Thread Tools Rating: Thread Rating: 10 votes, 4.20 average. Display Modes
Old 01-11-2019, 10:45 AM #1351
Sharkseed Sharkseed is offline
Sharkseed will become famous soon enough
Originally Posted by ELock3rdGen View Post
Will the adjustable tundra Burstein 5100 we used in our 3rd gen fit our 4th gen? Assuming I get new springs? Reason I ask is I put in some new 5100 on my 3rd gen a few month back but now I'm debating on selling it. I already have a 04 4runner v8 so of it was compatible I was going to take them off and use them on the 4th gen.
Yes it will fit
Sharkseed is offline   Reply With QuoteReply With Quote
Old 01-11-2019, 11:13 AM #1352
ELock3rdGen ELock3rdGen is offline
ELock3rdGen is on a distinguished road
Originally Posted by Sharkseed View Post
Yes it will fit
Thanks!
1998 4Runner. AVS wind visor. Yakima LoadWarrior. Optima Yellow top. Trail Gear battery holder. Big 3 upgrade. Tundra brake upgrade. Tundra TRD front coil. Toytec Superflex with Tundra 5100 Bilstein rear. Complete Alpine audio system. FJ Trail Gear rim.
ELock3rdGen is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 05:01 PM #1353
MotherPrometheus MotherPrometheus is offline
MotherPrometheus is on a distinguished road
fJ Springs with Bilsteins 5100
So Im in the process of installing FJ Springs with Bilstein 5100 Shocks. I've set the Bilsteins at 1.75 and now the springs are so compressed I cant jack up the control arm, the springs don't want to compress any more and when trying to jack up my lower control arm, the whole truck lifts and the shock and spring wont compress any further. Thoughts?
MotherPrometheus is offline   Reply With QuoteReply With Quote
Old 01-28-2019, 03:03 PM #1354
Rodtheviking's Avatar
Rodtheviking Rodtheviking is offline
Real Name: Chris
Rodtheviking will become famous soon enough
Real Name: Chris
Spring seat on upside down?
2005 V8 Limited. ARB Bumper, ARB Touring rack, Bilstein 5100 with Toytec 3" Tacoma springs, OME 2895's, 255/80 Cooper ST Maxx. TG spacers. JBA UCA.
Rodtheviking is offline   Reply With QuoteReply With Quote
Old 02-27-2019, 12:07 PM #1355
crete01 crete01 is offline
crete01 is on a distinguished road
XREAS is shot....
The rides been getting rougher and rougher, and found my XREAS is leaking at the central control module on both sides on my 06 Sport 4WD V6. 130k miles. I plan on ripping it out and therefor, need to replace all my shocks. Figure I'd do the coils as well.
After reading a lot (wow, this forum is an incredible resource), I think I'm going to do the 5100s with Moog Coils, with new KYB shock mounts, but am currently looking at the 4runner Moog coils (81045-back and 81090-front). I'm only on dirt roads/mountain roads occasionally but this is more of our play vehicle, so I'd like about 1.5"-2" of lift, and would like to level out the front which has horrible sag right now. My current plan is to do a Daystar 1.5" spacer in the back and set the 5100s on 1.75" in the front. From what I've seen, that (with new springs) does a pretty good job leveling things out. The Moog 4R coils have about .5" more height than OEM.
Now I'm wondering if I should do the Moog FJ coils (81081) in the rear instead and skip the spacer, which according to a coil rate chart that I found here, which have 1.2" most coil height to them, but also appear to have a lower spring rate than the 4Runner Moog coils. Any thoughts? I've read that the Moog FJ coils don't fit well in the rear and require modifications.
As I mentioned before, we mainly use the 4runner for going up canyon roads in the winter, fire/dirt roads in the summer for backpacking/climbing, and occasionally will take it to Moab on some rougher roads, but never do anything that a stock vehicle wouldn't be able to get through. Some extra clearance and a fresh ride is really all I want.
crete01 is offline   Reply With QuoteReply With Quote
Old 02-28-2019, 12:36 AM #1356
SCY7H3 SCY7H3 is offline
SCY7H3 is on a distinguished road
Alright so this past weekend I finally pulled the trigger and did my upgrade. I chose to stick with the stock 2007-2009 FJC Tokico shocks and the 2010+ FJC coils and wow, what a difference it made in handling.
No more bottoming out (front end) over speed bumps at very low speeds, no more feeling the imperfections of the road at any speed either.
Cornering definitely improved. Braking and accelerating also feels tighter now. Before I could feel the truck tilt when braking and accelerating.
Before the "upgrade" I could tilt the truck side to side and it would wobble a few times but now it wobbles maybe twice and then stops.
Here's some before and after measurements from the ground to the bottom of each fender. The difference from left to right was really tiny, like 1/16" in both before and after which is why the measurements look perfect.
Before Upgrade: Stock OEM T4R Limited Suspension on V6 4WD
Front Left: 32 3/4"
Front Right: 32 3/4"
Rear Left: 35 1/4"
Rear Right: 35 1/4"
After the Upgrade: 2007-2009 FJC OEM Tokico Shocks and 2010+ FJC coils
Front Left: 33 3/4"
Front Right: 33 3/4"
Rear Left: 35 3/4"
Rear Right: 35 3/4"
Front Difference: 1" gain
Rear Difference: 1/2" gain
I'm really happy with the results and wasn't looking to raise it much as it is mostly always driven in the city. It's been about 11 years on the old suspension and about 90k miles.
There was nothing special I needed to do in order to have the two different years of FJC parts work. Everything bolted up just fine.
For those who are curious or interested in this mod, I listed the shocks and coils below.
PARTS LIST:
Front Shock (Left/Right): 48510-80397
Front Coil (Left): 48131-35670
Front Coil (Right): 48131-35660
Rear Shock (Left/Right): 48530-80461
Rear Coils (Left/Right): 48231-35420
This concludes the chapter of this upgrade on my T4R. Thanks for all the information from everyone.
SCY7H3 is offline   Reply With QuoteReply With Quote
Old 03-06-2019, 02:45 PM #1357
Small update, ordered the 5100s and some other parts. Ended up getting the Moog FJ coils for the front, and the Moog T4R coils for the rear. Both arrived horribly packaged, with each coil having at least 10+ chipped sections throughout the powercoat or whatever the finish is. They are scratched to the point where it looks like they have almost been installed before. I've order paper towels that came with more protective packing...
Decided to return all of the coils, including the 1.5 rear spacer, and am going to bite the bullet and go for the T1/T12 coils, with only a 1/4" spacer on the FL to level out the driver's sag based on: . I thought about doing the OME stuff, but the heavier spring rate, combined with some comments around here about the valving for 5100s not playing the best pushed me towards the Wheeler's stuff.
Will update when everything arrives!
Old 03-18-2019, 03:59 PM #1358
4RUNNINGNY 4RUNNINGNY is offline
4RUNNINGNY is on a distinguished road
Can somebody confirm if I have the correct springs and spacer? I have a 4WD 2006 4runner. I ordered the 5100 4Runner/FJ and KYB 4Runner/FJ front strut mount already and looking to pair up the springs and rear spacers.
I found the MOOG coil springs cheapest on ebay as of right now (Please feel free to chime in if somebody has found them cheaper somewhere else!)
Front:
Front Constant Rate 660 Coil Spring Set Moog For Toyota FJ Cruiser Tacoma 4WD | eBay
Rear:
Moog Coil Spring Set For 2007-2010 Toyota FJ Cruiser 81081 | eBay
Rear 1.5 Daystar spacer
Daystar, Toyota FJ Cruiser 1.5" Rear Lift Kit, fits 2007 to 2014 2/4WD, all t... 814423011006 | eBay
Thanks in advance guys!
4RUNNINGNY is offline   Reply With QuoteReply With Quote
Old 03-18-2019, 10:34 PM #1359
Frontier4Runner's Avatar
Frontier4Runner Frontier4Runner is offline
Real Name: Chad
Frontier4Runner is on a distinguished road
Real Name: Chad
Front:
Rear:
I think you can beat those prices at Advance Auto Parts - they will almost always give you 25% off if you throw them in the cart and then wait a day. But even at that with the 15% code at the top of the site you'll be a few bucks ahead I bet
2008 4Runner SR5 V6 - Bilstein 5100 (0.85) w/ MOOG FJ Springs - 255/70R17 Goodyear Wrangler TrailRunners - Rola Rack w/ extension - Pioneer AVH-2300NEX - Canvasback Cargo Cover - WeatherTech mats
Frontier4Runner is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 06:18 AM #1360
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
@4RUNNINGNY , IIRC, Daystar is among the few manufacturers whose specs indicate the thickness of the spacer, not the lift gained, which is double the spacer thickness. I’m not sure if the geometry is the same front & rear but in the front, my understanding is that a 1.5” spacer gives you 3” of lift. Can someone with a deeper knowledge than mine confirm that this is also true for the rear?
If so, just be aware that with Daystar gear, you’ll be lifting the rear 3”, not 1.5.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 12:01 PM #1361
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Rear is 1 to 1.
So the rear at 1.5" = 1.5".
Your just lifting straight up at the coil.
Front is almost 2 to 1...or just under.
Front at 1.5" = just under 3"... in theory. 2x1 ratio. has to do with the geometry ratio with the A-arms. Think of it like a lever.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 03-19-2019, 01:39 PM #1362
Bluesky 07's Avatar
Bluesky 07's Avatar
Originally Posted by BackOff View Post
Rear is 1 to 1.
Thanks for clarifying that.
Old 03-20-2019, 12:08 AM #1363
Thanks for that info guys! Definitely saved a bit using Advance auto parts. One thing to keep in mind is that they charge tax and eBay did not.
Old 04-11-2019, 06:05 PM #1364
sport2004's Avatar
sport2004 sport2004 is offline
Real Name: James
sport2004 is on a distinguished road
sport2004's Avatar
Real Name: James
Front:
Rear:
Are those the rear springs that need a mod to get to seat corectly?
Regards, sport2004
Gotta Start Somewhere 2004, V6 Sport 4WD (French Speaking), All LED interior lights, LED reverse lights, Weathertech-laser cut floor mats up front, 2nd row Weathertech-laser cut floor mats , OEM Extreme cargo liner, 4LO aint hap'nin
sport2004 is offline   Reply With QuoteReply With Quote
Old 07-08-2019, 03:41 PM #1365
Wally517 Wally517 is offline
Wally517 is on a distinguished road
So let me get this straight, FJ Cruiser springs from 2012 WILL fit a 4th gen 4Runner but the actual OEM shocks will not?
Wally517 is offline   Reply With QuoteReply With Quote
Compiled: Satoshi Build, Help & Picture Thread dgwood12 4th Gen T4Rs 76 08-11-2021 07:20 PM
Lift Info and FAQ thebwlife 5th gen T4Rs 1 05-25-2012 06:01 PM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
mixed info with 99 tall springs?? hdoggie24 3rd gen T4Rs 17 07-15-2010 04:48 PM
Leaf Springs-Prices/buying info '88 mountainman_gz Classic T4Rs 4 02-08-2009 01:28 PM
