Thread Tools Rating: Thread Rating: 10 votes, 4.20 average. Display Modes
Old 01-08-2012, 12:01 PM #46
badgas's Avatar
badgas badgas is offline
badgas is on a distinguished road
badgas's Avatar
Originally Posted by ARK_SWAMP_RIDER View Post
Read the tire rubbing section of this page. 265/70/17 is the same size as what you're asking about. The bfgs may have more rubbing, but running fj wheels and not spacers should help. That'll give you a very good idea of what's needed.
Toyota 4Runner Wheel Spacers
Thanks Swamp
badgas is offline   Reply With QuoteReply With Quote
Old 02-24-2012, 12:17 PM #47
BReardon21
Guest
Posts: n/a
BReardon21
Guest
Posts: n/a
So I am looking at getting a set of 2011 FJ springs and then getting a set of 5100s all around.
I am thinking this should give me about 2" of lift in the front and .5" in the rear.
Do you think I would be able to fit 285s down the road? or will I have to throw top off spacers in? I already have 1.5" wheel spacers. Thanks guys!
Old 02-24-2012, 01:30 PM #48
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
You could fit them, would require a good bit of trimming. Here's what I would do if you're set on 285s. 5100s set at highest notch on the front. Use the fj coils all around and add the Daystar 1.5" rear spacer. The result would be approx a 3/2 lift. Would still need to trim . The Daystar spacer is $40 from 4wheelparts.com.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 02-24-2012, 01:49 PM #49
BReardon21
Guest
Posts: n/a
BReardon21
Guest
Posts: n/a
Ark,
You are the man. This is pretty much exactly what I am going to do. I just got 2011 FJ springs from the FJ forum for $75 shipped, going to buy new 5100s and throw them all around with the 1.5 daystar in the rear.
The only thing that sucks is I only have about 6k miles on my current tires. May hold off on the rear spacer and set front at .85 until I can upgrade tires. Or you think I should just bang out the 1.75 setting on the front right out of the box? I have the v8 with push bar and roof rack
Old 02-24-2012, 02:23 PM #50
Ark,
Totally up to you, I'd do the .85 if you like a little rake or 1.75 if you want it completely level. Will look good either way.
Great deal on those coils, shipping was probably nearly half of that.
Old 03-05-2012, 07:29 PM #51
ronsta's Avatar
ronsta ronsta is offline
ronsta is on a distinguished road
ronsta's Avatar
Anyone know which Daystar kit to use if I am going to swap my XREAS with the 2010 FJ bilstein suspension? Would it be the 9115 (for 4runner) or 9124 (for FJ) ?
2007 V6 SE 4WD Shadow Mica
Weathertech window deflectors, floor & cargo mats; 3M Clear Bra, front (wouldn't do again), Purolator PureOne 20195
RATEK 8000k HID low & fog, Gentex 453 Auto Dim HomeLink AMBER Compass Mirror; Rubber: 265/70/17 Yokohama Geolandar A/T-S installed 1/14/11, Denso IKH20 spark plugs (6) installed at 60k miles; HCF delete
ronsta is offline   Reply With QuoteReply With Quote
Old 03-05-2012, 07:51 PM #52
Either should work (my guess, no experience here). From what others have said, the difference between the 2007-2009 and 2010+ is the shocks, not the coils. Quite a few have interchanged the kits between the FJ and 4runner with no issues. I wouldn't expect this to be any different, so I'd go with whichever is cheaper. Don't hold me to this, but from my understanding of other folks setup this should work.
Old 03-05-2012, 07:57 PM #53
ronsta's Avatar
ronsta's Avatar
ARK: thx anyway, I guess i'll order them both and see what the diff is. Any updates on the swap chart ? I'd like to know how much lift I'll get with the bilstein shock/spring setup without the daystar. If it's enough then I might just forget about the DS.
Old 03-05-2012, 08:12 PM #54
No updates yet...busy weekend.
Expect 1" front, .5" rear. Your results should be with .25" of that. I'd do that with the Toytec 1" spacer. The Daystar will probably be a little much.
Old 03-17-2012, 06:35 AM #55
cgarrett5119 cgarrett5119 is offline
cgarrett5119 is on a distinguished road
Is there a difference between 2010 FJ springs and 2007 - 2009 FJ springs or is there just a difference in the shocks given those years?
cgarrett5119 is offline   Reply With QuoteReply With Quote
Old 03-17-2012, 08:51 AM #56
Both are a direct swap, but I've heard the 2010+ are a little beefier that the earlier ones.
Old 03-17-2012, 01:04 PM #57
So I can run 2010 springs on the 07 - 09 shocks? Thanks for the info.
Old 03-17-2012, 01:16 PM #58
They should, don't see any reason they wouldn't.
Old 03-28-2012, 01:23 PM #59
BReardon21
Guest
Posts: n/a
BReardon21
Guest
Posts: n/a
I decided against 285's right off the bat as my current tires are pretty much brand new.
I am most likely going to opt out of the rear spacer as well at this time and just take the inch or so lift I will get out of the rear springs. I think the spacer would make it look a bit awkward without 285's.
In the front I am torn between 0.85 setting and 1.75 on the 5100s. I don't want any bro lift but also want the truck to sit level and not have as much rake, so it looks more aggressive. I am personally thinking with a 4wd, v8, a Push Bar, and roof rack that 1.75" is the logical choice to level everything out. This way if I decide to add 285's later I will not have to disassemble the strut, I can just add top off spacer in the front and 1.5 rear spacers. Anyone experience any differences in the ride between 0.85 & 1.75? Will this cause the shock to wear faster?
I am still trying to search around and find a few pictures of a set up with FJ coils and 5100s all around on 1.75". Thanks in advance for everyone's input!
Old 03-28-2012, 04:58 PM #60
crackiswack's Avatar
crackiswack crackiswack is offline
crackiswack is on a distinguished road
The 1.75" setting on the 5100's gives more lift than it states, like 2.5-3" IIRC, combined with the addition 0.5-1" from the FJ's and you are looking at 3-4", if you aren't lifting the rear, stick to the 0.85" setting with the FJ's
crackiswack is offline   Reply With QuoteReply With Quote
Compiled: Satoshi Build, Help & Picture Thread dgwood12 4th Gen T4Rs 76 08-11-2021 07:20 PM
Lift Info and FAQ thebwlife 5th gen T4Rs 1 05-25-2012 06:01 PM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
mixed info with 99 tall springs?? hdoggie24 3rd gen T4Rs 17 07-15-2010 04:48 PM
Leaf Springs-Prices/buying info '88 mountainman_gz Classic T4Rs 4 02-08-2009 01:28 PM
