Originally Posted by BackOff
Pull HARD.
I just went and looked at it, maybe wiggle and pull.
That little tab really has a good grip on the white cover on.
Found the actuator on ebay for $140.
Great, thanks so much. I'll try wiggling it this time. I was trying to be a little careful to not damage anything, but I don't seem to have an alternative at this point. I'm hoping clean-up and lubrication can fix the issue. I've sprayed it with WD-40 a couple times, and it seemed to work fine for a month or two each time. I know WD-40 is no fix, technically it's not even a lubricant but I didn't really see a point in doing thorough lubrication without having the mechanism fully exposed.
