Old 01-04-2017, 03:27 PM #16
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
Originally Posted by Lolrax View Post
Oh yeah I heard about that ;)
Rear Wiper arm problem solved
there it is! it's crazy how much it annoys me that the rear blade doesn't give a crisp, clean swipe. every damn morning!
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 01-05-2017, 04:05 PM #17
Lolrax's Avatar
Lolrax Lolrax is offline
Lolrax is on a distinguished road
Lolrax's Avatar
It's still not great even with the spring. Better than it ever was, but it's just a bad design. My wife's 06 GX gives a perfect swipe every time. Disappointing!
2005 4Runner V6 Limited 4WD Pacific Blue Metallic: Bilstein 5100 + Moog FJ Springs front, Superflex rear, OEM LED tails, Dinoc woodgrain conversion, Kenwood DDX371
Lolrax is offline   Reply With QuoteReply With Quote
Old 11-27-2017, 01:12 PM #18
luckyluke luckyluke is offline
Real Name: Lucas
luckyluke is on a distinguished road
Real Name: Lucas
Originally Posted by DanLuo4Runner View Post
There is no real adjustment to this rear wiper arm/blade. The arm typically gets pulled from car washes. I do have a permanent fix for this though. You'll need to pull the entire arm off the splined motor shaft. But first, remove the plastic end cap by slightly spreading the sides and slipping it off the end of the arm. Loosen the nut and with a small pulley, remove the whole arm from the splined motor shaft. Dissasemble the entire arm by carefully bending the blade arm away from the arm itself. It will come off, just don't force it too much. Turn the arm over and remove the spring between the long and short arm sections. Carefull, this spring is tough and you'll need to use some force. The repair consists of two steps. First, bend the spring ever so slightly to shorten the overall length of the spring. Just slightly. This will put a little more downforce pressure on the arm to the glass. Now for the big part. Notice how the arm works without the spring. The arm pivots in the center against the small arm section. There is a flange that stops the arms movement against the spring's force. That stop flange needs to be shaved so that the arm closes further (1/4" slightly yields decreased angle to the window). This shaving off of 1/4" from the stop, will make the arm apply greater pressure/travel to the window itself thereby pressing the wiper blade against the window nicely. Reassemble and reistall the arm. Problem should be corrected forever. I've done it to mine and it works great now, better than new. Puts nice down pressure against the window to wipe nicely, and returns nicely to the rest position. Good luck......let me know how you make out.....
Just done it. Works much better. I wish I found this post earlier.
2007 SR5 4x4 V6. Bilsteins 5100 all around. Front set to 1.75. Daystar spacers 1.5 in the rear. Stock springs. Cooper Discoverers A/T3 265/75R16.
luckyluke is offline   Reply With QuoteReply With Quote
Old 11-24-2021, 05:48 PM #19
Flyboy52 Flyboy52 is offline
Flyboy52 is on a distinguished road
My 2014 4runner rear wiper blade does not contact the window. I replaced the wiper blade and arm, and still minimal contact with no tension. The blade swings down from the top of the window and has no spring. Anyway to solve this problem?
Flyboy52 is offline   Reply With QuoteReply With Quote
Old 11-25-2021, 08:46 AM #20
ElDuck ElDuck is offline
ElDuck is on a distinguished road
Unfortunately, your best bet here.might be to look in the 5th gen section. Though, perhaps a similar design and you could see if some of the ideas in this thread apply to what you have.
ElDuck is offline   Reply With QuoteReply With Quote
Rear Wiper doesn't work... H1_VLTG 4th Gen T4Rs 8 12-04-2022 08:56 PM
Dead battery from rear wiper on 06 4runner pcarpilot 4th Gen T4Rs 19 05-16-2019 12:30 PM
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
Tailgate Window getting stuck on Rear Wiper. Help! tineman06 3rd gen T4Rs 7 10-05-2009 10:31 PM
BO019-03 10/17/2003 Wipers/Washers - Poor Rear Wiper Performance CBR_GUY_IA TSB 0 07-12-2009 10:43 PM
