Originally Posted by jayjaytuner
anyone know if a 1.5" bl, and 3/2 spacer lift would fit these??
i know the stocks are 30.56" high 10.43" wide
and these are 33.82" high 11.22" wide
also, does anyone have any pics of there t4r's with 285/75's??
I just installed 32's (technically 31.9) AT's and had slight rubbing. I trimmed the inner liner and mudflap. I do not have spacers because the right wheel offset takes care of it.
But your will need spacers - either way. From what I can tell, 33's (almost 34); will require trimming.
Do not be scare of this - the inner fender lining is cheap, thin, plastic - you can cut with a sharp knife. There are two bolts on the driver and three passenger. I unbolted and cut "like paper" with a pair of snips. It took 20 mins.
