04-07-2011, 07:03 PM
Rear passenger door is stuck shut....
Okay, so I did something incredibly stupid. I took all my door handles off to paint them (which turned out great btw) and when I was putting the rear passenger door back together something happened with the door opening thingy. Idk if maybe a cable came loose or something but neither the inside or outside handle can open the door. And I accidentally closed it so now I can't take the panel off to fix it! What do I do?!?!?!
The locks, windows, speakers, lights, etc all work, it's the the handles not working.
Mods on my 2004 Sport Edition: New stereo head unit (Kenwood KDC-HD545U), new front and rear door speakers (Polk Audio db6501 components in the front and Polk Audio db651 full range speakers in the rear, they both sound great), 2 10 inch 10w0 JL Audio subs powered by a Rockford Fosgate P300-1, Door speakers powered by a Rockford Fosgate p400-4, Removed running boards, tinted front windows 20%, tinted rear windows/hatch window 5%, Weathertech Window Visors, Blacked out grille, Blacked out door handles
04-07-2011, 08:43 PM
I guess what I really need to know is there a way to remove the rear door panel with the door closed? Or a way to force the door open w/o a handle?
04-08-2011, 07:05 AM
You need a locksmith to reach between the weather strip and the glass down to the latch and pop it open for you. Its the easiest way. I'd also bring him a schematic of the door mechanism....
2005 Silver SR5 Sport 4x4 128,000 miles (failed cats - failed calipers 3/4 - blown head gasket at 128k - quoted $3000 - $7300 to repair)
1997 Nissan pathfinder SE 304,000 miles - Retired
1973 IHC Scout II 28,000 miles
1972 Honda AN600 45,000 miles
04-08-2011, 07:14 AM
I agree, your local stealer parts dept can print you out a diagram of the inside, latch mech. Sounds like the clip that holds the rod latch on fell off your handle.
2003 4Runner SR5 V8 AWD + Daystar 2.5/1.5 + FJ Swap + Definity Dakota 285/75r16 MT's
2014 Taco 6spd TRD OR billies/dakar HD pack/33's
04-08-2011, 08:47 AM
this is gona be tricky, but do this, open the windows, then remove the screws that holds the panel, the one in the armrest and the lever i think, then try to pop the panel off, pull it towards u and then lift up, just make sure u got all the clips off, its gona take some skills but i have tried it b4, also take the back seat out for some extra room to reach at the bottom. ur gona need to reach up from the bottom to pull the cable.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
04-09-2011, 12:54 PM
So you've done this before and it is possible?
04-10-2011, 08:33 PM
You were right, it's possible. It's a HUGE pain in the rear though. I had to take out the back seat, remove the door weatherstripping, the middle pillar, passenger seatbelt, and floor things, but I finally got it out. And luckily I was able to fix the handle problem, turns out it just wasn't attached to the opening mechanism thingy. Door's back to normal now and I didn't have to pay anyone to do it!!! yay!!!! lol
04-10-2011, 08:35 PM
Btw, here's what the handles look like if anyone wanted to know
04-10-2011, 10:21 PM
nice.
04-10-2011, 10:23 PM
the trick was to make more room inside to get the panel off.
04-10-2011, 10:24 PM
Exactly lol
