09-29-2013, 05:13 PM
#61
Originally Posted by morphious
dereky,
I am not 100% sure as I did not use a stock switch when I did this mod, but I believe once the switch is modded pushed in is on and system is engaged and working, popped out and the switch disconnects internally turning it off thus causing an interrupt in the system and thus enabling the mod. Once the mod is activated the only way to reset the system is to push the button in and power off and restart as this allows the system self test, find no faults and re-engages the system. The momentary TRAC OFF switch is used to turn TRAC OFF only up to a certain speed, approx. 23 mph I believe, this mod allows the system to stay off at any speed until you decide to turn it back on.
So it sounds as though all is working correctly then?
09-29-2013, 06:07 PM
#62
Real Name: John
Real Name: John
If this is what you get when the mod is activated "Lights on dash = VSC TRAC, TRAC OFF, ABS" then yes.
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
10-06-2013, 12:09 PM
#63
Originally Posted by emelianenkov
No switch, no option.
Not sure what those connectors are for
When you say no switch no option that means no switched option right. That doesn't mean I dont vsc,atrac at all right.if so I would still be able to do the mod to turn that stuff off?
2006 V6 4x4 SR5
2003 Ford Expedition
1999 Ford f-150
1988 Ford Ranger
10-09-2013, 11:17 PM
#64
Do you guys use this mod when off road/rock crawling. It just seems like you would want it on if one wheel started to spin the power would transfer to the other side. And when I say on I mean not using the mod.
2006 V6 4x4 SR5
1999 Ford f-150
1988 Ford Ranger
10-10-2013, 06:06 PM
#65
Real Name: Alex
Real Name: Alex
It's good when ATRAC starts being an *******. Also good in bad conditions, like snow, when you want some wheel spin!
-07 FJ Cruiser 6MT. 185k. Camburg 3.5" Long Travel.
-17 Subaru WRX STI. 305AWHP/311AWTQ. Warranty delete.
-13 Subaru Crosstrek CVT. / 05 Subaru Outback limited 5MT. Flip project.
-99 Ford F-250 Super Duty Lariat 4x4. 7.3 PowerStroke. SCLB.
-93 Toyota Pickup Crawler 5MT Solid axle swap. 37's. / 82 Yota Pickup.
10-20-2013, 11:16 PM
#66
If installing a locker is a good idea to have this mod?
2006 V6 4x4 SR5
1999 Ford f-150
1988 Ford Ranger
10-28-2013, 09:44 PM
#67
So I went to the desert this weekend and experienced atrac for the first time. What a P.O.S. design. It should be illegal to install that without a switch to turn it off. Definitely will be doing this mod before my next trip.
2006 V6 4x4 SR5
1999 Ford f-150
1988 Ford Ranger
10-28-2013, 11:35 PM
#68
Real Name: Alex
Real Name: Alex
With a locker you should disable it
And yeah ATRAC sucks
12-06-2013, 03:33 PM
#69
Real Name: Stephan
Real Name: Stephan
Amazing!
New to the forum, but found this thread when searching how to disable ATRAC. This mod is truly amazing. Just did it this morning and took her out for a ride and the truck drives just like it was meant to! I want to thank the inventors for such a great trick!
12-07-2013, 02:39 AM
#70
Real Name: Alex
Real Name: Alex
Welcome to the forum and I'm glad you enjoy the mod. This was the first mod I ever did to my truck haha.
12-09-2013, 07:00 PM
#71
Real Name: Ryan
Real Name: Ryan
Can someone tell me what wire to splice. I thought it was the white black on the two prong but just double checking
12-09-2013, 07:28 PM
#72
Real Name: John
Real Name: John
Read this starting at post # 6 on how I did mine. Red ground wire on 3 prong connector.
VSC Mod AWESOME even for 2wd!!!!!!
Pic of the new switches I installed.
12-24-2013, 01:44 AM
#73
Registered User
Real Name: Morris
Registered User
Real Name: Morris
I believe what you guys are trying to accomplish is the VSC mod using the stock VSC switch. In order for this to work you need to do the mod then mod the switch, as the stock switch is momentary and you need a switch that will stay on or off. The mod itself is pretty simple and well covered, but here is a link to mod the switch. Hope this helps.
How to convert an OEM momentary switch - Toyota FJ Cruiser Forum
Wiring is such a hard thing for me to wrap my head around. I assume if i was to do what this guy did with this switch mod, it would be taking care of everything?
12-24-2013, 03:34 PM
#74
Real Name: John
Real Name: John
To be honest now after rereading several threads, I am not sure. The switch Mod was done for the FJ which prior to a certain years it did not come with a switch to turn off VSC so they are modding that switch to be on/off. On our trucks all that is needed is a temporary disruption in the VSC circuit to enable the mod until the truck is re-started so a momentary switch should work. I don't know if this switch is a pulse momentary or momentary the whole time the button is pressed as it takes about 1/2 a second or so for VSC to be disabled and if it is pulse momentary I do not know if that is enough time of disruption to enable the mod. I hope this makes sense.
12-24-2013, 04:39 PM
#75
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Ummm.....that just read as Charlie Brown's teacher.....lol
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Another VSC Trac, VSC OFF, ABS, BRAKE!, and Swerve/Slippage Light PROBLEM!!!
HotSauceT4r |
4th Gen T4Rs |
50 |
11-22-2023 08:23 PM |
ABS, VSC Trac, and VSC Off lights are all on
thumper |
4th Gen T4Rs |
27 |
09-15-2018 07:17 AM |
How do bigger tires affect VSC, TRAC, ABS
martini |
4th Gen T4Rs |
8 |
11-12-2009 12:19 PM |
Brake, VSC Off, VSC Trac, ABS Lights
024runnerrich |
Problems & Warranty Issues |
1 |
01-14-2006 01:30 PM |
024runnerrich |
Maintenance/Detailing |
0 |
01-13-2006 10:02 PM |
