I recently purchased a 2003 Toyota 4runner (a new T4R member) and realized that the back seat center console was broken. When you pull it out, it should pop-up but the back connections to it is broken. Does anyone know of any cheap websites to buy a whole new one or how i can fix this the cheaper way?!
ok gimme a few minutes and ill do some searchin around and see what i can find part wise.
i dont think thats a cheap and easy fix, i think the whole thing meeds to be replaced. maybe someone else will know more. but in the down time might as well post the links just in case.
thank you very much a truly appreciate it! Quick question, do you know how to reset the maintenance light? Do you just put the key in, hold reset, then turn it on and then off? I just recently changed the oil, and for some reason, i did what it said to add 5.5 quarts of oil and now my oil stick is telling me it is to much? But thats what the manual said! Ha Sorry to bother you!
to reset the light, hold the reset button then start your 4runner. hold the reset button the whole time til it starts to flash a few times then go off. thats how i do mine and it works. im still researching the part. its a tough find.
i cant seem to find the exact part number via searching. the one i found on this forum i dont think is the right one. i would suggest calling a dealership, asking for the parts department, tell them what you need, ask for a price and the part number. that way you know what the dealership charges, and then search that part number on a few sites to compare. im thinking its going to be around $150. so maybe someone else on here will see this and help more than i can, maybe theyll have an idea of an easy fix.
