Originally Posted by kristir77
Recently the 2 front drivers vent on left side are not blowing out cold air, like the rest of the vents. The 2 front passenger vents and back vents are OK.
Mechanic states there is a small leak in the evaporator core and they would have to remove the steering wheel & dashboard to repair. It would probably take 5 to 6 hours of labor, costing around $500.00 And the cost to replace the evaporator core is around $200. So total cost of $700 plus.
Does this sound resonable?
Has anyone tried to take apart their dash to get to this part/area? Is it hard?
What do you all recommend???
old post but just wanted to add important accurate info for anyone else searching this problem.
the 4runner a/c system acts weird in that this is the normal result of when the system runs low on Freon, the side of the evaporator for the passenger compartment still blows cold but the rear vents and the drivers side will be warm air.
add 1 can of Freon and everything will work fine again. finding the leak is your next challenge, if its the evaporator is a huge expense to replace, the whole dash needs to come out right down to the bare firewall
