Old 01-19-2011, 03:48 PM #1
JBReagan JBReagan is offline
JBReagan is on a distinguished road
Question Mode Damper Servo Sub Assembly
I have a 2006 4Runner Sport V8. I noticed a "clicking" sound coming from the front passenger side of the dash. As I investigated this further, it seems that I have a problem with the "Mode Damper Servo Sub Assembly (Air Outlet Damper Control Servo Motor)"
My question is, has anyone ever replaced or repaired one of these servos on a 4th Gen 4Runner and if so do you have any tips or steps to follow?
Jim
JBReagan is offline   Reply With QuoteReply With Quote
Old 01-19-2011, 09:36 PM #2
Acidmeld's Avatar
Acidmeld Acidmeld is offline
Acidmeld is on a distinguished road
Acidmeld's Avatar
Its not too difficult. You should probably pull off the glove box and lower air duct. After that youll see what to do.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
Acidmeld is offline   Reply With QuoteReply With Quote
Old 01-19-2011, 09:40 PM #3
THEROK THEROK is offline
THEROK is on a distinguished road
Jim
there is more than one servo as i've come to understand. one of mine went bad and the part wasn't cheap to replace. i didn't do it myself. had the dealer handle it. i think in total they charged me a few hundred? not sure.
sorry i can't be of more help, but just letting you know you're not a lone ranger with this bad servo deal.
THEROK is offline   Reply With QuoteReply With Quote
Old 01-20-2011, 04:09 PM #4
Its not as simple as just pulling off the glove box and lower panel. That would work for the "Air-Mix Servo" but I think I'm going to have to pull out the blower unit as well to get to this one. I'm thinking this is going to run more than just a few hundred bucks from the dealer. It would involve a lot of man hours I think which that is where 90% of this expense will be.
Old 03-30-2015, 06:34 PM #5
ATL4runJeff's Avatar
ATL4runJeff ATL4runJeff is offline
ATL4runJeff is on a distinguished road
Servo
Having the same issue with driver side servo clicking - seems possessed.
Have had this clicking noise for several years but the thing still works.
Glad to finally see some info on this issue, I thought it was coming from the fuse panel all this time.
ATL4runJeff is offline   Reply With QuoteReply With Quote
air , blower , servo , servo motor , vents
ST001R-05 09/08/2005 Steering - Highway Speed Steering 'Flutter' CBR_GUY_IA TSB 2 11-30-2010 05:45 PM
Can't switch to AUX mode using either button on '07 Sport crushlee Engines / Suspension / Wheels / Tires / Audio / Accessories 4 09-09-2010 12:35 AM
Transmission Leak - Dip Stick Assembly smallbrian 4th Gen T4Rs 5 01-07-2009 09:12 AM
4WD Mode Locked, VSC + Engine Lights On cbob Maintenance/Detailing 1 11-16-2008 05:31 PM
V6 Gas Mileage: 2wd mode VS 4wd mode the_josh 4th Gen T4Rs 0 11-12-2004 01:33 PM
