02-16-2011, 05:27 PM
Cargo Cover Clips?
Hi all, I recently purchased a cargo or tonneau cover for the back of my Runner from Ebay. However, I was wondering if this thing just kinda slides in those holes with the bolt and the two slits in the rear cargo area of Runner or do I have to buy "cradle-like" clips to hold it in place? It fits if I depress the springs on the ends of the cargo cover and slide it in the holes but I remember from my 2002 4Runner, the cargo cover slid in place starting from the top which would make it almost impossible to slide out.
Thanks for your help,
Snes
2007 4Runner Limited V8
02-17-2011, 12:05 AM
Would anybody mind looking at their setup and letting me know?
Thanks!
02-17-2011, 01:04 AM
The factory one on the 4th gen just goes in the holes and pulls out into the cutouts.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
02-17-2011, 02:48 AM
Super Moderator
Super Moderator
The cover has spring loaded ends that you push towards the middle and it sits in square holes on the cargo side walls. When the cover is closed, it slides into slots on end. There isn't any brackets that hold the cover in place other that slot piece when cover is closed.
Here are bad pics of it. (I took these pics for the liners.) If you need, I can get better pics tomorrow. Truck's outside and it's pouring now.
The slot (by the top of the taillight) is where the cover latches onto when the cover is closed.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
02-17-2011, 09:35 AM
Right on Uneek! That is what I was looking for. I wanted to find out if the spring loaded ends just inserted in those square holes. Seems like a rather large G-force or bump could potentially knock it out of place! Nevertheless, I thank you for you time.
Snes
02-17-2011, 02:50 PM
Geeze Uneek, got oil??
2005 4X4 V8 LTD 4Runner Black
Driver's side upper assist handle, tail/stop bumper light mod, Flowmaster 50 suv with side exit exhaust and Valor tip, 20% tint on fronts and 27% add'l tint on rear window, DIY blacked-out headlights, Stainless door sills, VIP Plus w/GBS alarm, OBX pedals, Can. hood protector, ash tray kit, '06 LED tails, T&H Euro bar, OME lift, Spidertrax spacers, LT275/70R17 Cooper AT3s, HIR bulbs in LB and fogs, VSC mod, AFE Pro Dry S filter, White LED cluster and HVAC
02-17-2011, 04:39 PM
Snes
As Uneek said, the spring loaded ends just fit into the two side sockets. I have not had mine come out in the 8 years I have had it. Also, there are 4 straps with 'c' clips that clamp around the rear seat headrest posts to hide the area between the rail and seat backs.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
02-17-2011, 06:57 PM
Forgot to give you props as well Acidmeld...Thanks!
01-21-2015, 10:13 PM
I realize this is an old thread but ...PLEASE HELP
I have an 07. I found a cargo cover on the Bay. hooks up nicely on the front end but when I drew it out i realized I didn't have any place to hook it. The 07 has four removable covers two at the front for the spring loaded ends on the cover but the covers at the rear don't accept the ends of the cover. Anyone know where to find these parts???
07 4r SR5 V6
no mods yet
01-21-2015, 10:59 PM
Are you sure you don't have the two molded recesses on either side, just above the separation between the lower and upper panels? They would be roughly inline with the top of the tail lights, and just before the panels start to curve into the rear corner post. You can see them in the photo in the post quote you replied to. There should be two plastic tips, one on each side of part of the cover that pulls out, that fit into these to keep the cover in the extended position. You pull the cover into the lower part of these openings, lift it up a bit, and let it retract back so these tips rest on the small supports molded into the recess. If your vehicle has the recessed sockets to hold the cover rail just behind the rear seat, then you should have the support recesses near the tailgate.
