avatar
I had to get new LCAs and the Boss kit fits just fine in them. so I answered my own question, haha.
J.
Old 07-16-2020, 09:36 AM #1440
pmoneys pmoneys is offline
pmoneys is on a distinguished road
Got new OEM FJ springs and 5100s for my 05 V8. It has 245k on the original shocks and struts, so it will probably look lifted with everything at the lowest setting.
pmoneys is offline   Reply With QuoteReply With Quote
Compiled: Satoshi Build, Help & Picture Thread dgwood12 4th Gen T4Rs 76 08-11-2021 07:20 PM
Lift Info and FAQ thebwlife 5th gen T4Rs 1 05-25-2012 06:01 PM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
mixed info with 99 tall springs?? hdoggie24 3rd gen T4Rs 17 07-15-2010 04:48 PM
Leaf Springs-Prices/buying info '88 mountainman_gz Classic T4Rs 4 02-08-2009 01:28 PM
