Originally Posted by MrBunnyRunner
Does anyone have any suggestions for the rusty nuts inside the frame that keep breaking off?
Yes the weld nuts eventually turn into little rust pimples that end up being completely inadequate later in life. My '06 OEM hitch was rusted pretty bad, and I wanted to put a new aftermarket one that had better corrosion resistance. The weld nuts were the weak spot in the removal process. After two broke loose, I realized that some bolt-drilling was in my future. But it's doable and those nuts can be substituted with a piece of threaded bar stock that is inserted into the frame where the old weld nut used to be. Just make sure it is a material that can take the load. Might not need to be grade 8 equivalent but it can't be soft. I can't remember what grade I used but that was a couple years ago and my Draw Tite hitch is pulling our 21' travel trailer like a champ!
