On the 1grfe we have four cats and four sensors. The four sensors only monitor the health of the front two cats which are located on the exhaust manifolds. I'm guessing the reason they didn't replace those is that they are a pita to remove and install. The sensors can go bad as well because of age, heat, etc. It could even the wiring though I have only seen that once when I helped installed a set of JBA headers on a buddies taco which had seen alot of off roading. If you just need a O2 sensor look up Gadget at URD as he sells them and might hook you up. If its the cat they might either hack off the old one and weld a new one in place or order a whole new exhaust manifold as its one piece. If you need those I have two I'm not using. Those are really your options unless you want to go exploring the in the performance world.
Open diff, auto, bof, suv beats corvettes at a road course. You can't explain that!
My Build http://www.toyota-4runner.org/galler...006-build.html
