Thread Tools Rating: Thread Rating: 10 votes, 4.20 average. Display Modes
Old 12-21-2010, 04:07 PM #1
Toy4R4Me's Avatar
Toy4R4Me Toy4R4Me is offline
Toy4R4Me is on a distinguished road
Toy4R4Me's Avatar
Arrow Compiled: FJ Springs Lift Info for 4th gen
Edit by Mod: Due to the popularity of this swap with 4th gens I am going "stick" this thread. Another very helpful resource for those considering the swap can be found here: http://www.toyota-4runner.org/suspen...e-fj-swap.html CJ3Flyr
So, I just did the FJ spring lift and found myself running all over the place to find the information I needed. I've been on many other forums and most others make a lot more use of Stickies for this kind of information that's widely requested. I don't know if we try to keep the number of stickies down or what, but if a mod sees fit to sticky this, that would be great.
Anyways, on to the info. (Disclaimer: I am just organizing information here so it is easy to find, not claiming any of this as my own)
The parts:
You'll need a set of stock FJ cruiser springs, which many members get from Craigslist, eBay, or the FJ community classifieds
any set from an 07-09 4x4 FJ will be a direct replacement for any 03-09 4runner, but those from 2010's require some slight modification. 2WD springs will fit as well, but will not yield the same results.
According to X6RUNNER:
The 2010 front FJ strut's lower joint needs to be modified in order to fit a 4Runner. The rear mounting hole (on the chassis) also need to be enlarged to fit the larger bushing washer. It can be done with some power tools.
The FJ has 3 models, all with different shocks. The base model has Tokico shocks. The Trail Teams and TRD both have Bilsteins, although the shocks are different between the two. The Bilstein's are definitely preferred, but any of them are an upgrade based on the responses I've seen.
It is important to note that there is a difference between the driver and passenger side front springs. The drivers side is about 1/4'' taller and a little stiffer to offset the additional weight of the driver and gas tank. The springs are color coded Yellow/Green on driver side and Gray/Green on the passenger side.
Most people who do this lift add a spacer to the front springs to "level" the truck. There are two ways people define level. First is having the running boards and roof rack level, which is what most prefer and what the following setups should achieve. Others go for equal space between the tire and fender (takes more lift to achieve this). So, if you're a v6 owner wanting equal space between the tire and fender, the 1/2" spacer may need to be considered.
The 1/4'' toytec spacer (1/2'' net lift) is suggested for a v6 runner and the 1/2'' spacer (listed as 3/4'' lift, but actually yields 1'' net lift) for the v8. The cornfed 1'' lift front spacer yields similar results to the toytec 1/2'' spacer. Some also add a full spacer lift on top of the springs such as the cornfed 2/1 or the Daystar 2.5/1.5 to give some extra height.
If you have a 2wd (v6 or v8), the 1/4" spacer is recommended. The FJ springs provide more lift on 2wd's than 4wd's.
toytec 1/4'' spacer
toytec 1/2'' spacer
popular lift installation write-ups
Note: this lift can be done with XREAS; it is highly suggested that you leave the hydraulic lines connected to the shocks/struts and work on them in the wheel well because if you lose fluid from the system it is ruined. However, there are ways to disconnect the XREAS if you so desire.
Many people (including myself) have used and suggest the no spring compressor method for the install.
No Spring Compressor Method
but here are two others just for variety
Daystar (Spacer) installation on 4Runner with XREAS - Toyota 120 Platforms Forum
2007 Toyota 4Runner Sport Edition Lift
Expected Lift
The FJ springs alone net about .5-1'' in the front and .25-.75'' in the rear. 1/2" front is more common on v8 4runners. On 2wds (v8 or v6) and v6 4x4 1" is about average. Most models get about 1/4" from the rear, but some do get as much as 3/4". This difference is what makes it so difficult to suggest an exact setup, there are way too many factors to consider when swapping out the springs. Mainly, all of our 4runners have sagged different amounts on the stock suspension, same for all the FJ's. So, the lift gained depends on how much use your stock springs have and also how much use the FJ springs you have sagged.
Also, many members have been impressed by the change in ride quality. The FJ springs are stiffer, reducing body roll and brake dive. However, the ride is far from harsh and many prefer it to stock.
Pictures
gaterose: V6 2WD FJ springs w/ 1/4'' toytec spacer 265/65 stockers
My V8 4x4 w/ FJ springs and 1/2'' toytec spacer 265/70 BFG ATs
EDness: fj springs with cornfed 1'' spacer
zstamp: fj springs with daystar 2.5/1.5 and 265/70 hankooks
PharmSCRunner: fj springs with cornfed 2/1
and there are probably countless other combinations out there, but these should give you the basic idea.
[Additional comments by ARK_SWAMP_RIDER have been added]
Acknowledgments:
ARK_SWAMP_RIDER's write up
CJ3Flyr's write up
'05 Sport V8 4x4, Weathertech Floor Liners, Husky rear cargo mat, '06 JBL Headunit w/ AUX Input, Toyota Faux Skid Plate, 265/70/17 BFG AT's, PIAA Ion Crystal 520's, FJ springs w/ toytec 1/2'' spacer.
Toy4R4Me is offline   Reply With QuoteReply With Quote
Old 12-21-2010, 04:31 PM #2
gaterose's Avatar
gaterose gaterose is offline
Real Name: Matt
gaterose will become famous soon enough gaterose will become famous soon enough
gaterose's Avatar
Real Name: Matt
Missing photo from above @ARK_SWAMP_RIDER
Another popular option:
FJ springs + Bilstein Adjustable set at 0.85"
265/70R17 BFG AT T/A KO (also spidertraxx 1.25" spacers)
2017 Tacoma TRD OR - His
2014 4Runner Limited - Hers
'13 Silverado Z71 - Sold
'03 4Runner UnLimited - Sold
gaterose is offline   Reply With QuoteReply With Quote
Old 12-21-2010, 04:53 PM #3
Hi-Fi Hi-Fi is offline
Hi-Fi is on a distinguished road
Thanks! Hope to do the front of mine to level it out some this spring.
I'm in the market for springs if anybody has a set they want to sell.
Bill
Hi-Fi
KF9EZ, 2005 T4R SE V8, Husky liners in front, Scangauge II, Michelin LTX A/T2 LT265/70R17E
Hi-Fi is offline   Reply With QuoteReply With Quote
Old 12-21-2010, 10:48 PM #4
ARK_SWAMP_RIDER's Avatar
ARK_SWAMP_RIDER ARK_SWAMP_RIDER is offline
ARK_SWAMP_RIDER will become famous soon enough ARK_SWAMP_RIDER will become famous soon enough
That's got most of the basics down. Here are a few notes (no particular order):
There are two ways people define level. First is having the running boards and roof rack level, which is what most prefer and what the listed setups should achieve. Others go for equal space between the tire and fender (takes more lift to achieve this). So, if you're a v6 owner wanting equal space between the tire and fender, the 1/2" spacer may need to be considered.
The Toytec is a 1/2" thick spacer, listed to give 3/4" lift. In reality, you get 1" from it. The Cornfed 1" spacer gives identical resuls, as both use 1/2" of material.
From what I've seen, most with v8's gain ~1/2" from the spings in the front, 1/4" in the rear and most v6's gain ~1" front and 1/4" rear. Some have gotten more, some less, it strictly depends on how worn the stock suspension is.
You want the shock/coils off of a 4x4 FJ, the 2wd ones are different (will fit, the 4x4 ones are preferred though for the most improvement).
That's all I can think of for now, I'm sure something else will come up later.
2003 Limited V8 - sold - Build Thread | JL Audio amp/sub | Icon stage 2 | 1/2" Body Lift | 265/70/18 Nitto TG G2's | 18" Limited wheels | Spidertrax | Clazzio's
2016 Trail Premium - Bilstein 5100 | Airlift 1000 | 285/70/17 Cooper AT3 4S | XenonDepot HID | RAV4 Blindspot Mirrors | Kicker Subaru Tweeter Upgrade | Lock'er Down Console Safe | Sprint Booster
ARK_SWAMP_RIDER is offline   Reply With QuoteReply With Quote
Old 12-22-2010, 12:10 AM #5
zstampe's Avatar
zstampe zstampe is offline
zstampe is on a distinguished road
zstampe's Avatar
Awesome thread! Thanks for including my truck as well. If anyone has any questions about my truck pm me. I also just got done fabbing a new light bar up with 2 Hella 500's on it. Will post pics soon
2006 SR5 4x4 My build: http://www.toyota-4runner.org/4th-ge...ml#post1104330
"We're the middle children of history man. No purpose or place. We have no great war, no great depression. Our great wars a spiritual war....our great depression is our lives. We've all been raised on television to believe that one day we'd all be millionaires, movie gods or rock stars. But we won't. And we're slowly learning that fact....."
zstampe is offline   Reply With QuoteReply With Quote
Old 12-22-2010, 01:42 AM #6
Toy4R4Me's Avatar
Toy4R4Me's Avatar
gaterose and ARK, thanks for your input, your comments have been added to the initial post.
ARK - are you sure about the average lift numbers? Before doing the lift I was under the impression that 1'' front .75'' rear was the general consensus? It was almost exactly what I got, too.
Old 12-22-2010, 02:49 AM #7
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
Great thread. Thanks for putting in the time.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 12-22-2010, 10:35 AM #8
I've not written down the numbers and averaged them, so no not 100% sure. That's just the best I can remember what most have gotten. Some have gotten the amounts you listed, but from what I remember 1/2" front is more common on v8 4runners. On 2wds (v8 or v6) and v6 4x4 1" is about right for the average I'd say. I do think all models get about 1/4" from the rear, but I have seen some get 3/4". This difference is what makes it so difficult to suggest an exact setup, there are way too many factors to consider when swapping out the springs. Mainly, all of our 4runners have sagged different amounts on the stock suspension, same for all the FJ's. So, the lift gained depends on how much use your stock springs have and also how much use the FJ springs you have sagged.
I'd prefer to state lift gained as a range between the numbers I posted and the numbers you posted, as that's much more accurate than saying one specific number.
I've wanted to compile a spreadsheet with members names, setups, and lift gained for reference, but I've not had the time lately.
Also, don't forget to check your local craigslist for the FJ shocks/coils, I've seen some good deals there from time to time.
Old 12-22-2010, 11:20 AM #9
MSBX4RUNNER MSBX4RUNNER is offline
MSBX4RUNNER is on a distinguished road
I got about 1" in the front and .75" in the rear with the FJ coils and Bilstein5100s and I have 2WD.
2005 4Runner SportEdition V8: Bilstein5100s, FJC Coils front/rear, BFG All Terrain 265/70R17s, Yahkima FatCat 6, Scion t1809 HU, WeatherTech DigitalFit floormats front/rear/cargo
MSBX4RUNNER is offline   Reply With QuoteReply With Quote
Old 12-22-2010, 11:32 AM #10
Toy4R4Me's Avatar
Toy4R4Me's Avatar
Gotcha, your comments have again been added. Let me know if you ever do that spreadsheet. I think that would be very helpful for those looking for a specific setup.
Also, does anyone know how I might go about getting this thread stickied? It feels like every fourth thread is someone with an FJ lift question that this thread could hopefully answer.
Old 12-22-2010, 11:38 AM #11
message's Avatar
message message is offline
message is on a distinguished road
message's Avatar
Excellent right up guys!
message is offline   Reply With QuoteReply With Quote
Old 12-22-2010, 12:55 PM #12
8086bruce 8086bruce is offline
8086bruce is on a distinguished road
Great info and good write up. I did the fj springs and bilsteins with the 1/4 spacer on my 07 V6 and love it.
2024 Limited Windchill Pearl/ 1" cornfed front spacer/ 275/55R20 Toyo AT3
8086bruce is offline   Reply With QuoteReply With Quote
Old 12-22-2010, 01:00 PM #13
Old 12-22-2010, 10:47 PM #14
EDness's Avatar
EDness EDness is offline
EDness is on a distinguished road
EDness's Avatar
Great info! Thanks for the write up.
EDness is offline   Reply With QuoteReply With Quote
Old 12-22-2010, 11:27 PM #15
4RBob 4RBob is offline
4RBob is an unknown quantity at this point
"any set from an 07-09 4x4 FJ will be a direct replacement for any 03-09 4runner, but those from 2010's require some slight modification"
what is the required modification for the 2010 FJ springs? btw - I am going to try the 2010 FJ TT springs/shocks on a 5th Gen 4R.
thanks
2003.5 4Runner Sport, V8, Galactic Gray, Cornfed 1" front & 3/4" rear, Bilstein 5100's, FJ Cruiser wheels, 265/70/17 Firestone AT's
2010 4Runner Trail, Magnetic Grey, PIAA horns, FJ TT coils/shocks, Daystar front pre-load spacers, 265/70/17 Firestone AT's
4RBob is offline   Reply With QuoteReply With Quote
Compiled: Satoshi Build, Help & Picture Thread dgwood12 4th Gen T4Rs 76 08-11-2021 07:20 PM
Lift Info and FAQ thebwlife 5th gen T4Rs 1 05-25-2012 06:01 PM
Front FJ Springs gave me a touch more lift than 4runner springs and DS Budget Boost! clemsonxplorer 4th Gen T4Rs 12 08-20-2010 09:11 PM
mixed info with 99 tall springs?? hdoggie24 3rd gen T4Rs 17 07-15-2010 04:48 PM
Leaf Springs-Prices/buying info '88 mountainman_gz Classic T4Rs 4 02-08-2009 01:28 PM
