Where is transfer breather?
SSt4r
Does anyone know where the transfer breather is on the 4th gen V8? A quick look & I couldn't find it.
Uneek, my V8 only has the single breather under the hood. I think that is for the front diff.? Was looking to extend the transfer breather but not sure where it is.
The V8s must be different. Mine is right next to the front diff breather where Uneek described also. I have a V6 though.
Sorry this doesnt help at all, but just throwing it out there.
Edit-This is a quote I found from a google search. It came from this site though. It may or may not help.
"As an addendum, you can find the breathers for the transfer case and transmission on the 04 V8 hiding between the firewall the inlet manifold directly above the location where the transmission mates to the block. You need to climb up on top of the engine to find it. With a torch you can see the white or silver valve.
By approximation, it would be only 2-3" lower than the front diff breather."
Found it. The transfer & transmission breathers are on top of the front of the transmission (bell housing?) where it meets the engine. Pretty much inaccessable.
charlesz
