Originally Posted by Cox
I have an 03 sport and when I hit 60mph the steering wheel starts wobbling really bad. It has a little over 90,000 miles on it. Has anyone ever had this or know what it is, and how to fix??
Also when the A/C is on it blows cold but after a while the A/C light will just start flashing and won't really blow as cold anymore. Any thoughts???
I haven't had the steering vibration on the 4Runner, but I used to have it on the M3. It would have a slight vibration any time I used to go over 60.
did you recently hit a big pothole, or a curb, or something with your wheels? there's a chance you bent one of them...
Another one could be warped rotors, although, unless they are REALLY warped, you would only feel vibrations under braking (even slight braking at high speeds)...
I say go get your wheels balanced first. see if that helps. If not look at maybe getting an alignment done.
On the M3, balancing didnt help, alignment didnt help, it ended up being the bushings i believe. Im sure more members will chime in. Just my 02.
