Thread Tools Rating: Thread Rating: 4 votes, 4.75 average. Display Modes
Old 03-20-2013, 10:51 PM #31
emelianenkov's Avatar
emelianenkov emelianenkov is offline
Real Name: Alex
emelianenkov is on a distinguished road
Real Name: Alex
Originally Posted by ddnww View Post
can i use a 3 post switch to do this mod.. i have a fj switch and a touch sensing switch.. both are 3 prong
As long as one goes to the negative and one goes to the positive you should be ok!
-07 FJ Cruiser 6MT. 185k. Camburg 3.5" Long Travel.
-17 Subaru WRX STI. 305AWHP/311AWTQ. Warranty delete.
-13 Subaru Crosstrek CVT. / 05 Subaru Outback limited 5MT. Flip project.
-99 Ford F-250 Super Duty Lariat 4x4. 7.3 PowerStroke. SCLB.
-93 Toyota Pickup Crawler 5MT Solid axle swap. 37's. / 82 Yota Pickup.
emelianenkov is offline   Reply With QuoteReply With Quote
Old 05-07-2013, 10:19 PM #32
ThePMFG's Avatar
ThePMFG ThePMFG is offline
ThePMFG is on a distinguished road
ThePMFG's Avatar
i want to do this mod, but have a question... when i pull the lower part of my driver side dash panel, just behind where my center diff lock button is and behind the other 3 blank places for switches i've got two taped up factory plugs for something? it's directly behind where those factory cut out holes are for switches...? does anybody know what they are for?
http://www.toyota-4runner.org/member...06-switch1.jpg
2004 SR5 4WD, front-toytec/5100's, rear-metal tech/ICON long travel, 285/65R18 TW Wardens, Shrockworks bumper w/9500 winch, RCI front skid, BAMF LCA skids and sliders, WMW roof rack, CBI premium tire carrier, Trail Toys NSA box for some fun stuff, Scuba Mod, VSC Mod, HCF Delete, K&N, ScanGaugeII, Optima Redtop, interior LED swap, Cobra 29LTD Chrome, Panasonic Double Din DVD touchscreen w/ipod hookup, weathertech digifit f-r-c.
ThePMFG is offline   Reply With QuoteReply With Quote
Old 05-07-2013, 10:22 PM #33
ThePMFG's Avatar
ThePMFG's Avatar
i'm just curious if these might have anything to do with TRAC or something. i know i've seen other t4r's and the factory TRAC button is directly to the right of the center diff button, which is right where these seem to want to be mounted?
Old 05-07-2013, 10:42 PM #34
Real Name: Alex
Real Name: Alex
Disable VSC, TRAC, and ABS without damaging factory wiring
One might be trac and one might be 115A power
Old 05-07-2013, 11:13 PM #35
ThePMFG's Avatar
ThePMFG's Avatar
yea the diagram of "controls" in the owners manual labels the 3 buttons from the left as "aux power" "center diff lock" and "TRAC" and leaves the 4th hole blank. but if my truck didn't come with a "TRAC" button, (i have an SR5) would everything still already be wired in from the factory so that all i have to do is find and simply plug in a "TRAC" button? also would this "TRAC" button disengage my VCS and TRAC?
Old 05-08-2013, 03:40 AM #36
Real Name: Alex
Real Name: Alex
I think so! FJ's are like that with the ATRAC. Just buy the button and rock n' roll
Old 05-08-2013, 10:58 AM #37
ThePMFG's Avatar
ThePMFG's Avatar
God I hope it's that simple for me, but has anyone else ever seen a 4runner come with those already back there? I have a 2004 V6 SR5 4WD.
Old 05-13-2013, 05:05 PM #38
e10pvmt e10pvmt is offline
e10pvmt is an unknown quantity at this point
quick question here...someone may know...if i was to completely remove these system, ABS, TRAC, and VSC will the truck still start? I have converted to power steering hydroboost and completely changed my brakes. I have taken the wireloom apart and would like to remove the VSC computer altogether and all the wiring that goes with it. But i wanna make sure when i put my truck back together it will still run. BTW its a 2003 1gr 2wd
2003 sr5 v6
2wd pickup IFS
Supra IRS
Full airride chassis
Complete shave and Stock floor bodydrop
e10pvmt is offline   Reply With QuoteReply With Quote
Old 05-20-2013, 06:00 PM #39
ThePMFG's Avatar
ThePMFG's Avatar
So with your mod described here... If I'm following correctly... You just splice a 2 prong "on/off" switch into the top (white-black striped wire) and then rock and roll good to go? No funky grounding or anything?
Old 05-20-2013, 10:03 PM #40
Real Name: Alex
Real Name: Alex
Nope! Plain and simple
Old 05-20-2013, 10:26 PM #41
ThePMFG's Avatar
ThePMFG's Avatar
Hmmm ..... I've done this and nothing is happening. Hell I can completely unplug the whole thing and nothing happens. I've got a 2004 SR5 V6. Are they different or something?
Old 05-20-2013, 11:24 PM #42
morphious's Avatar
morphious morphious is offline
Real Name: John
morphious is on a distinguished road
morphious's Avatar
Real Name: John
PMFG, I had the same problem when I did this mod. Before I did the mod I to completely removed this plug and noticed nothing happened, but it works when you unplug the connector above this that has three wires (black, red, and white I believe). These 3 wires run from the brake fluid reservoir connector to the skid control unit under the driver side dash behind the fuse block. I cut the red wire which is the ground (I believe would need to check schematic) and put a switch from there as I did not want to run a wire through the firewall. Here is the link to when I did mine.
Skid Control Computer
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
morphious is offline   Reply With QuoteReply With Quote
Old 05-20-2013, 11:41 PM #43
ThePMFG's Avatar
ThePMFG's Avatar
Ok, so you're saying to just splice the two prong connector into this red wire coming out of the plug with 3 wires right by this? Can you take a picture of the one you tapped into?
Old 05-29-2013, 11:32 PM #44
My06runner's Avatar
My06runner My06runner is offline
My06runner is on a distinguished road
My06runner's Avatar
I just did the 12v constant power mod last night and found the same thing. So I called Toyota today and the person I talked to siad that if I don't have switch then my 4runner doesnt have the feature. However I just got my tr4 and haven't had the chance to put it in the dirt to see what happens when I break the tires loose.
So my question to the guru of this mod is... Does my tr4 have the VSC,TRAC options even though I have no switchs for them?
My06runner is offline   Reply With QuoteReply With Quote
Old 05-30-2013, 12:15 AM #45
Real Name: Alex
Real Name: Alex
No switch, no option.
Not sure what those connectors are for
abs , disable , mods 3rd gen sr5 , trac , vsc
Another VSC Trac, VSC OFF, ABS, BRAKE!, and Swerve/Slippage Light PROBLEM!!! HotSauceT4r 4th Gen T4Rs 50 11-22-2023 08:23 PM
ABS, VSC Trac, and VSC Off lights are all on thumper 4th Gen T4Rs 27 09-15-2018 07:17 AM
How do bigger tires affect VSC, TRAC, ABS martini 4th Gen T4Rs 8 11-12-2009 12:19 PM
Brake, VSC Off, VSC Trac, ABS Lights 024runnerrich Problems & Warranty Issues 1 01-14-2006 01:30 PM
Brake, VSC Off, VSC Trac, ABS Lights 024runnerrich Maintenance/Detailing 0 01-13-2006 10:02 PM
