Originally Posted by w210210
Dont forget 5VZ has Iron block which means it will outlast 1gr fe ...
1gr fe dont have a good lifespan as 5VZ ...
5VZ is non interference engine ... so when timing belt will broke it wont destroy the engine ..
1GR has many problems like head gaskets ....
Hi folks, Just new in posting here. I'm looking at 3.4 and 4.0 4runners for a purchase, and all have over 290,00 kilometres (about 185000 miles). motorreviewer.com states that the 1GR-FE 4.0 has cast iron sleeves that are too thin to bore out, so a rebuild is not possible and another cylinder block must be found. The same applies to the 3.5 V6 FE motor. As far as I know, the 3.4 can be rebuilt using the original cylinder block. Does anyone else have knowledge of this? thank you.
