Originally Posted by CarnivorousPrime
Found a set of FJ takeoffs in an FJ Forum. From I’ve read this should be a direct replacement with no modification for a 4th Gen 4Runner. Do I have the correct?
What type lift would I expect for my V8 if I were to go with this?
I'm not 100% sure about the amount of lift you'll get with the V8, I'd imagine about .5"~ less then a V6. If you find out, and are looking for a little more, I have a pair of .5" front spacers I'm selling that will help make up the difference, if you're interested.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
