Old 03-11-2011, 10:06 AM #1
BBV BBV is offline
BBV is on a distinguished road
BBV BBV is offline
Rear wiper/rear defroster/dome light not working... fuses?
I got in to leave for work and hit the rear defrost button and I got nothing. Then I turned the knob to turn on the rear wiper and nothing.
Whenever the doors open, the dome light does not come on.
I have only had this 4runner for like 3 weeks, so im a little stressed out about these issues
hope its an easy/cheap fix
apprecaite the help
BBV is offline   Reply With QuoteReply With Quote
Old 03-11-2011, 01:37 PM #2
cali_axela cali_axela is offline
cali_axela is on a distinguished road
The rear wiper and defroster probably just aren't working because they need to learn where the "up" position is for the rear window glass -- it needs to be "re-taught" every time the battery is disconnected. Just roll the rear window down a little bit, then roll it back up all the way, and KEEP HOLDING DOWN the up button for about 2 extra seconds after it's all the way closed. This teaches it where the fully-closed position is, and those features will be enabled again.
As for the dome light, have you tried replacing the bulb? Hopefully it's that simple.
04 V8 SE 4WD
cali_axela is offline   Reply With QuoteReply With Quote
Old 03-11-2011, 04:34 PM #3
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
set the dome light switch to "door" & yes, reset the wiper
chaz is offline   Reply With QuoteReply With Quote
Old 03-11-2011, 11:55 PM #4
BBV BBV is offline
BBV BBV is offline
ah sweet.... the rear window was down just a little bit, so now that its all the way up, the wiper and the defroster are working.
i dont see a "door" setting for the dome light. i just see the moonroof/sunroof, whatever it is, switch between the two lights. ill check again a little later. maybe im just blind
appreciate the help
Old 03-12-2011, 10:44 AM #5
chaz's Avatar
chaz's Avatar
if ur talking about the map lights by the sunroof switch, those dont operate with the doors unless u do the mod for them .
Old 03-12-2011, 02:55 PM #6
BBV BBV is offline
BBV BBV is offline
oh... im just used to opening the door and lights coming on.. no lights come on w this vehicle. ill have to go investigate
Rear Window and Wiper stopped working wperk 4th Gen T4Rs 25 09-26-2018 01:08 PM
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
4th Gen: Running board light not working! BIGBLACKV8 Problems & Warranty Issues 1 06-13-2010 12:19 AM
Rear brake not working desmo907 4th Gen T4Rs 1 03-12-2009 04:37 PM
