Old 07-05-2017, 12:43 PM #1
AUwheels AUwheels is offline
AUwheels is on a distinguished road
How not to change your Alternator
2007 4.0 liter
alternator died after I made it to the office. OK, no problem, I'll swap it out right here.
10-15 minutes to remove ground, plug, top bolt, bracket bolt.
Then comes the bottom bolt.
Here is what not to do
Try to reach it with a breaker bar and extender
you will round the nut and say all kinds of bad words.
remove the fan/shroud and get to it with an impact and a 14mm socket.
otherwise you will spend several hours grinding off the bold head, trying to drill it out, crying, pleading, and finally you have an epiphany!
you remove the plastic back housing, remove the four 8mm bolts holding the front and back together, hit it with a hammer/screwdriver until it comes apart. Then you hit it one more time for being a jerk before you separate the two haves and remove it from the bay.
FWIW, the new alternator, new belt, etc took less than 30 minutes to install including refilling the radiator.
AUwheels is offline   Reply With QuoteReply With Quote
Old 07-05-2017, 01:24 PM #2
ghs215 ghs215 is offline
ghs215 is on a distinguished road
Originally Posted by AUwheels View Post
2007 4.0 liter
Yep, been there, done that..........
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
ghs215 is offline   Reply With QuoteReply With Quote
Old 01-30-2022, 05:16 PM #3
tjndvn tjndvn is offline
tjndvn is on a distinguished road
Covid Change
Thank God mine went better than that. Just changed mine while on Covid intermission from life. Thanks for your story!
tjndvn is offline   Reply With QuoteReply With Quote
4th Gen alternator change darrowood 4th Gen T4Rs 1 04-06-2015 08:43 PM
Alternator & belt change - Now hums at low speed ncollom 4th Gen T4Rs 1 09-20-2013 10:16 AM
V6 alternator change wrestler157 4th Gen T4Rs 1 10-26-2012 09:25 AM
Will or should low mileage oil change standards change related to warranties 5,000/6m jow 4th Gen T4Rs 2 01-08-2012 08:03 PM
