Thread Tools Rating: Thread Rating: 10 votes, 4.20 average. Display Modes
Old 11-09-2020, 11:34 PM #1471
blackjackck's Avatar
blackjackck blackjackck is offline
Real Name: John
blackjackck will become famous soon enough
Real Name: John
Originally Posted by Tironeous View Post
Looks great! What year was the FJ? The off-road package shocks are Bilstens and look like 5100s (maybe there are) right? Was this a direct bolt on or did you need to modify anything? Thanks!
My FJ suspension were 08/09 Trail Team coil & Shocks. These were direct bolt on. No modifications what so ever. I got them new. You can read about it on my thread. It’s pretty pedestrian compare to the amazing members here.
2008 V6 4x4 Sports Edition / Build Thread/ FJ Off Road Package, 265/70/17, 2012 FJ Wheels, Husky Liner, LED bulbs, Spare Bumper -current////// SOLD Past vehicles:1996 V8 Landcruiser Rebuilt; 1988 Jeep Wrangler- 2 inch lift with 33' tires; 1976 Jeep CJ 7 (inline 6) - Frame off restoration
blackjackck is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 10:18 AM #1472
Heffernan's Avatar
Heffernan Heffernan is offline
Heffernan will become famous soon enough
Heffernan's Avatar
I've been toying with the idea of going up a setting on my 5100s, from 'stock' to the .85" setting. I have front FJ springs already (gained about an inch of lift) but I wanted to see if other members w/ FJ springs set to the .85" setting needed aftermarket UCA or a diff drop...? Also, any current ground-to-fender or hub-to-fender measurements would be great.
2008 Toyota 4Runner Sport V6
5100s / front 4x4 FJ springs / OEM stock rear springs
ToyTec 1/4" topout spacer & OME 10mm trim packer (both driver side)
General Grabber AT2 tires
Heffernan is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 03:11 PM #1473
zig553's Avatar
zig553 zig553 is offline
zig553 is on a distinguished road
zig553's Avatar
I did the FJ springs set at .85 with no diff drop or UCA and everything is good. The CV angles are pretty much level now. Not sure on measurements though. Tires are 265/70/17s as well.
Compiled: FJ Springs Lift Info for 4th gen-capture-jpg
zig553 is offline   Reply With QuoteReply With Quote
Old 11-12-2020, 03:15 PM #1474
Heffernan's Avatar
Heffernan's Avatar
Cool thanks for the reply. Is your 4Runner a V6 or V8?
Looks just about where I'd like to be.
Old 11-12-2020, 03:28 PM #1475
zig553's Avatar
zig553's Avatar
Mines a V8. I was actually expecting a bit more height on the front but I think the extra weight of the V8 is bringing it down a bit.
Old 11-12-2020, 03:32 PM #1476
Heffernan's Avatar
Heffernan's Avatar
Gotcha - Yea, I'm thinking since mine is a V6, I might have to add rear FJ springs for a little extra bump if I jump to the .85" setting. Right now my rear springs are stock, I just swapped out the shocks.
Old 11-23-2020, 01:19 AM #1477
nlau87 nlau87 is offline
nlau87 is on a distinguished road
Bilstein 5100 with stock coils
I have a 4th gen and installed Bilstein 5100’s with stock coils. Is this taboo? Should I get some FJ coils or am I good to go?
nlau87 is offline   Reply With QuoteReply With Quote
Old 11-23-2020, 08:28 AM #1478
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
You can run any coils you like if the look and ride is to your satisfaction. For example, I have 2015 Tacoma TRD Offroad coils on the front and FJ coils on the rear. See the suspension post linked in my sig to see a side-by-side pic of the FJ rear springs vs. stock and you'll see why many people swap them out.
Personally, I think many people overlook the need to change out the stock springs period regardless of what they're replaced with. They're made of stout metal, but the youngest 4th gen is 11 years old now and likely has 100+K miles. So no matter how stout, I think it's safe to assume that metal which has hauled around a 4500 lb. SUV for that long and that far probably isn't performing as well as it once did. People always go on about shocks, and they're important, but springs are just as important if not more so.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 01:52 PM #1479
freshedie92 freshedie92 is offline
freshedie92 is on a distinguished road
Wow thanks a lot for the sticky I was looking to do this and it has all the info i need.
freshedie92 is offline   Reply With QuoteReply With Quote
Old 12-28-2020, 04:51 PM #1480
702tripgen 702tripgen is offline
702tripgen is on a distinguished road
Curious as to why FJ springs are being used in the front of 4th gen Runners especially with V-8's and 5100's. The 5100's will allow you to raise ride height, and the FJ are all V-6's so wouldn't those springs have less load rating than the factory 4Runner V-8 Springs?
Are the rear FJ springs load rated higher or just generally longer than stock 4runner springs? Thanks
702tripgen is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 03:26 PM #1481
Heffernan's Avatar
Heffernan's Avatar
From my understanding the FJ springs have a higher spring rating. I did the 5100/FJ swap (leaving the perch on the bottom setting) and netted exactly 1" of lift with my v6. I plan on moving the perch up one spot to the .85" setting in the near future however.
Old 01-01-2021, 12:50 PM #1482
Heffernan's Avatar
Heffernan's Avatar
I treated myself to the final parts to complete my FJ/5100 lift. Brand new OEM rear springs and a ToyTec 1/4 topout spacer and a rear OME 10mm trim packer to correct the driver side lean.
Compiled: FJ Springs Lift Info for 4th gen-img_4198-jpg
Old 01-26-2021, 02:46 PM #1483
KeepingMy_ShirtOn KeepingMy_ShirtOn is offline
KeepingMy_ShirtOn is on a distinguished road
KeepingMy_ShirtOn is offline   Reply With QuoteReply With Quote
Old 02-11-2021, 10:59 PM #1484
BuzzardsGottaEat BuzzardsGottaEat is offline
BuzzardsGottaEat is on a distinguished road
Going to replace my tired 2006 4Runner (V8, 4x4) suspension with FJ coils and shocks.
For those who just did FJ coils/shocks (no spacers, no 5100s or non-OEM shocks) did you find a big difference in ride between the Tokico or Trail Teams or TRD shocks themselves?
I highly doubt anyone has run more than one of those options but it's worth an ask if any of you have insights on the differences in ride quality or other differences.
Just not sure which shocks I want to order. I have other vehicles for heavier off roading (99 4Runner and 93 Pickup). Our 4th Gen 4Runner and 1st Gen Tundra are just for lots and lots of highway miles and daily driving / car camping.
Any pros and cons between the different FJ shock options? Thank you!
BuzzardsGottaEat is offline   Reply With QuoteReply With Quote
Old 02-23-2021, 06:27 PM #1485
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Selling my FJ Springs if anyone is interested
https://www.toyota-4runner.org/for-sale-suspension-wheels-tires/295079-fs-fj-springs-$100-sacramento-ca.html
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Compiled: Satoshi Build, Help & Picture Thread dgwood12 4th Gen T4Rs 76 08-11-2021 07:20 PM
Lift Info and FAQ thebwlife 5th gen T4Rs 1 05-25-2012 06:01 PM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
mixed info with 99 tall springs?? hdoggie24 3rd gen T4Rs 17 07-15-2010 04:48 PM
Leaf Springs-Prices/buying info '88 mountainman_gz Classic T4Rs 4 02-08-2009 01:28 PM
