Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Old 07-20-2018, 11:56 AM #271
swegen's Avatar
swegen swegen is offline
swegen is on a distinguished road
swegen's Avatar
MOOG springs 81083 81108 with 5100 shocks installed
No mods required - done at local Midas muffler shop.
shocks installed with circlip at first lift groove .85" ?
2008 Limited V8 looks perfectly level
Thanks
Swegen
2008 4runner LTD V8
60193
swegen is offline   Reply With QuoteReply With Quote
Old 07-20-2018, 01:07 PM #272
pw211 pw211 is offline
pw211 is on a distinguished road
Awesome thanks for the quick response
pw211 is offline   Reply With QuoteReply With Quote
Old 09-21-2018, 11:51 AM #273
Roody Roody is offline
Real Name: Ross
Roody is on a distinguished road
Real Name: Ross
Anybody running 255/85/16s with the FJ springs? Any rubbing?
2005 4R - "The Stormtrooper"
OME 3" lift; SPC UCAs; bumper; rack; sliders; skid; snorkel; 255/85/16 KM2s; steelies; CB; tucked exhaust, etc
2018 4R TRD Off Road Premium
Stock ...for now
hooniverse.com
Roody is offline   Reply With QuoteReply With Quote
Old 07-19-2019, 07:30 PM #274
impervious17 impervious17 is offline
impervious17 is on a distinguished road
I just did the swap. The rear springs are not sitting correctly. What did everyone do to make them sit properly? Did you guys cut the spring or use a prybar?
If using the prybar method how do I do it exactly?
impervious17 is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 05:11 AM #275
MY06T4R's Avatar
MY06T4R MY06T4R is offline
Real Name: @professorj2
MY06T4R is on a distinguished road
MY GARAGE
MY06T4R's Avatar
MY GARAGE
Be the judge
I did mine last year, I used Moog 81081 2009 fj rear springs $57 and 07-09 fj DTA 70020 quick struts and rear shocks $169 and did a supreme suspensions 3" front 2" rear spacer lift $165. All purchased on Amazon and installed by me, I eliminated the xraes factory suspension.
4th gen- For all who've done the FJ swap....-my06t4r-albums-my-06-4runner-picture55789-before-fj-struts-springs-lift-spacers-jpeg  4th gen- For all who've done the FJ swap....-my06t4r-albums-my-06-4runner-picture55398-fullsizeoutput-520-jpeg
06 V8 SPORT, 3" SUPREME SUSPENSION LIFT, JBA UPPERS, DIFF DROP, SWAY BAR DROP & RELOCATE, 2010+ POWER STOP CALIPERS, ENERGY SUSPENSION BUSHINGS THROUGHOUT, GIBSON ELITE STAINLESS CATBACK WITH BLACK TIP, URD FUEL PUMP WITH EXTERNAL FILTER, K&N, & MORE
MY06T4R is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 08:31 AM #276
pjbrownva's Avatar
pjbrownva pjbrownva is offline
Real Name: Phil Brown
pjbrownva is on a distinguished road
pjbrownva's Avatar
I did mine a couple of years ago, so -- quite truthfully -- my memory is a bit fuzzy.
I know that after I finished, I went to a local garage, and cut a deal to pay one 1 hr of labor (plus a tip for the mechanic) to have the mechanic help me. If I recall correctly, I think I had trouble with the "pan hard bar" ... of that's what it's called. It was a diagonal bar on the rear suspension. The mechanic pulled out some very long pry bars, and we used a combination of finesse and brute strength to get it to seat properly.
There may be a better method, but I haven't learned it.
One thought... and I don't know if it will help, or be a waste of time... is to consider going to a big chain autoparts store that does free loaner tools, and borrowing a spring compressor from them.
BE CAREFUL WITH SPRING COMPRESSORS... you can get hurt if they slip off.
By me, two large chains lend tools. When you want to borrow the tool, they give you a kit, and charge you a price for the tool kik (often $100 to $150)... but then you have a long time (30 or 60 days... I don't recall) to return the used tool for a full refund. It's not the same as abusing a return policy. They really are meant to be loaner tools (in fact, they usually are used when you get them). They charge you and give you a refund as their way of making sure that they get the tool back.
Two words of caution. First, don't lose any pieces or small parts, or you may find that you bought the kit. Second, at one location, the manager asked me to take a call phone photo of the open box with all of the kit parts and keep the photo on my cell phone -- just in case there were any questions upon return, I could show the photo to have a record of what was there when I picked up the kit.
If my memory serves me correctly, when I did the install myself, I had a spring compressor... the kind that looked like a very long screw with two knuckles on it, that grabbed the spring, and then you tightened it to compress the spring. There were two of these items, and I had nothing but trouble with them. The popped off several times, and at other times, once I got them in place, I couldn't release them to get the back off.
My final solution was putting the whole truck on jack stands, releasing the pan-hard bar (if that's the name... the diagonal one), and getting a friend to help.
With him standing on the axel, and some pry bars and elbow grease, I finally got it mostly in place.
Later, with the help of a pro, I was able to rotate the spring to get it seated completely correctly, and fix a few areas that weren't quite right.
Before that, I had tried several hours of work solo, and didn't get very far... for me at least, it turned out to be a two person job.
Here are some images of compressor spring kits that are available to rent near me.
The first image didn't work for me... although NOW that I read it, it seems to be made to compress the spring on struts (not sure that I'd trust it for that... I used the no-compressor trick written up on this forum... it's one where you use a jack to compress and slowly decompress the lower control arm, so you end up slowly and carefully releasing and then recompressing the strut coil without using any type of tool... just the weight of the vehicle, and some jacks... for the struts, I'd prefer to pay a shop to compress them, rather than use some cheap kit that I've never used and risk getting hurt).
The second one I would tend to favor, as I prefer having a flat piece or a disc shaped piece inside the coil spring, and I suspect it would make it easier to remove.
I would suspect that the third kit might be hard to remove one the spring is in place, but your experience may differ.
I can't recall if I had the spring compressed at all when my friend helped me, or whether we just muscled them in. I do recall releasing the pan-hard bar, and having him stand on the rear axel to open up space for me. I also recall having to watch the line on the brake calipers... but I don't remember if there were any connectors I had to loosen or other tricks to give me some more length. I also don't recall whether I had to mess with the brake calipers to give me more room to move the axel, or whether everything was OK.
If anyone has a better, more sane way of replacing the rear coil springs, I'm all ears. I'll confess that I didn't do a lot of reading or research on the procedure before attempting it.... that's now become a standard practice for me, since it can save soooo much time! :-) Good luck, and let us know what you learn or find out.
4th gen- For all who've done the FJ swap....-spring-compressor-1-jpg  4th gen- For all who've done the FJ swap....-sping-compressor-2-png  4th gen- For all who've done the FJ swap....-coil-spring-kit-2-png
pjbrownva is offline   Reply With QuoteReply With Quote
Old 07-20-2019, 10:18 PM #277
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 is a jewel in the rough Bluesky 07 is a jewel in the rough Bluesky 07 is a jewel in the rough Bluesky 07 is a jewel in the rough
MY GARAGE
Bluesky 07's Avatar
MY GARAGE
What exactly is the issue? You may know this but the lower spring mount has a stop and the spring has to be placed so that the end of the spring is against the stop. Scroll down in this post to the part about the rear springs to see pics of what Iím talking about.
Bluesky 07 is offline   Reply With QuoteReply With Quote
4th Gen owners who were 3rd Gen owners, suspension question RickC 4th Gen T4Rs 18 11-27-2015 07:06 PM
3rd Gen vs. 4th Gen domstriker 4th Gen T4Rs 20 01-17-2011 09:13 PM
Supercharged 3rd gen vs 4th gen? bxc13 4th Gen T4Rs 5 03-06-2005 02:24 AM
Copyright ©2000 - 2019, vBulletin Solutions Inc.
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Lite) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
Copyright © 2019
